Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 12-23-2007, 03:25 AM   #1
inh
inh is an unknown quantity at this point
RRCam 2.0 Final
Lots of changes!
Here is a paste from the changes.txt file. THese are just changes since the 2.0 beta release:
-added minimized and normal startup options
-added minimize and maximize com messages
-Added border to make it a bit more user friendly when run outside of RoadRunner
-Added '-minimize' command line switch
-Added a setting to detect (and kill, if deisred) multiple instances of RRCam, so that only one will be running at any time
-Fixed bug so that window messages/commands no longer have to be all uppercase
-Added support to resize based on skin settings in general.ini. Note that if your skin isnt displaying at a multiple of your camera resolution, you will have grey bars on either side of the video window. IE: If your camera is 800x600, and you set your skin to display at 1024x768, there wont be any problems, but if you try 1280x800, there will be bars on either side.
-Added support for touching the video window, etc. There are two sets of settings in the config. One is for while RRCam is in normal skin mode, the other is for when it is in fullscreen mode. You can set which actions you want RRCam to perform while in either mode, when either a single click is detected, or a click and hold. BY default, a single click takes in and out of fullscreen mode, and a click and hold takes a still picture of the video and saves it.
-Added VIDEOWIDTH and VIDEOHEIGHT com messages to set the video display area of RRCam.
-RRCam now defualts to testmode when started without RoadRunner running.
-files and length in recording in config.ini
-EXIT command changedto PREPEXIT, because now it just prepares RRCam to be closed. you need to use RoadRUnners CLOSEWINDOW command to actually close the program.
-Added MOVE;X;Y command, where X and Y are the window postion for RRCam, in pixels
-Added POSITION to ini files, where it is position=x,y for startup position
There are still more things to do, but I wanted to get this released for you guys =]
Download here
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
inh is offline   Reply With Quote
Old 12-24-2007, 02:21 AM   #2
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
thanks inh
for your time and work ,will give ago sometime later , its xmas and all that.
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is offline   Reply With Quote
Old 12-24-2007, 08:18 AM   #3
pablo1970 is an unknown quantity at this point
Buffer
INH, Many thanks for this Plugin.
The overlay is exellent and is why i would prefer this plugin over Capture.
I am in the car for two hours a day, and i see alot of eejits on the road, and some things you wouldnt believe ! , What i would like to be able to do is have a recording buffer and only save a file after i have seen an incident, i have tried the settings in the ini but they dont seem to do anything as yet.
Files=2
Length=10
maybe i can achieve what i want using the idle and timer commands to record small clips and set a button to copy the file into an archive directory but thats about the limits of my skill.
thanks again
pablo1970 is offline   Reply With Quote
Old 12-25-2007, 03:42 PM   #4
virussino is an unknown quantity at this point
Hello
I have a problem with this plugin
When launching the program shows image of cinergy 600 and not my webcam
Can I fix?
virussino is offline   Reply With Quote
Old 12-26-2007, 12:42 AM   #5
inh
Files=2
Length=10
thanks again
Just press the record button whenever you see an accident, and it should record. or you could make an autoit script to copy the latest file to the archive directory whenever you press the button. then just change the command line in the config.ini for the button command to run the program.
Quote: Originally Posted by virussino View Post
Hello
Can I fix?
No idea man.. sounds like an issue with your camera settings. or is the cinergy 600 a capture card?
Old 12-26-2007, 11:17 AM   #6
Resolved..
to the windows control panel, audio devices, disabled cinergy tv capture, then I restarted windows, open rrcam and worked with camera....
I enabled again cinergy TV capture and restarted windows..
Hours everything ok
I have other problem..
I change the font written at the top, with the song listening
I see too small and black
How can I do?
Old 12-26-2007, 11:56 AM   #7
inh
How can I do?
That is something i need to fix in the skin. here it is for anyone that has already downloaded it.. just paste everything below in to the rrcam.skin file. im also going to update the zip file in the first post to include it for anyone that hasnt already installed the latest..
