Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-30-2008, 10:30 AM   #526
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Quote: Originally Posted by Stealth915 View Post
Am I the only one with this problem?
Summary:
Using Playlist to Disc (Add or Replace) --> Disc shows "0 Songs"
Using Selected to Disc --> works as intended.
I haven't experienced this, and believe me, I have tried to flush out the bugs from this plugin.
Question: Does the skin you're using have both a DL list AND a PL list?
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 10-30-2008, 01:22 PM   #527
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
That would be one thing that I'd check. Most of the exp skinners put a pl deff in every screen whether its visible or not other wise you'll run into little problems such as this.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 10-31-2008, 12:57 PM   #528
Stealth915's Avatar
Stealth915 is on a distinguished road
What is a DL list and a PL list?
I've tried this on both the RRMedia test skin provided with the plugin and DigitalFX 4.0. I get the same problem on both.
2004 Mazda3 Carputer Worklog - Update 9/12/08: INSTALLED!
Stealth915 is offline   Reply With Quote
Old 11-05-2008, 07:14 AM   #529
nasa is an unknown quantity at this point
Quote: Originally Posted by spamminator View Post
I took the quote out of that track title, and it got past it, only to fail at another track that had a quotation mark in the title. So, I think it's safe to say that it chokes on track names with quotation marks.
Was this examined any closer? I am running into similar problems with character " ' " (ie: 7' mix). This problem, which existed for the orignial version, was fixed with v1.2. Not sure what changed with v1.2.2
Of course, it is also likely I am messing something up.... If so please let me know.
nasa is offline   Reply With Quote
Old 11-14-2008, 10:14 PM   #530
EricE is on a distinguished road
I am stumped. I am trying to get Digital FX 4.0 running after installing it for the first time (never tried any other version of this skin either). I was especialy attracted to the Media browsing built in. But I am unable to get the build db option to work. When I try and build DB it fails with error "ActiveX component can't create object". It also does this if I try and run the RMBuilder.exe from the RMDatabase folder.
I have tried installing/running on two systems and they both fail in the same way.
I made sure I ran the latest Road_Runner_Setup.exe and even went and grabbed the RRMedia 1.2.2 installer and ran that. No luck. Any ideas?
Edit: I fixed this. Apparently one doesn't get ALL the files one needs from the digital FX 4.0 install or the RRMedia 1.2.2 Patch. I solved it by grabbing the RRMedia 1.2.2 Full install and running that.
EricE is offline   Reply With Quote
Old 11-14-2008, 10:30 PM   #531
The Curator
Blue ZX3's Avatar
After you get the error, look in the RMDatabase folder and see whats in the debug_builder.txt file.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-14-2008, 10:45 PM   #532
I think I solved it. See my edit to the post above this.
The scanning is happening now on my CarPC. I got it to work fine on my HomePC (test machine). I did get an error on my CarPC (said something about it couldn't find RMBuilder.exe. I said OK on that dialog then tried again. It seems to be processing now. <shrug>
Old 11-14-2008, 10:50 PM   #533
I spoke too soon. It wasn't moving so I exited to see the dialog again...saying it couldn't find the RMBuilder.exe (but it IS there).
Debug file says:
11/7/2015 7:38:18 PM: RRMedia Builder> MediaInfo communitation OK!
11/7/2015 7:39:03 PM: RRMedia Builder> File not found
Edit: more info.
It finds the music path and counts the files, then it says scanning...and then 200 files (...Checking file list) into my 2022 it fails with that error message. Window title is "Main" and the message is "File not found RMBuilder" The only button is OK.
BTW, before that last message I tried uninstalling then installing, then rebooting.
I thought it might be related to the date being wrong. The date was being set incorrectly by the GPS. I fixed that but that didnt fix the RMBuild error.
Old 11-15-2008, 10:31 AM   #534
Quick update to my problem.
