Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 05-02-2008, 09:24 AM   #61
Ineffigy is on a distinguished road
Thanks! That should be all the information that I need. Bad thing is, I won't be able to do any testing until I get some hardware, is it available for sale yet?
Ineffigy is offline   Reply With Quote
Old 05-07-2008, 09:22 AM   #62
Robby BMW's Avatar
Robby BMW is on a distinguished road
Of course. You have several options:
1) I can provide you the PIC with the firmware already inside and the PCB, then you will have to bought all the electronic components, the 3rd eye TPMS kit, and assemble the device. (Send me a PM if your are interested in this option).
2) You can try to contact DEJAN (a member of this forum) and ask to him if he has yet some whole assembled divice for sell.
3) You can ask to LYHTSPD (another member of this forum), which has produced a smal series of these devices for the people of the forum.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 06-06-2008, 05:21 PM   #63
ASmods is an unknown quantity at this point
I have a Mazda CX-7 with OEM TPMS, I would love this on my car pc screen, anyway to hack the OEM signal? If I replace my OEM TPMS I will get a CEL
ASmods is offline   Reply With Quote
Old 06-09-2008, 10:49 AM   #64
Robby BMW's Avatar
In theory it would also be possible, but this would lead to start from zero the development of a new USB interface.
Old 06-09-2008, 11:11 AM   #65
Robby BMW's Avatar
A new version as been released in the first post of this thread.
1.20:
- Fixed the issue with sliders when multiple plugins are loaded. (More informatinos on this thread)
Old 07-04-2008, 08:15 PM   #66
K4BlOs is an unknown quantity at this point
Itīs great!!!So, what hardware I need for this?
K4BlOs is offline   Reply With Quote
Old 07-05-2008, 02:42 AM   #67
Robby BMW's Avatar
This
Old 07-24-2008, 02:53 AM   #68
a__l is an unknown quantity at this point
Hi Robby BMW,
Could you please share a picture that you used in the RR config? (a car with tires that are numbered withing 1...4) ... if it's possible :-)
a__l is offline   Reply With Quote
Old 08-04-2008, 01:20 PM   #69
Robby BMW's Avatar
A new version (1.30) as been released in the first post of this thread.
Old 08-04-2008, 01:23 PM   #70
Robby BMW's Avatar
Quote: Originally Posted by a__l View Post
Hi Robby BMW,
Here you go
Old 08-10-2008, 04:49 PM   #71
bes51659's Avatar
bes51659 is on a distinguished road
I have just installed the system and I think the learning worked. But I have not installed RR yet as I want to make sure all hardware works first.
Can I somehow start the skin without RR? Or is a simple exe that loads the dll required? Does it exist already?
A 8051 system that controls PC power etc with or without BMW IBus and is a GPS receiver with dead reckoning. mp3car thread
My car installation mp3car thread "showing off project"
bes51659 is offline   Reply With Quote
Old 08-11-2008, 09:37 AM   #72
Robby BMW's Avatar
No, but you can use "TPMS Doctor" to test your hardware without RR.
Old 08-11-2008, 04:56 PM   #73
bes51659's Avatar
Yes, off cause! Sorry.
I've tried it now and it worked. I must say that the TPMS has been the easiest to install of all functionalities I've installed.
I do have some problems getting updates from the sensors, aspecially the sensor closest to the reciever, but I'll read thru the threads and see if I can find something there.
Old 08-16-2008, 05:01 AM   #74
Robby BMW's Avatar
That is strange because normally are the sensors farthest that could have some problems, maybe you need an external antenna.
Old 08-16-2008, 07:43 PM   #75
bes51659's Avatar
Hi Robby
Thanks for your effort!
I am considering an external antenna according to your previous drawing but I also think there might be a problem with the learning usecase....
I have relearned my system several times (without doctor and config up at the same time) and this time it is wheel 2 that causes me problems. In fact I get only one value at learning and then it is silent. (If I erase data it stays with question marks. See below)
[media]http://web.comhem.se/mulle4/TPMSDoctor.jpg[/media]
Q1) Could it be that collision makes the ID wrong and then the sensor is never seen again? Or do you have retries? Should I maybe deflate below 1,5Bar and back again to force sensor into "init mode" to get more frequent updates?
Q2) Why is this? I have observed (by accident) that the abort prompt sometimes goes away before I've even started to deflate the tyre, or VERY soon after I've started. I become very suspicious that a valid learning really has taken place.
Q3) If I have a problem with one sensor, do I have to relear all tires or can I just relearn that tire? Unless the ID is already used I don't see why not.
Q4) When I use TPMSDoctor on my 480x800 display the bottom gets cut-off entirely and I do not get access to the buttons at the bottom. I then have to violate the screen resolution with 600x800 (which will give the screen a nasty offset) when I need to use them. Can I please get a smaller layout version? (Am I really the only one that has had problems with this, or am I the only one rude enough to ask?)
Once I am at it, I would really like a timer on all sensors in TPMSDoctor to show have many seconds that has passed since last update. Or something else that has the effect that I can get an idee of how well the system is working.
I have read thru this thread at last and I have put some gold nugget post links here.
Edit:
I just seen in post one (:-)) that there is a 16 bit CRC in the message so the learning should not get confused by collisioned messages. (Why not show ID also in TPMSDoctor? Or save all traffic in a log file? Is it not sent from pic to PC?) Still, something seems to be wrong with "learning".
(btw. I only count 12 bytes)
Edit 2:
Since we know that we will get one transmission every 60s in normal mode we know if messages are lost. This could be used for finding best position for receiver/external antenna. A percentage calculation in TPMSDoctor maybe?
Velleman K8055 USB I/O Board Extension plugin 307SW_NLD RR Released Plugins 200 04-06-2009 07:02 AM
Use serial port with extension plugin??? guillemasco RR Plugins 5 12-04-2006 07:26 PM
Extension plugin problems festy Road Runner 2 06-23-2006 07:20 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
Extension Plugin help .... Gobby Road Runner 1 06-09-2006 11:27 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
