Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 08-03-2008, 08:02 PM   #241
rsrblade is an unknown quantity at this point
Blue, I changed directories again to show the 2 rrmediadb that are created. Here's a pic
rsrblade is offline   Reply With Quote
Old 08-03-2008, 08:07 PM   #242
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Yes, it is working 100% correctly, there only need to be one place for the db and that is at your musicpath location. You change your music path, you change where there should be a db file.
I am confused as to why your trying to point this out to me?
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 08-03-2008, 08:34 PM   #243
Ah, perhaps I misunderstand, when rebuilding the db is it not supposed to remove the old database or at least move it to the new location? Until I delete the old file manually, I get the CheckforMP3.exe error. Again, I must be misunderstanding how the rescan works.
Old 08-03-2008, 08:37 PM   #244
If the rescan only builds a new db in the appropriate folder and leaves the original alone full intact then I have another issue to examine on my end-why is it looking at both or looking at the original database instaed of the new. humn...think I'll go play with that idea a bit.
Old 08-03-2008, 08:38 PM   #245
The Curator
Blue ZX3's Avatar
"CheckforMP3.exe" is NOT part of my plugin. Rescanning does a combination of three things: remove missing media records from db, check for updated/changed files (ie upated tags in a file), and new files that have not been imported yet all on the original db file from the origanal scan, unless you change your musicpath, then ya its going make another db file as one doesn't yet exists at the path.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 08-03-2008, 09:30 PM   #246
Blue, it appears the CheckForMP3.exe located in the 'scripts' folder was/became corrupted. I replaced the .exe with a known working.
Thanks for your help.
Old 08-04-2008, 01:26 AM   #247
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
I don't know if this was intended or not, but RM_ADD1 does not "unload" a "loaded" disc like the other commands. Granted, it appends the playlist, but the "DISC" playing does not match the playlist.
Also, when using "RM_Sel2Disk" at a file/song level in RM_MEDIA.skin, it doesn't update the the "DISC" song count label as seen in RM_ADD2DISK.skin.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 08-04-2008, 01:34 AM   #248
The Curator
Blue ZX3's Avatar
The RM_ADD has the logic that if you have a disk loaded it will add that selection to both the current PL and to the disk, otherwise just to the current PL.
Also, when using "RM_Sel2Disk" at a file/song level in RM_MEDIA.skin, it doesn't update the the "DISC" song count label as seen in RM_ADD2DISK.skin or add the song to an empty "DISC."
This one I'm not sure about but will check on...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 08-04-2008, 02:11 AM   #249
Stealth915's Avatar
Stealth915 is on a distinguished road
I figure I should post this here instead of the DFX thread. An update on my problem - I'm unable to get the database built. Originally I was getting this error while building the database:
More recently I've tried building the DB with only 1 MP3 in my music directory, but still no luck. I did notice that my ID3v1 tag and ID3v2 tag was different on the same MP3 file. When I clear one of the two, the popup box during DB building goes away. However, I'm still not getting any entries in my database after building.
After poking around the DB I got to this when going to Browse Mode > Recently Added. I still don't get anything when Browsing by Artist/Album/Genre and the DB file is blank.
The 1 file I have in my Music dir is:
RR Music Path: D:\Music\
Filename: Akon.mp3
ID3 tag (tried on both v1 and v2):
- Title: Ghetto
- Artist: Akon
- Album: Konvicted
- Year: 1998
- Genre: Other
- Comment: [left blank]
Does this plugin scan both ID3v1 and ID3v2 tags? Is there a preference for any tag? Any help would be appreciated. I've spent a better part of this weekend trying to figure this out.
I don't know if this matters, but I have "Prefer ID3v2 Tags", Show ID3 Playlist, Show ID3 Browse, and Lazy ID3 Load checked in my RRConfig.
2004 Mazda3 Carputer Worklog - Update 9/12/08: INSTALLED!
Stealth915 is offline   Reply With Quote
Old 08-04-2008, 02:29 AM   #250
Sal R.'s Avatar
Yeah, RM_ADD1 is not updating the loaded disc playlist nor it is updating the song count.
In addition, RMA_ADD1 is not adding songs at a file/song level.
I am using the beta you sent me.
Old 08-05-2008, 01:16 AM   #251
Stealth915's Avatar
Any update on this? It doesn't seem to matter what MP3 file I put in my Music directory, the builder will say it was completed but the database file will be blank.
Old 08-05-2008, 02:18 AM   #252
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
Spent the whole weekend cleaning up all my MP3s. Still have errors on the standalone builds but 95% are in database. DFX4 DB works perfectly. Seems the rebuild there goes without a hitch???? Still learning how to work with virtual playlists and virtual 10 disc changer.
Just out of curiosity, when clicking on the virtual playlist button - why does it count backwards as opposed to forward?
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 08-05-2008, 11:07 AM   #253
The Curator
Blue ZX3's Avatar
Its a previous PL history.... like hitting the back btn above.
To anyone having build/recan problems...
I am currently in the process of switching the builder over to a vb app. I am currently more than half way and so far the testing that i have been able to do looks like this will now allow me to catch all errors and deal with them. Meaning, no more builder crashes durring a build/rescan...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 08-05-2008, 11:27 AM   #254
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
Blue, when I change virtual disks in the disk changer it sets my volume to 0%.
John thinks that you have it set to mute the volume on a disk change. This is most likely specific to my sound hardware which doesn't raise the volume back after muting in RR.
Is there some need to mute on a disk change?
Machinehead is online now   Reply With Quote
Old 08-05-2008, 01:38 PM   #255
The Curator
Blue ZX3's Avatar
Actually, it saves the wave vol , set it to 0, does it thing, then sets the wav back to it's prev value..
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Is there an Alpine blue for RR? turbosx RR Skins 10 06-01-2008 04:35 AM
problems with navigation in streetdeck customaudioman StreetDeck 3 01-25-2008 01:46 PM
RR 04-08-05 .. BETA Base Plugin ... guino Road Runner 37 04-11-2005 12:39 AM
Does Any Winamp Plugin Work With Media Car ? ccsnet MediaCar 4 11-23-2003 02:39 PM
