Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 08-13-2009, 08:10 PM   #706
NOTORIOUS_VR is an unknown quantity at this point
Alright so I finally got around to checking to see if the instructions and files you've provided above work, and they don't
the DBBuilder will still crash if I move known bad MP3's back into my music folder even with the modifications and it will not produce a debug file. It actually doesn't produce a debug file even if I remove the known bad files and let it complete successfully.
thanks
-Sascha
NOTORIOUS_VR is offline   Reply With Quote
Old 09-04-2009, 11:07 AM   #707
Bump
Old 09-29-2009, 04:35 PM   #708
Dougw133 is an unknown quantity at this point
After hours and hours of pretty much manually tagging my collection I am still having a problem with RR media and RR picking up tags. When I organize my databse to browse by "Artist" I still get the "Unknown" folder with about 200 songs. I have gone back and tagged, erased, retagged...I am using the same software to tag these files however RR Media will not read the tags. Some are WMA, and some are FLAC, but most are MP3. I have many FLAC files that RR Media reads and lists fine but I dont understand what could be going on here.
Dougw133 is offline   Reply With Quote
Old 09-29-2009, 04:45 PM   #709
spamminator is an unknown quantity at this point
Are you using 2.3 or 2.4 ID3 tags? I think I've had issues when using 2.4.
spamminator is offline   Reply With Quote
Old 09-29-2009, 05:53 PM   #710
Hmm...Don't know to be honest. I have tagged them all with the same software. I'll have to check
Old 09-29-2009, 10:47 PM   #711
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
This is some good intel (not the proc kind ) And to further the details even more... what SW are some using? I have Tag & Rename v3.4 that supports ID3v1-2.4 but only writes v2.3 which I'm assuming is the NON unicode one that all players old & new can read. And might be the reason that some are still having problems even though they do tag the media
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 09-29-2009, 11:16 PM   #712
Quote: Originally Posted by Blue ZX3 View Post
This is some good intel (not the proc kind ) And to further the details even more... what SW are some using? I have Tag & Rename v3.4 that supports ID3v1-2.4 but only writes v2.3 which I'm assuming is the NON unicode one that all players old & new can read. And is the reason that some are still having problems even though they do tag the media
I am using the same version of tag and rename blue. I thought I deselected the option for unicode as I have read it can cause issues.
Old 10-07-2009, 04:43 PM   #713
DJCannonball is an unknown quantity at this point
i'm new to RMdb plugin. first i want to thank blue for his effort done so far.
i also have some issue building the database. it stops at 33%.
when i restart riderunner and clicked rescan, it picks-up from 32% and stops again at 33%.
the rmbuilder returns an error: unrecognized token: "" Lite.X.LiteStatement.1
i isolated the folder with the bad mp3s and renamed it with tag & Rename to 2.3 but it still doesn't work.
will the new RM 1.3 resolve this?
DJCannonball is offline   Reply With Quote
Old 10-08-2009, 10:46 AM   #714
navputer's Avatar
navputer is an unknown quantity at this point
Support sort by Track Number?
Blue,
Will the new version have the option to sort by Track Number?
In Playlist (Sort List shows...)
Title Alphabetical
Filename Alphabetical
Reverse Order
Randomize
Thanks...
Gee
navputer is offline   Reply With Quote
Old 10-08-2009, 11:25 AM   #715
The Curator
Blue ZX3's Avatar
RRMedia supports By Track when it creates the playlist to play. Those opts are using WA directly to sort the list, which doesn't have that. I don't know why either....
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-08-2009, 11:36 AM   #716
The Curator
Blue ZX3's Avatar
It might, do you have any quotes ->"<- in any of those tags?
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-08-2009, 03:08 PM   #717
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Maybe a simple $SongTitle = StringReplace($SongTitle,Chr(34),"") would do the trick in the builder code where the tag is initially read? This would kill any potential errors, if they exist or not, more just "Being on the safe side" so to speak.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 10-11-2009, 10:13 PM   #718
emkman is an unknown quantity at this point
I get a similar but different error on my song import at 99% complete. I am using DFX 4 with RR media upgraded to 1.22 using the patch exe. The error is
Quote:
near ",": syntax error LiteX.LiteStatement.1
Can I figure out what song is the problem if any, or is this a syntax error in the RRMedia code?
emkman is offline   Reply With Quote
Old 10-12-2009, 04:08 AM   #719
The Curator
Blue ZX3's Avatar
E..err both sorta
It probably a coma(s) in a tag somewhere causing the issue. Seeing that it got 99% it must be a song that is in on of the last folders(alpha wise) in your music path.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-26-2009, 09:14 PM   #720
RipplingHurst's Avatar
RipplingHurst will become famous soon enough
I am eagerly awaiting v.1.3; I have too many songs to test as it is right now.
I actually think this should be part of the standard RR code! Media management, playlist creation, etc. should be in every skin. (My favorite one, Carwings, does not have it, sadly).
I'm sad to hear about unicode issues, though. How can they be a problem? It's just a tag? ().
Hope they can be solved, I have a lot of music with Unicode tags.
Worklog - 07 Infiniti Fx35 Carputer
Worklog – 06 Infiniti M35 Carputer (sold!)
RipplingHurst is offline   Reply With Quote
Is there an Alpine blue for RR? turbosx RR Skins 10 06-01-2008 04:35 AM
problems with navigation in streetdeck customaudioman StreetDeck 3 01-25-2008 01:46 PM
RR 04-08-05 .. BETA Base Plugin ... guino Road Runner 37 04-11-2005 12:39 AM
Does Any Winamp Plugin Work With Media Car ? ccsnet MediaCar 4 11-23-2003 02:39 PM
