Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-21-2008, 03:38 PM   #511
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Hey Blue,
Is there an indicator state like "RM_DiskLoadedX" for VPL's?
I didn't see one in the cmd readme.
If not, no biggie. I've got a work around in place. Just looking for a "cleaner" solution.
TIA!
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 10-21-2008, 04:01 PM   #512
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
No, but something that I could really easly add, it would be on only when a disk is not loaded as the playlist is either a vpl or a disk persay.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 10-21-2008, 04:21 PM   #513
Sal R.'s Avatar
Yeah, that'd be perfect.
Old 10-21-2008, 05:07 PM   #514
The Curator
Blue ZX3's Avatar
Just one ind?
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-21-2008, 05:10 PM   #515
Sal R.'s Avatar
Just one ind?
No, one for each VPL. I'm basically trying to do something similar to what I've done for the Virtual CD changer, but for the VPLs:
Code:
L00,211,389,050,020,#INFINDLBLDEF04#,"BYIND;RM_DiskLoaded1;<<=1","LEFT" L00,238,389,050,020,#INFINDLBLDEF04#,"BYIND;RM_DiskLoaded2;<<=2","CENTER" L00,299,389,050,020,#INFINDLBLDEF04#,"BYIND;RM_DiskLoaded3;<<=3","CENTER" L00,357,389,050,020,#INFINDLBLDEF04#,"BYIND;RM_DiskLoaded4;<<=4","CENTER" L00,419,389,050,020,#INFINDLBLDEF04#,"BYIND;RM_DiskLoaded5;<<=5","CENTER" L00,479,389,050,020,#INFINDLBLDEF04#,"BYIND;RM_DiskLoaded6;<<=6","CENTER" L00,533,389,050,020,#INFINDLBLDEF04#,"BYIND;RM_DiskLoaded7;<<=7","CENTER" L00,589,389,050,020,#INFINDLBLDEF04#,"BYIND;RM_DiskLoaded8;<<=8","CENTER" L00,646,389,050,020,#INFINDLBLDEF04#,"BYIND;RM_DiskLoaded9;<<=9","CENTER" L00,700,389,050,020,#INFINDLBLDEF04#,"BYIND;RM_DiskLoaded10;<<=10","RIGHT"
Old 10-22-2008, 06:52 PM   #516
Stealth915's Avatar
Stealth915 is on a distinguished road
I'm having trouble adding saved playlists to the 10-disc changer. When I add a playlist to a disc, RR loads the playlist, and the disc name is changed to the title of the playlist, but in the disc changer screen, it shows "0 songs". However, I'm able to add individual songs to disc using the browser screen.
I've tried this using both DFX 4.0 and the RRMedia Test Skin.
2004 Mazda3 Carputer Worklog - Update 9/12/08: INSTALLED!
Stealth915 is offline   Reply With Quote
Old 10-26-2008, 05:39 PM   #517
Arbies is an unknown quantity at this point
Error Message
Maybe you can help me out. WinXPFull, Winamp 5.13; RR 10/13/2008 release; DFX4. I am getting this message when trying to build my database initially.
Main
Division by zero
RMBuilder
Attaching a screen capture.
Arbies is offline   Reply With Quote
Old 10-27-2008, 12:21 PM   #518
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
@Blue, if I have a plugin which sends the command "RM_BuildDb" will that cause your plugin to reread the musicpath for new music and pick up any changes that may have been made?
Enforcer is offline   Reply With Quote
Old 10-27-2008, 12:34 PM   #519
The Curator
Blue ZX3's Avatar
Yes.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-27-2008, 01:03 PM   #520
Confusion Master
Enforcer's Avatar
Do you also have an indicator so that I tell tell if you are running or not?
Old 10-27-2008, 01:07 PM   #521
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
OohWeee, do I see plugin to plugin interactions coming?
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 10-27-2008, 01:18 PM   #522
The Curator
Blue ZX3's Avatar
Looks like a little plugin mating going on...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-27-2008, 01:20 PM   #523
The Curator
Blue ZX3's Avatar
When I release the update that will include the RRMedia ind and vers, and will also be able to be placed in the plugins folder w/o issues...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-27-2008, 02:02 PM   #524
Confusion Master
Enforcer's Avatar
Hopefully, it's so RRUpd8 can get the music it copies or deletes updated within the RRMedia Database.
(will need to find a way to get RR to do it if RRMedia is not being run. Hmmmm?)
Old 10-28-2008, 02:03 PM   #525
Stealth915's Avatar
Am I the only one with this problem?
Summary:
Using Playlist to Disc (Add or Replace) --> Disc shows "0 Songs"
Using Selected to Disc --> works as intended.
Is there an Alpine blue for RR? turbosx RR Skins 10 06-01-2008 04:35 AM
problems with navigation in streetdeck customaudioman StreetDeck 3 01-25-2008 01:46 PM
RR 04-08-05 .. BETA Base Plugin ... guino Road Runner 37 04-11-2005 12:39 AM
Does Any Winamp Plugin Work With Media Car ? ccsnet MediaCar 4 11-23-2003 02:39 PM
