Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 08-19-2008, 07:18 AM   #76
Robby BMW's Avatar
Robby BMW is on a distinguished road
Quote: Originally Posted by bes51659 View Post
Hi Robby
Thanks for your effort!
I am considering an external antenna according to your previous drawing but I also think there might be a problem with the learning usecase....
I have relearned my system several times (without doctor and config up at the same time) and this time it is wheel 2 that causes me problems. In fact I get only one value at learning and then it is silent. (If I erase data it stays with question marks. See below)
[media]http://web.comhem.se/mulle4/TPMSDoctor.jpg[/media]
It sounds like you have a lazy sensor.
Have you tried in running conditions (driving the car) if the data are updated?
Q1) Could it be that collision makes the ID wrong and then the sensor is never seen again? Or do you have retries? Should I maybe deflate below 1,5Bar and back again to force sensor into "init mode" to get more frequent updates?
As you have already noticed, ther is a 16 bit CRC in the message, so each data collision or bad signal reception will be automatically ignored.
Also, deflating the tire below 1,5Bar and go back again may be helpfull if there is some difficulty during the learnig procedure.
Q2) Why is this? I have observed (by accident) that the abort prompt sometimes goes away before I've even started to deflate the tyre, or VERY soon after I've started. I become very suspicious that a valid learning really has taken place.
Generally, this problem is due to an incorrect cleaning of the USB buffer, the most likely causes are the simultaneous use of several programmes which have direct acces to the device, like TPMS Doctor or RRTMS Plugin and RRTMS Config.
When the "learnig" procedure is performed, any program, with the exception of Config Tool, should to be stopped in order to prevent any interference with the USB buffer.
Sometimes it may be useful to disconnected and reconnect the interface before to perform the learning procedure for each sensor.
What software (and release) gives you this issue?
Q3) If I have a problem with one sensor, do I have to relear all tires or can I just relearn that tire? Unless the ID is already used I don't see why not.
The system doesn't store any identical sensor ID, but you can replace any sensors with a new one (with different ID) without the need to re-perform the procedure for each sensors.
Q4) When I use TPMSDoctor on my 480x800 display the bottom gets cut-off entirely and I do not get access to the buttons at the bottom. I then have to violate the screen resolution with 600x800 (which will give the screen a nasty offset) when I need to use them. Can I please get a smaller layout version? (Am I really the only one that has had problems with this, or am I the only one rude enough to ask?)
I will see what I can do for it.
Once I am at it, I would really like a timer on all sensors in TPMSDoctor to show have many seconds that has passed since last update. Or something else that has the effect that I can get an idee of how well the system is working.
I have read thru this thread at last and I have put some gold nugget post links here.
Nice work.
Edit:
I just seen in post one (:-)) that there is a 16 bit CRC in the message so the learning should not get confused by collisioned messages. (Why not show ID also in TPMSDoctor? Or save all traffic in a log file? Is it not sent from pic to PC?) Still, something seems to be wrong with "learning".
Each sensor ID is stored internally to PIC E2PROM only for internal usage and is not possible to read it.
It would require a change in the PIC firmware.
(btw. I only count 12 bytes)
You are right, sorry, my bad.
Edit 2:
Since we know that we will get one transmission every 60s in normal mode we know if messages are lost. This could be used for finding best position for receiver/external antenna. A percentage calculation in TPMSDoctor maybe?
Even this is not possible, because each time the PC does a data request to the PIC, this last always returns the latest information received from the sensors, so is not possible to determine how much time has elapsed from the last RF reception.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 08-24-2008, 09:49 AM   #77
bes51659's Avatar
bes51659 is on a distinguished road
Thanks for your thorough answer! I don't know why I did not see it until now!
I did have some problems with reception that seems to be ok now. I do not know why. Maybe the sensor was dormant for some reason. It was not the learning procedure as it started to work all of a sudden without me doing anything.
I have not rerun the learning so I do not know why learning completed so fast. I definitely did not run any other TPMS sw than the config app. Do all apps share the same USB buffer? What if it received an update from a different tyre? Would it do like this when it discovers that ID is already used for a different tyre?
To bad the ID is not part of data sent from PIC to PC. It could have been helpful when "learning" for some reason pics the wrong sensor.
480x800 would be great, as well as an intelligent guess when sensor data was last updated. Like time when pressure, temp, or battery data last changed. Great help optimize receiver position. But for me, as I now have reached the point of using a skin, its no longer nessessary.
Only problem I have left is a problem I started to get when I moved the receiver from the USB in the back to the hub under the dash. I get "unknow device" and "not connected" a lot, but not always. If I disconnect and reconnect the plug it works fine. Rebooting PC or restarting TPMSDoctor is not enough.
On the same hub is only my OBDII and a cable for extra's like ipod etc. They work fine. The hub is active but the DC/DC (15W) also drives the DVD (10W max), so there should be sufficient power. I have cut 5V and GND in the USB cable from the back to the front of the car to avoid ground loops.
I have had difficult USB problems so I have looked into that a lot, and cannot see what is wrong, and I am 95% sure its not a power problem. I have 10 or more device not giving me any problems anymore. How much power does the receiver need?
A 8051 system that controls PC power etc with or without BMW IBus and is a GPS receiver with dead reckoning. mp3car thread
My car installation mp3car thread "showing off project"
bes51659 is offline   Reply With Quote
Old 08-26-2008, 10:44 AM   #78
Robby BMW's Avatar
No, but as the USB bus is basically a serial bus, if two differents apps sent two differents data requests to the device, this last will sent back two different replies that will be recived from both apps which would be "confused" by unexpected data (especially during the learning operation).