On the theory that the problem was related to some music file I had, I pointed winamp and RR at a directory with only one album in it. I was then able to build the DB just fine. So now I just have to sift through all my media and try and determine which file is causing the problem.
Edit: I was able to solve my problem by finding all files with " ' " in them and removing the single quote from the file name and the track title.
Old 11-19-2008, 01:11 AM   #535
maxthebuilder is an unknown quantity at this point
Hi Blue,
I think something is not right with the unicode support in your plugin (which is great otherwise!).
I have a lot of titles tagged with cyrillics (russian).
They are shown correctly in most of the pages of most of the the skins (including your demo).
Your demo skin uses unicode fonts throughout.
Just 1 page - RM_Media.skin (one of the essential ones..) does not show the unicode correctly.
Half-a$$ed solution - replace unicode fornt with non-unicode Win98 style font with Russian codepage 1251.
Please see below:
RM_Media.skin (bad. Arial font used)
Audio_Playlists.skin (good. Arial font used)
Audio_Player.skin (good. Arial font used)
RM_Media.skin - FIXED (good. non unicode font used)
Would it be possible to fix this? To fully support unicode?
Thanks!
--max
maxthebuilder is offline   Reply With Quote
Old 12-01-2008, 11:34 AM   #536
Sal R.'s Avatar
Database bug that was discovered after using EL CAMINO's MP3 Tag editor:
i.e.
Albums before tag edit:
Splinter
splinter
I use EL CAMINO's MP3 tag editor to change "splinter" to "Splinter" and rescan database afterwards.
Albums rescan after tag edit:
Splinter
splinter
I delete the database file in $musicpath$ and re-build database.
Albums after delete and rebuild dbase after tag edit:
Splinter
I've confirmed this with the Artist & Album list display (RM_Artist & RM_Album). Haven't tried Genre.
Old 12-02-2008, 10:40 PM   #537
fatrat's Avatar
fatrat is an unknown quantity at this point
thanx for all the hard work. got one problem. when i installed the new skin, mt music would play until i selected browse. then it asked for me to build the music database, since then i can't listen to any of my music or will it build the database, any suggestion.
fatrat is offline   Reply With Quote
Old 12-10-2008, 08:22 PM   #538
Once again I am stumped on this.
The issue is that the database builds but I do not get tagging info for my Flac files in my skin (Using Digital FX skin). I got winamp reading the flac tags fine. I am not sure the skin pulls the tags from the DB or from winamp. All I know is that winamp has the tag info but my skin doesn't. I don't see any errors when I build the RRMedia DB. It seems to build fine.
Any help would be appreciated.
Thanks.
Old 12-11-2008, 12:27 AM   #539
The Curator
Blue ZX3's Avatar
Try putting a copy of the "MediaInfo.dll" from the "Road Runner\RMDatabase\Support Files" folder in the RoadRunner folder and see if then your taginfo shows up. If there is already one in your roadrunner folder, just replace it as the one that comes with this plugin is newer that the one the might come with RR installer. RR does not nativly support non mp3/wma formats, but putting that file in RR dir will allow rr to read all kinds of different tag formats. I have brought this up to mitch and he will be including it with the next update installer..
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 12-11-2008, 12:33 AM   #540
The Curator
Blue ZX3's Avatar
And as far as this plugin is concerned....I am making my way back to continue working on this, just trying to finish up some of the other projects as once i start working on this again it will be the only thing i will be working on as it is a type project that isn't easy to just jump in and out quickly.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Is there an Alpine blue for RR? turbosx RR Skins 10 06-01-2008 04:35 AM
problems with navigation in streetdeck customaudioman StreetDeck 3 01-25-2008 01:46 PM
RR 04-08-05 .. BETA Base Plugin ... guino Road Runner 37 04-11-2005 12:39 AM
Does Any Winamp Plugin Work With Media Car ? ccsnet MediaCar 4 11-23-2003 02:39 PM
