08-26-2009, 11:37 AM
#121
Hi well thanks for all the help.....
But for some reason I am not able to get the LEARN process for sensor 2,4,5
1 & 3 learn procedure is complete
How do I get to learn the rest of the sensors....
Pls help me... Also the Batt SHOWS EMPTY.. ( and its a new 1 for sure )
Commell LV-677 DC 6 x 6" Mother Board
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
7" InDash Xenarc MTD - X7000 Screen
Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
Parrot MK 6000 & iPhone
Re done the carputer...Into the Glove Box !!
08-26-2009, 01:47 PM
#122
The Last Good Gremlin
I had the same kinds of problems installing my first set, too. See this post for procedures that eventually worked. My technique for reliable learning.
Hope this helps.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
08-27-2009, 04:12 AM
#123
Great work Robby, I've got my kit installed to the car and the software in RR and all works well - thanks.
I have a question about using it and can't find an answer anywhere: what conditions do I need to get the voice warning to work? Do I need to have the TMS screen displayed, or just RR running? Thanks.
08-27-2009, 10:16 AM
#124
I think you can be on any screen.
The TPMS screen will popup when there is a problem.
At which time you'll get teh voice alert.
08-27-2009, 11:16 AM
#125
Thanks CannonBaller. If that is correct, that is what I need.
08-27-2009, 12:15 PM
#126
You are correct. That is how it works!
08-27-2009, 01:27 PM
#127
Fantastic - thanks V much.
08-31-2009, 03:22 PM
#128
Hi Guys
well i am now able to see the TPMS working and its sensors are showing the correct pressure..
How ever i am not able to see the BATT strenght... The icon is there but it shows empty and also am not geting any AURAL warning as the press goes down below the pre determined value...
( but i have tried this in centrafuse and both batt and aural warning function works )
can you guys pls help me with this step..
much thanks in advance
Vicky
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
09-01-2009, 06:14 PM
#129
Robby you inbox is full Can I get a chip for both the tpms and the parking sensor
Cheers
Michael
09-03-2009, 11:48 AM
#130
Guys can you pls help me... as how do i get the Audio warning and the battery status..
For some reason i am not able to get these both.. while the sensors display the right value...
The batt shows empty....
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
09-04-2009, 01:38 PM
#131
BUMP
Can no 1 help me as to why i am not able to display the battery status ( it shows empty )
also theres no aural waring about Lo/Hi pressure...
Your help much appreciated
Vicky
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
09-05-2009, 05:52 PM
#132
Re audio,
Are you sure your speakers are working, and you have not got TPMS set to mute.
Also, have you set the messages, and they are not all blank?
Since you have no battery status also, I might suggest you uninstall and reinstall the software.
09-06-2009, 01:03 AM
#133
Quote: Originally Posted by allypally
Re audio,
Hi Thanks
Regarding the Batt Status.... It Shows EMPTY always....
And
Audio yes the speakers are working and TPMS is not Mute
BUt i guess am not able to Set the messages properly....
Could you be kind enough to show me how to put in the messages for warnings and the code to display batt staus....
( or may be you can post in your copy of TMS.SKIN so i can read that and work from there )
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
09-12-2009, 09:38 AM
#134
just wondered, how do i most easy keep settings for 2 set of tires? (winter / summer sets)
are the ID of each sensor stored in the ini? in that case i can simply write a batch to change them around
or could it be possible that the next version will support 2 set of tires and just a winter summer toggle buttom?
09-12-2009, 11:41 AM
#135
When you rotate your tires then you just tell the program where the sensors are. If you change tires completely you have to goto the complete setup.
| Thread Tools |
| Display Modes |
Linear Mode
