Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 08-14-2008, 05:59 PM   #301
alex21008 is an unknown quantity at this point
Fantastic job Blue, can't wait for the updated version! Best plugin ever!! very much appreciated.
alex21008 is offline   Reply With Quote
Old 08-14-2008, 06:25 PM   #302
ccwild's Avatar
ccwild is an unknown quantity at this point
ccwild is offline   Reply With Quote
Old 08-15-2008, 02:46 AM   #303
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Update...
Builder convert is 100% done and working!!
Currrent stats using an USB HD and importing 7,628 songs
Initial build: 3:24
Rescan: 1:03
I'm now working on the RRMedia app to mirror the database format change.
This next update will have quite a few changes and additions which I will latter post as to what they are..TBC...
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 08-15-2008, 12:33 PM   #304
Stealth915's Avatar
Stealth915 is on a distinguished road
Sounds like it's coming along quite nicely! Do you have a rough estimate of when this new version will be released? I don't mean to rush you but the anticipation is killing me!
2004 Mazda3 Carputer Worklog - Update 9/12/08: INSTALLED!
Stealth915 is offline   Reply With Quote
Old 08-15-2008, 01:47 PM   #305
The Curator
Blue ZX3's Avatar
Ain't nobody rush'n me... I might have it out by the end of weekend, IDK...we'll see.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 08-15-2008, 04:10 PM   #306
x10
x10's Avatar
x10 is on a distinguished road
ok I tried searching for "blank list", "list", and "browse mode" but I have been unable to find my answer...
so here's my question...
On my laptop I use to work on roadrunner when I choose to browse with any of the types available: Song Title, Artist, Genre, etc...the playlist populates with the correct information everytime...
Now on my carpc running the same version of everything (RR, Winamp, same RRMedia Installer), after the DB is made and I choose "Browse Mode" every option, except Folders, returns a blank list. If I browse by Folders I can see everything on the list. Using any other browsing criteria, Song Title, Artist, etc, the list comes back blank....
any ideas as to why the Browse Mode works perfectly on one PC but not the other?
I'm not blaming your plugin...I'm just trying to figure out why its doing this...thanks in advance!!!
I noticed a new Smilie and I have to use it...
x10 is offline   Reply With Quote
Old 08-15-2008, 04:35 PM   #307
Stealth915's Avatar
Sounds like you're having the same database building problem as I am. Check the size of the RRMediaDB.db file in your music path. If it's around 32kB, it means it's empty and the database didn't build properly. Some people have said this could be due to invalid characters in the ID3 tags. I've tried putting a single MP3 with ID3 tags with nothing but letters and numbers (no spaces, even), and my database wouldn't build correctly. It will say the build completed successfully but nothing shows up in the library.
I've tried everything I could think of to get my DB to build and I haven't had much luck. Since you said it works fine with one computer and not another, I'm thinking it might be a hardware/driver/configuration issue. The new builder is supposed to be better than the current one, and with a possibility of it being released very soon, it might be more worthwhile to wait for it and see if it works for your carputer.
Old 08-15-2008, 04:44 PM   #308
The Curator
Blue ZX3's Avatar
X10... Some good news as to that file you sent me. Not only does the new builder not crash on it, it actually got imported into the db..
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 08-15-2008, 06:04 PM   #309
x10
x10's Avatar
aha! You are the MAN!!!
can't wait for the update....
Thanks!
Old 08-15-2008, 06:10 PM   #310
x10
x10's Avatar
damn, this is what was wrong...You'd think I would learn that my crappy mp3 library doesnt cooperate with RRMedia....haha
Old 08-20-2008, 10:57 PM   #311
The Curator
Blue ZX3's Avatar
small update...
RRMedia's Coverart ind (RM_CoverArt) works in the following modes, Artist-Albums-Songs-Search!!!
All Assuming that everything is in its correct place..
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 08-21-2008, 12:03 AM   #312
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
w00t!
Will there a cmd available to "unload" a disk? i.e. using stuff like coverflow/coverjuke to load music?
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 08-21-2008, 02:24 PM   #313
The Curator
Blue ZX3's Avatar
Updated first post with current status...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 08-22-2008, 11:25 AM   #314
The Curator
Blue ZX3's Avatar
Arrow RRMedia Ver 1.1
All fixes, changes, and additions are done!
If John is avail tonight, will have a run through with him to do any final tweaks.
Version 1.1 should then be released either sat or sun.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 08-22-2008, 11:29 AM   #315
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
if you need anyone else to run it through the gauntlet i'll be around tonight.. just watchin the cowboys game
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Sonicxtacy02 is online now   Reply With Quote
Is there an Alpine blue for RR? turbosx RR Skins 10 06-01-2008 04:35 AM
problems with navigation in streetdeck customaudioman StreetDeck 3 01-25-2008 01:46 PM
RR 04-08-05 .. BETA Base Plugin ... guino Road Runner 37 04-11-2005 12:39 AM
Does Any Winamp Plugin Work With Media Car ? ccsnet MediaCar 4 11-23-2003 02:39 PM
