Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 01-27-2009, 08:42 PM   #136
moreause is an unknown quantity at this point
OK this my first tread on mp3car and i just installed RR yesterday with rrcam
i have small issue with the overlay but they were already stated
but i want to overlay some more value from obdII and other com device
would it be possible to import them ??
lets say if you just call them them data 1 to whatever ??
i'm not pro at this ...yet
moreause is offline   Reply With Quote
Old 01-28-2009, 11:55 AM   #137
tempgp's Avatar
tempgp is on a distinguished road
I might get extra line in my own app
Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
Bluetooth Cell Phone CallerID [Pre-Alpha]
Custom Button Bash Board - Add physical touchable buttons to your CarPC Project
Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
tempgp is offline   Reply With Quote
Old 02-24-2009, 05:06 AM   #138
hakweldag is an unknown quantity at this point
RRCamera funtion not working correctly.
Hello peepz,
I am realy happy with the RR software. And hope that somebody can help me.
The camera function is not starting from the userinterface. I can see in the live debug that the command is "ONCOMMANDINVALID".
When I hit the `re-executed` option the camera will start and work normaly. Record, etc it works. Also the still capture and video is transported to the right directory.
The "bug" I recieve in the Live Debug is the following one:
BYVAR;MAINBUTTON9;MyApp01<<MyApp02<<MyApp03<<MyApp 04<<MyApp05
<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyApp10<<M yA pp11<<MyApp12
<<MyApp13<<MyApp14<<MyApp15<<MyApp16<<MyApp17<<M yA pp18<<MyApp19
<<MyApp20<<MyApp21<<MyApp22<<MyApp23<<MyApp24<<M yA pp25<<MyApp26
<<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<M yA pp32
So when I see this, and "re-executed" the camera It will work.
The camera simply will not boot from the user interface.
Can someone please help me?? I realy like to go build the carputer.
hakweldag is offline   Reply With Quote
Old 02-25-2009, 05:00 AM   #139
Solved my last post. See my other topic!!
Old 04-09-2009, 03:55 AM   #140
sgtpepperaut is an unknown quantity at this point
Quote: Originally Posted by sgtpepperaut View Post
ok rrcam installed successfully and running! (love it!)
2.) i always want to record continuously so i set the filename to somethign static:
Path=C:\RRCam\
Filename=Record
Files=2
Length=20
i suppose this will override the file every time rrcam starts..however the option Files 2 confused me. Will it create "Record1" and "Record2" then always delete the later one when it loops trough the files?.... i really just want to have 2 files on my pc that basically cache the last 20 minutes of driving (so 40min max total).
thx phil
anyone can help me with this? i would love to use this software but deleting the files manually is a really a pain...
any ideas?
thx
sgtpepperaut is offline   Reply With Quote
Old 10-01-2009, 12:32 PM   #141
msperano is an unknown quantity at this point
2 Error
I am getting a error pop up when I try to close RRCAM, anyone know what this could be
This is the command I have for the button
RRCam.exe;PREPEXIT||CLOSEWINDOW;RRCam.exe||EXIT
msperano is offline   Reply With Quote
Old 10-01-2009, 12:57 PM   #142
almera's Avatar
almera is on a distinguished road
I can't help with that, but I would suggest minicam;
http://www.mp3car.com/vbulletin/soft...ml#post1345630
almera is offline   Reply With Quote
Old 10-01-2009, 02:24 PM   #143
And
And is an unknown quantity at this point
i get the following errors can anyone help me??
VideoOCX (VIDEO) - Driver can't be connected
then
Unable to use MSVC codec for saving video
THanks
Andy
And is offline   Reply With Quote
Old 10-01-2009, 02:43 PM   #144
almera's Avatar
then
THanks
Andy
Try setting
Driver=0
in config.ini
Old 10-01-2009, 03:04 PM   #145
And
its was set to 0 initial and I've tried 1 also but no change???
if I run the app on its own it seems to work? so only get the error from RR could this be directory link related??
Sorted was the path in the config file, but now I just get a clear screen? any ideas
Andy
Old 10-01-2009, 03:12 PM   #146
Did you register the dll's
regsvr32 videoOCX.ocx
regsvr32 videoOCXTools.ocx
Old 10-01-2009, 03:14 PM   #147
tempgp's Avatar
then check if VideoX dll ir VideoOCX.dll (forget which one) is located in the same folder ad Rcam. If not then go to C/windows/Sustem32/ and find DLL there and copy it back to Rcam folder
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
Canīt get DirectX to work Linde Software & Software Development 0 10-19-2007 08:35 AM
SD crashes on startup mangus580 StreetDeck 7 10-05-2007 12:14 PM
USB 2.0 issues PLEASE HELP! Kamakazie2 General Hardware Discussion 25 10-23-2006 08:25 AM