Code:
MEDIACAR Skin MEDIACAR Games Skin RRCam_off.bmp,RRCam_off.bmp,RRCam_on.bmp,RRCam_down.bmp /Remove the comment below to have RRCam close when you leave the skin page. By default, /it will leave RRCam running in the background when you go to another page in the skin /B,-2,525,99,78,"SENDMSG;RRCam.exe;PREPEXIT||CLOSEWINDOW;RRCam.exe||EXIT", B,-2,525,99,78,"ESC", L,215,21,567,34,255,255,255,25,"Arial","TAGTITLE", L,15,20,173,34,255,255,255,25,"Arial","TAGARTIST", B,98,526,99,78,"SENDMSG;RRCam.exe;PREPEXIT||CLOSEWINDOW;RRCam.exe||EXITMENU", /Button labels L01,617,100,160,60,255,255,255,16,"Arial:B","EXEC;SENDMSG;RRCam.exe;BUTTON1||=", I,611,67,174,23,"!RRCAMRECORD" L02,619,170,164,60,255,255,255,16,"Arial:B","EXEC;SENDMSG;RRCam.exe;BUTTON2||=", L03,616,245,169,60,255,255,255,16,"Arial:B","EXEC;SENDMSG;RRCam.exe;BUTTON3||=", L04,617,315,169,60,255,255,255,16,"Arial:B","EXEC;SENDMSG;RRCam.exe;BUTTON4||=", L05,619,390,164,60,255,255,255,16,"Arial:B","EXEC;SENDMSG;RRCam.exe;BUTTON5||=", L06,619,460,164,63,255,255,255,16,"Arial:B","EXEC;SENDMSG;RRCam.exe;BUTTON6||=", /button indicators I,613,95,175,67,"!RRCAMBUTTON1" I,613,168,175,67,"!RRCAMBUTTON2" I,614,241,172,64,"!RRCAMBUTTON3" I,614,311,176,65,"!RRCAMBUTTON4" I,614,387,175,67,"!RRCAMBUTTON5" I,613,459,175,64,"!RRCAMBUTTON6" /Button text labels L1,617,114,164,31,255,255,255,16,"Arial:B","!BUTTON1","CENTER" L2,618,186,164,30,255,255,255,16,"Arial:B","!BUTTON2","CENTER" L3,619,256,161,30,255,255,255,16,"Arial:B","!BUTTON3","CENTER" L4,620,329,164,30,255,255,255,16,"Arial:B","!BUTTON4","CENTER" L5,621,403,164,30,255,255,255,16,"Arial:B","!BUTTON5","CENTER" L6,618,474,164,30,255,255,255,16,"Arial:B","!BUTTON6","CENTER" /Audio player buttons B,198,526,99,78,"PREVTRACK", B,299,526,99,78,"PLAY", B,400,527,99,78,"NEXTTRACK", B,500,526,99,78,"VOL-", B,601,527,99,78,"VOL+", I,702,527,93,71,"MASTERMUTE" /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT A,0,75,599,449,,, END
Old 12-26-2007, 02:13 PM   #8
ok....tnx
Old 12-29-2007, 08:12 AM   #9
vicky_obee's Avatar
vicky_obee is on a distinguished road
Hi Inh thanx for the wonderful software
Well i am still having difficulty in configuring this.....
BAsically i am using DFx skin at 1024 x 786 res....
And am trying to use the in built PNG files for RR along with its buttons....
and all i could figure out is the 3 buttons
---Record, Snap shot and Mirror ( working fine )
---Overlay, Custom text and Date/time ( not able to configure )
Also the Active viewing area is not in the correct position and CHANGING the Config is not doing any change......
Can u pls help me
thanx
Commell LV-677 DC 6 x 6" Mother Board
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
7" InDash Xenarc MTD - X7000 Screen
Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
Parrot MK 6000 & iPhone
Re done the carputer...Into the Glove Box !!
vicky_obee is offline   Reply With Quote
Old 12-29-2007, 08:25 AM   #10
inh
So you tried changing the position settings in the config file and it didnt work?
Are you using the latest DFX skin, and are you trying to use the skin that comes with DFX, or the skin in the latest release of RRCam?
To set custom text, you just need to change it in the config file, and also make sure that it is set to display. Under the General section, you need to set these accordingly to get the text to display
Text1Startup=True
Text2Startup=False
Text3Startup=True
Text4Startup=False
Set them to True to get the text to display
Old 12-29-2007, 10:55 AM   #11
vicky_obee's Avatar
Yes the config file i tried to modify...from position 0,0 to 10,90 ( just trying to get it sync with the Dfx 1024 x 768 screen
and the size to 645,480...
The size changed ... but the position wont move.....
Well i am uisng the latest version of Dfx skin.... and am trying to use the skin that came with Dfx...
And regarding the custom text ... if i write it in Config.ini can it work ON/Off with the skin button ( view / hide )
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
Old 12-30-2007, 03:02 AM   #12
inh
I'll look in to it. It worked fine with my skin.. =/ Then again, when I tested with DFX< it scaled itself automatically and lined up fine.. SO i dunno..
So you're saying its scaling right, so that the video is the right size, its jsut not lining up right in the skin?
Old 12-30-2007, 12:31 PM   #13
vicky_obee's Avatar
Thats right ... its not Lining up right....
So i tried to do it via INI 0,0 to any value but no effect.....
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
Old 12-31-2007, 08:17 AM   #14
Cycfari's Avatar
Cycfari is an unknown quantity at this point
Cycfari is offline   Reply With Quote
Old 01-01-2008, 07:34 AM   #15
inh
It works fine for me using DFX 2.0...
My screen res is 1280x800, but i run RoadRunne at 1024x768 by changing the showwdith and showheight settings in the General.ini in the skins folder. Try changing those (by default it is 800x600, and let me know if it still does that, because it is working fine for me..
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
Canīt get DirectX to work Linde Software & Software Development 0 10-19-2007 08:35 AM
SD crashes on startup mangus580 StreetDeck 7 10-05-2007 12:14 PM
USB 2.0 issues PLEASE HELP! Kamakazie2 General Hardware Discussion 25 10-23-2006 08:25 AM
