Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 11-10-2007, 09:41 PM   #31
erricson_nguyen's Avatar
erricson_nguyen is an unknown quantity at this point
Quote: Originally Posted by Robby BMW View Post
Is this kit able to comunicate with ours car pc throug USB?
oh gezz i felt like an idiot lol. why didnt i think of that b4 asking
well i guess this's a stand alone kit
erricson_nguyen is offline   Reply With Quote
Old 11-10-2007, 10:37 PM   #32
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
The one that robby refers to is supposed to be standalone, he has just made a bit of electronics that intercepts the signals and connects to the PC's USB. (he's also done the necessary software).
Or maybe possible to do the same to your one.
Enforcer is offline   Reply With Quote
Old 11-11-2007, 05:35 AM   #33
Robby BMW's Avatar
Robby BMW is on a distinguished road
Don't worry
I asked because I doesn't understand if that TPMS kit is provided of a comunication port and you was looking for a way to connect it to the PC or if you have asked if is possible to use it with my software.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 11-12-2007, 12:15 PM   #34
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Suggestion:
Since the stems/sensors are color coded, anyway to use colors instead of sensor number w/ the option to use those labels in the skin?
It'll make moving sensors around less...annoying...trying to remember which sensor number is associated w/ a color. (i.e. rotating tires)
That was a real PITA w/ my SmartTire system. Always had to keep a list of which sensor was which color and the tire location.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 11-15-2007, 11:53 AM   #35
Robby BMW's Avatar
There isn't any reference at the sensor number in the skin.
Perhaps are you talking about the section "Sensor location" in the config utility?
Old 11-15-2007, 12:22 PM   #36
Sal R.'s Avatar
Yeah, the sensor location in the config. In addition to numbers, or instead of numbers, a color can be assigned since the sensors are color coded too.
On top of that, a label could be added/created w/ the plugin so you can see in the skin which color sensor is associated with a specific tire for quick verification so you don't have to keep opening the config utility all the time.
Old 11-17-2007, 07:58 AM   #37
Robby BMW's Avatar
It's a good idea, I will give a look in it after the 26st because the next week I will be traveling in Spain.
Old 11-17-2007, 01:04 PM   #38
inh
inh is an unknown quantity at this point
Better idea!
In the config app, make so you have 5 sections, numbered 1-5, and then you can assign a sensor to each number. Then, next to each wheel on the car diagram, instead of 'learn' just make a little drop down combo box, and select the sensor 1-5. That way when you rotate tires, just gotta open the config and change which sensor number is at each wheel.
Or instead of sensor numbers, you could do it by the colors on the sensors themselves =]
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
inh is offline   Reply With Quote
Old 11-17-2007, 01:25 PM   #39
Robby BMW's Avatar
The "Learn" button can't be replaced by the drop down lists, but it's posible to move the 5 drop down lists near each buttons.
Old 11-17-2007, 01:36 PM   #40
inh
Why cant it be replaced? Certainly you can move the learn buttons over to the side, next to the numbers 1-5 (or colors) for each sensor (in my suggestion above), and just have the drop downs by the car diagram, right?
Old 11-17-2007, 01:50 PM   #41
Robby BMW's Avatar
Of course, all the controls can be moved.
What I said is that the buttons can't be replaced by the drop down lists because the two controls have diferent functions, you should keep both.
Old 11-17-2007, 02:00 PM   #42
inh
Would you be able to implement this?
I would (assuming I ever manage to get VB6 installed on my computer again (that is what its programmed in right?))
But it would be a lot easier and cleaner if you could do it real quick..
Old 11-18-2007, 06:12 AM   #43
Robby BMW's Avatar
I will give it a look after the 26st when I will came back
Old 12-16-2007, 12:25 AM   #44
mnwcsult's Avatar
mnwcsult is an unknown quantity at this point
Anybody know how to add this to DigitalFX 2.0? And yes I did see the howto at the beginning of the thread. My question actually centers around adding a button. As there seems to be a png file that would need to be edited in addition to modifying the text skins file.
mnwcsult is offline   Reply With Quote
Old 12-16-2007, 12:18 PM   #45
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
If you get all the hardware interfacing completed and working, making a button for it will be the least of your worries. You can either remap an unused button (I think dfx supports changing the buttons without editing the skin) or edit the png if not..
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Velleman K8055 USB I/O Board Extension plugin 307SW_NLD RR Released Plugins 200 04-06-2009 07:02 AM
Use serial port with extension plugin??? guillemasco RR Plugins 5 12-04-2006 07:26 PM
Extension plugin problems festy Road Runner 2 06-23-2006 07:20 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
Extension Plugin help .... Gobby Road Runner 1 06-09-2006 11:27 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
