Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 11-06-2008, 11:25 PM   #121
tempgp's Avatar
tempgp is on a distinguished road
whats CLS?
Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
Bluetooth Cell Phone CallerID [Pre-Alpha]
Custom Button Bash Board - Add physical touchable buttons to your CarPC Project
Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
tempgp is offline   Reply With Quote
Old 11-06-2008, 11:26 PM   #122
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
a class
Enforcer is offline   Reply With Quote
Old 11-06-2008, 11:30 PM   #123
tempgp's Avatar
oh ok
well i better leave it for tommorow... no good to learn new things at night
for now just add audio suppotr in the application
Old 12-12-2008, 05:28 PM   #124
acidice333 is an unknown quantity at this point
Any chance to be able to record audio and the source code? If not the code how about the code for the Com Tool?
acidice333 is offline   Reply With Quote
Old 12-13-2008, 10:23 AM   #125
tempgp's Avatar
Audio Recording is on the request list for Road CameaHD v2
as to the source code i dont release it as all our applications are commercial.
As to the comm tool if you are refering to comm port debuger then its simple play around with Visual Studio Serial Port Controll.
Old 01-04-2009, 06:04 PM   #126
kelmk's Avatar
kelmk is an unknown quantity at this point
I have a couple of questions about rrcam.
Does it support standby/resume? It doesn't by default on my setup.
How do I change the video pin to 640x480 instead of 320x240?
kelmk is offline   Reply With Quote
Old 01-04-2009, 06:12 PM   #127
tempgp's Avatar
ups was that rrcam forum =))
ummm to what I know RRCam doesnt support resumes nor pix adjasments... resume mode can be added by original developer (is he/she still around?) pix streaching not possible to add, pin config possible to add but not directly....
that what i know but i didnt bild RRcamera... so just my take
Old 01-04-2009, 08:47 PM   #128
kelmk's Avatar
Hey, I'm just trying to find something that works until Road Camera HD v2 is ready to go
I'll stick with Capture! for now. It's the only one that supports standby/resume and configurable resolution. It's just missing the overlays and errors a lot.
Old 01-04-2009, 08:49 PM   #129
tempgp's Avatar
lol I dont know what capture is =)
Old 01-04-2009, 09:57 PM   #130
silvi4000 is an unknown quantity at this point
capture is only missing the info overlays and it would be the best option
Im using RRCam now. After doing some tweaking Its working ok.
Make sure you exit RRCam before hibernation. For this I only hibernate from the RRCam screen in DigitalFX4. The exit menu tells RRCam to save the video and exit and then it goes to hibernation. In case I forget I have running hibernate trigger and will kill rrcam.exe just before hibernating but if you kill the process you lose any video that havent been saved to disk. When resuming, exiting and entering again to the RRCam screen will startup RRCam
you can change the size in the config.ini
Size=600,460
but I guess you will be limited by your web cam capabilities
silvi4000 is offline   Reply With Quote
Old 01-04-2009, 10:02 PM   #131
tempgp's Avatar
i can write sniplet to kill rrcam before hibernation =)
Old 01-07-2009, 01:28 AM   #132
kelmk's Avatar
Capture is quite good and does everything a carpc cam app should do, it's just not stable for me and missing overlays.
Size=600,460
The size value only changes the size of the window, not the actual capture size.
Old 01-20-2009, 06:19 PM   #133
sgtpepperaut is an unknown quantity at this point
ok rrcam installed successfully and running! (love it!)
however i have two problems:
1.) when it resumes from hibernation the video area is white... i need to exit rrcam and restart it to get it to work again... Any ideas? is this possibly a driver issue?
Nevermind just read the above paragraphs ...please someone create those codes snippest with simple instructions where to past cause i have no idea...lol
2.) i always want to record continuously so i set the filename to somethign static:
Path=C:\RRCam\
Filename=Record
Files=2
Length=20
i suppose this will override the file every time rrcam starts..however the option Files 2 confused me. Will it create "Record1" and "Record2" then always delete the later one when it loops trough the files?.... i really just want to have 2 files on my pc that basically cache the last 20 minutes of driving (so 40min max total).
thx phil
sgtpepperaut is offline   Reply With Quote
Old 01-20-2009, 06:20 PM   #134
Please DO!...dont really know where so start...
also include the code to restart PLEASE!
Old 01-20-2009, 06:22 PM   #135
tempgp's Avatar
I dono what u mean by that... but as to sniplet... well ok probably will have something by tommorow =)
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
Canīt get DirectX to work Linde Software & Software Development 0 10-19-2007 08:35 AM
SD crashes on startup mangus580 StreetDeck 7 10-05-2007 12:14 PM
USB 2.0 issues PLEASE HELP! Kamakazie2 General Hardware Discussion 25 10-23-2006 08:25 AM