Each data paket sent from the sensors allways contain the 32 bit sensor ID, so even the PIC allways knows (after it has been successful paired) wich sensor is.
If the data paket contain an unknown ID (not paired sensor), the data are simply ignored.
The firmware inside the PIC is designed to not save any identical sensor ID, so it's impossible to pair twice the same sensor.
Due to the reason explained above, it is virtually impossible that the PIC takes the wrong sensor.
If I remember well, the receiver requires about 80 mA, so it should not be a power supply problem.
I had a similar problem, but I solved it by replacing the HUB with a new different one (D-Link USB 2.0 7-Port).
Old 08-26-2008, 03:41 PM   #79
mnwcsult's Avatar
mnwcsult is an unknown quantity at this point
I get "unknow device" on one of my computers the car computer. I have tried this device on three computers and on two them it works. I have tried thorugh direct connection and thourgh hubs.
Does the device work differently through USB 1.1 and USB 2.0 devices? My guess is ??? I would not think that it would work through multiple hubs. In my setup there are two chained hubs to the front of the car. There are direct connection at the back of the computer.
On the direct connection at the back of the computer I think those are USB 1.1.
Any ideals?
mnwcsult is offline   Reply With Quote
Old 08-26-2008, 04:44 PM   #80
bes51659's Avatar
Any ideals?
Sounds like you have the same type of problem as me. Or similar. Does it work if you connect the TPMS when the system is up and running?
Hope there is a solution to this. I have tried a number of hubs and this one I use now have not given mne any problems apart from this device. I've heard of "devcon", a way do enable and disable USB devices apone restart or reentry from hibernation. I will try that in a week or two.
Thanks for your replies Robby. My questions in this matter was regarding learning process and problems that might occur _during_ mating, so we missunderstood eachother there.
Old 08-27-2008, 11:41 AM   #81
mnwcsult's Avatar
The solution
Any ideals?
My carputer is a VoomPC II with front and back panel USB hubs. The front panel hubs are diasy chained to external Logitech premium 4 port hubs. The back panel hub is not in use (I thought).
Note: The Logitech Premiums are way cool black in color with green indicator lights showing at a glance active USB devices.
I had to go into control panel and look the power requirements of each of the hubs on the system. It turned out that my rear panel hub which would allow for a direct connection is actually "hosting" the Sierra Aircard in the nearby pcmcia slot as a USB device and it it drawing the full 500 ma.
Solution was to provide additional power to the external hubs. Once I did that the TPMS device activitated and was recognized properly by XP and the TPMS Doctor program.
Exact steps
Start Control Panel -> Device Manager -> Universal Serial Bus
You will see many entries, here you are interested in only the ones that specifically say "HUB", i.e. "Generic USB hub" or "USB root hub". Right click on first one and select properties. On the property panel you will see the "Power Tab". You will see Total amount of power available to each port on the hub. Also what is connected, power requirements of the connections, and finally number of ports still available. Repeat for each hub you have installed.
-Michael
Old 09-01-2008, 10:46 AM   #82
Robby BMW's Avatar
Oooh! Sorry, I had misrepresented your question.
During the "learnig procedure", the PIC, besides to not save any identical sensor ID, it takes into consideration only the sensors in "pressure alert mode" state, so, unless you don't deflate simultaneously two tyres, it's virtually impossible to pick the wrong sensor.
Old 09-14-2008, 11:20 AM   #83
MGD
MGD's Avatar
MGD is on a distinguished road
Robby, any chance you can update the plugin for the new RR release.
The battery indicators are not working anymore as the code changed.
Also the parking sensors need updating for the indicators.
Thanks Manny
MGD is offline   Reply With Quote
Old 09-14-2008, 01:31 PM   #84
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Fixed thread title misspelling.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 09-15-2008, 06:48 AM   #85
Robby BMW's Avatar
Thanks Manny
Fixed!
A new version (1.40) as been released in the first post of this thread.
Old 09-15-2008, 06:48 AM   #86
Robby BMW's Avatar
Old 12-16-2008, 08:05 AM   #87
boelle is an unknown quantity at this point
what the status on this? any chance of a complete kit?
EDIT: cant download from link i first post
boelle is offline   Reply With Quote
Old 12-16-2008, 05:24 PM   #88
just got hold of the software and did install pr instructions... but so far it does not show up in menu
useing newest RR with default skin
Old 12-17-2008, 12:34 PM   #89
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
I've added more download links to th the first thread.
Ride Runner RR's Myspace
guino is online now   Reply With Quote
Old 12-18-2008, 11:01 AM   #90
smithjames0 is an unknown quantity at this point
I have just installed this plugin it works great in RR but when I load the config I get an error message.
"Component 'MSCOMCTL.OCX or one of it's dependecies not correctly registered: a file is missing or invalid'
Can anyone help?
Thanks James
smithjames0 is offline   Reply With Quote
Velleman K8055 USB I/O Board Extension plugin 307SW_NLD RR Released Plugins 200 04-06-2009 07:02 AM
Use serial port with extension plugin??? guillemasco RR Plugins 5 12-04-2006 07:26 PM
Extension plugin problems festy Road Runner 2 06-23-2006 07:20 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
Extension Plugin help .... Gobby Road Runner 1 06-09-2006 11:27 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
