Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 05-07-2009, 01:30 PM   #616
navputer's Avatar
navputer is an unknown quantity at this point
Quote: Originally Posted by Dougw133 View Post
Happens to me too...Although I can't make discs right now. Like i said above, it always worked fine for me but with the latest RR and RR Media together the discs are only named but contain no songs..Ideas?
I updated to latest RRMedia (already had latest RR), wanted to add some new songs so I did a Rescan. All of my songs were removed instead of adding the new ones.
If I remember correctly, I renamed RRMmediaDB.ini and restarted RR. It reloaded my library and all was fine except the volume issue mentioned.
I am thinking about uninstalling and reinstalling with the previous version to see but I can wait until the next update.
Gee
navputer is offline   Reply With Quote
Old 05-07-2009, 01:36 PM   #617
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Renaming that file will simply make it recreate a new fresh one using all the defaults, would be the same as deleting it.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 05-08-2009, 09:32 PM   #618
Dougw133 is an unknown quantity at this point
Renaming or deleting my database file doesn't do anything.
Dougw133 is offline   Reply With Quote
Old 05-15-2009, 11:49 PM   #619
Jebus's Avatar
Jebus is an unknown quantity at this point
Newest RR, Is RMMedia Broken?
ONBTNPRESS
Load;Audio_Browser.skin
ONSCREENCHANGE
ONBTNPRESS
BYVAR;BROWSINGMODE;BROWSEMODE0<<BROWSEMODE1
RR_Media
load;RM_Media.skin
ONSCREENCHANGE
SENDMSG;MediaDB_plugin;View
RM_CheckList
Command Not Executed: RM_CheckList
Nothing will load in RM_Media.skin????
SerialSwitch Version 5.0
Major Rewrite
RRVoiceControl Version 1.1.0.83 BETA
RRVCConfig Version 1.0.0.44 BETA
Jebus is offline   Reply With Quote
Old 05-16-2009, 01:01 AM   #620
The Curator
Blue ZX3's Avatar
Is the RRMedia icon in your tray? Do you have the RoadRunner.exe running? The current v1.2.2 looks for the old exe name(is fixed for next one) so if the old exe is not running then it exited soon after it was started due to thinking that RR wasn't running.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 05-16-2009, 03:48 AM   #621
Jebus's Avatar
Hmmm...
Major Rewrite
Old 05-16-2009, 01:08 PM   #622
ksgoh88 is an unknown quantity at this point
I have that exact same problem. Also, nothing shows up under the plugin manager in DFX 4.
ksgoh88 is offline   Reply With Quote
Old 05-18-2009, 12:28 PM   #623
EricE is on a distinguished road
Quote: Originally Posted by EricE View Post
I am getting an error when I try and build the media db.
5/4/2009 12:25:26 PM: RRMedia Builder> MediaInfo communitation OK!
5/4/2009 12:25:32 PM: RRMedia Builder> no such table: Audio
Then a dialog pops up that says something about no such volume table. I looked in the voltable.ini and there is nothing but comments but I think that is the default anyway. Whats going on here?
Please help. I have spent close to 20 hrs trying to debug an error that I get on startup and I have finally tracked it down to the media db plugin.
Edit: I am on the latest version 1.2.2 and I just reinstalled to make sure everything was fine. Still getting error.
I was able to fix this by deleting the media.db and backup... The media.db is not easy to find, one has to look in your root music path.
EricE is offline   Reply With Quote
Old 05-18-2009, 04:27 PM   #624
The Curator
Blue ZX3's Avatar
Quote: Originally Posted by Jebus View Post
Hmmm...
This is related to the 5/1/09 release, the added img list support and incorrect skin files with an incorrect custom list definition.
My DT PSU crapped out on sunday , so momentarly can't exactly get to said files that I fixed. I'll see what I can do have John post a Fixed zip of all the DFX screens that contain a custom list.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 05-18-2009, 09:48 PM   #625
Jebus's Avatar
Just do this in Any skin that has Ilist BEFORE list definitions:
SC,55,140,381,373,#DFX1R#,#DFX1G#,#DFX1B#,255,128, 0,255,255,255,0,0,0,,20,"Arial"
IL,CL,transparent.bmp,sel.bmp,end.bmp,2,50,80
Flip em so the Ilist is after....
And it all works again. Something IN the last RR release?
...JJG
Major Rewrite
Old 05-18-2009, 10:38 PM   #626
Raw Wave
mitchjs is on a distinguished road
NO, Jebus, just a illegal skin command there...
the SC definition is bad... the 255 after #DFX1b# should be a 0
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 05-19-2009, 12:30 AM   #627
The Curator
Blue ZX3's Avatar
FYI...
No PSU yet, but....
John is/has posted in the #2 post in the DFX thread a zip of all the screens that have a custom list defined with all the correct parameters. So now works with all RR versions again...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 05-27-2009, 09:47 AM   #628
taguy83's Avatar
taguy83 is an unknown quantity at this point
Virtual Disk Problem
I have read this entire thread looking for an answer, but couldnt seem to find one. I am using v. 1.2.2 and DFX 4.0, my database works wonderful, never any errors, the only problem I am having is I will open RR, and assign names to all my Virtual Disks, and then add all the songs I want to each one. Then I will push the backup button and it says it backs up the disks and everything works fine. However when I reboot the machine, I go back and open RR again and all of my Virtual Disks go back to default, no names, no songs, I push restore Disk, and it restores nothing. Any ideas? Thanks!
1995 Pontiac Trans Am
AMD X2 Dual Core, 4GB Ram, 500GB Hard Drive, Lilliput 629GL, BU353 GPS w/Iguidance, Opus 360 Psu
Parts - 100%
Software - 70%
Installation - 30%
taguy83 is offline   Reply With Quote
Old 05-27-2009, 11:35 AM   #629
The Curator
Blue ZX3's Avatar
After you back them up, look in your music path for a RMDisksbackup._ file. If its there(should be), open in notepad and see if it has disk names/tracks.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 05-27-2009, 12:43 PM   #630
taguy83's Avatar
Thanks Blue, I will check that later when I am home, so if it does have the disk names and tracks then it should be ok?
Parts - 100%
Software - 70%
Installation - 30%
Is there an Alpine blue for RR? turbosx RR Skins 10 06-01-2008 04:35 AM
problems with navigation in streetdeck customaudioman StreetDeck 3 01-25-2008 01:46 PM
RR 04-08-05 .. BETA Base Plugin ... guino Road Runner 37 04-11-2005 12:39 AM
Does Any Winamp Plugin Work With Media Car ? ccsnet MediaCar 4 11-23-2003 02:39 PM
