Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 12-18-2008, 12:12 PM   #91
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
I hate to do this but stick MSCOMCTL.OCX in the search box at the top and you will have plenty of solutions.
Enforcer is online now   Reply With Quote
Old 07-03-2009, 08:35 PM   #92
fixerofallthing's Avatar
fixerofallthing is on a distinguished road
I just received the kit to beta test and I can not get the plugin to show any data. I know it is working because I have it working in Centrafuse fine. Does the plugin need to be updated or maybe it is something I am missing. I am using the default skin (Carwings) and I added it to the menu and registered the .dll and it launches fine just does not show data. Using Vista 32-bit and latest Riderunner.
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline   Reply With Quote
Old 07-03-2009, 09:23 PM   #93
Confusion Master
Enforcer's Avatar
Have you run the config program?
Old 07-03-2009, 09:28 PM   #94
Yes and both work fine. Both TPMS Doctor and RRTMS config.exe
Old 07-04-2009, 04:44 AM   #95
Robby BMW's Avatar
Robby BMW is on a distinguished road
When you press the TMS button in the main menu (you must to add it), the TPMS skin appears?
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 07-04-2009, 06:27 AM   #96
Yes it does.
Old 07-06-2009, 11:17 AM   #97
Robby BMW's Avatar
Well, it seems that the plugin is correctly loaded.Can you post in attachment your TMS.SKIN file?
It should be useful to understand what could be the problem.
Old 07-06-2009, 11:25 AM   #98
For testing I ma using the supplied skin. No changes at all. I will post a screen shot later.
Old 07-06-2009, 12:48 PM   #99
Robby BMW's Avatar
Ok, also a screen shot could be usefull.
Old 07-06-2009, 06:50 PM   #100
Well it must have been a computer specific problem. When I installed everything in the truck RR worked fine and read the info no problem. I will be posting a review in the review section soon. Sorry to bother you. Good job! The plugin works great.
Old 07-07-2009, 10:46 AM   #101
Robby BMW's Avatar
No worries. Glad to know that now it works fine.
However, looking at your screenshot, it seems that you have not copied the "SLIDER_BATTERY" folder in the skin folder (doesn't appear the state of the battery of each sensor).
Old 07-07-2009, 11:01 AM   #102
That is because it conflicts with the one already there so I need to rename one or the other and fix the skin but it was not important for testing. Thanks for noticing.
Old 08-01-2009, 09:03 PM   #103
CannonBaller is an unknown quantity at this point
I'm actually having some issues as well.
I can read all the sensors properly with TPMS Doctor.
But no information is coming through within RR.
I am running the DFX4 skin.
And I'm using RRTMS v1.4
This is what i did to install into RR DFX4
1. I have succesfully registered the RRTMS.dll (which is in the DFX4 skin dir)
And also registered MSCOMCTL.OCX (for TPMS Doc)
2. Copied the RTMS "skin" dir(only the contents) to DFX4 main dir
3. Modify DFX's ExecTBL.ini file with the following new entries:
--Dynamic Menu Buttons--
"MyApp48","TMS"
4. Modify DFXs Menu.skin and add line
X,RRTMS
These are the results
- the TMS skin seems to load correctly. I can see all the indicators, PSI, C, Batter
- no data is distplayed only see "---" for all entries and an empty battery icon
- i tried unpluging the USB receiver to see if it would show that connection is lost, but nothing happend. Same with reconnecting
- again i tried with TPMS Doctor and all data comes up properly.
- FYI...i am not running TPMS Doc and RR at the same time, so that they dont interfere with each other.
My conclusion is that the DLL loads correctly, but does not pass data to the skin.
Any ideas? Would you have the correct setup notes for DFX4 integration.
thanks...and great work btw.
CannonBaller is offline   Reply With Quote
Old 08-03-2009, 09:13 AM   #104
Robby BMW's Avatar
It sounds like you you haven't configured correctly the sensors location through the config tool (rrtms config).
Also, the configuration tools must be in the same directory of the DLL, otherwise the configuration file (rrtms.ini) can not be read by the DLL
Old 08-03-2009, 02:16 PM   #105
Not sure what you mean by configuring the sensor location. I just used the default settings. All 4 tires have sensors 1-4 attached to them.
1-Red, 2-yellow, 3-blue, 4-green
Is there something additional that I need to do here?
This is where i have all the important files installed:
C:\Program Files\RideRunner\Skins\DigitalFX 4.0\
RRTMS Config.exe
RRTMS.dll
RRTMS.INI
The dll is also regged under this directly. (i checked the registry to confirm)
The skin seems to be picking up details from the ini file, because if i change any of the settings (eg PSI, C or F), its reflected in the skin.
This is the second PC now that i have installed it on. So definitely not isolated. The sensor data is just not coming through. But it does work in TPMS Doc.
I know there is a faq on the install. But could you possibly post a more thorough step by step. So i can compare it too.
I'm sure its a simple solution and im just missing something.
Velleman K8055 USB I/O Board Extension plugin 307SW_NLD RR Released Plugins 200 04-06-2009 07:02 AM
Use serial port with extension plugin??? guillemasco RR Plugins 5 12-04-2006 07:26 PM
Extension plugin problems festy Road Runner 2 06-23-2006 07:20 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
Extension Plugin help .... Gobby Road Runner 1 06-09-2006 11:27 AM
