Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-24-2009, 01:12 AM   #271
sgtpepperaut is an unknown quantity at this point
hm... my unit broke after only 20 minutes of use!
center chip gets really hot and ouputs 1-12 always stay on. cant connect via usb either
tried both 12v and usb power supply!
ohh well hope the fusion brain guys will help me to fix it...!
sgtpepperaut is offline   Reply With Quote
Old 10-24-2009, 03:23 AM   #272
lithium398's Avatar
lithium398 is on a distinguished road
Exclamation
Sonic, i'd like to thank you for providing us with an add-on for the fusion brain... it's great! I'm still looking for the add-on that the fusion creators made..
ISSUE: I'm trying to control my windows and i've come across something very annoying that I haven't been able to figure out yet. When I hit for example "output4" which is for Driver's Window Down, it will SOMETIMES keep that output hot even after I release the button, and it stays this way until I unplug the fusionbrain. When I try to time one of the buttons to say roll down the driver's window (output4) for 6 seconds it works perfect until I try to roll the window back up... I hear the relay click off and the status light turns off on the board, I then hit output5 which rolls the window up, and half-way through, output4 gets hot again and the two relays fight over the window motor. When I release the button for output5 then the window rolls back down because output4 is hot, and stays this way until I un/replug the board.
I hope that's not too overcomplicated of a scenario/question, but there's something going on that's reactivating the timed button, I can't seem to figure that one out.
lithium398 is offline   Reply With Quote
Old 11-08-2009, 09:25 PM   #273
cambre is on a distinguished road
Linking outputs
This might be more of a skinning question but is it possible to link multiple outputs to a single button? I'm trying to use BYIND, for example, instead of TOGGLE:
B,10,10,100,100,"BYIND;DIGITAL0STATUS;DIGITALOUT0; HOLD<<DIGITALOUT0;RELEASE"
This seems to work.
B,10,10,100,100,"BYIND;DIGITAL0STATUS;DIGITALOUT0; HOLD<<DIGITALOUT0;RELEASE||DIGITALOUT1;RELEASE"
This doesn't seem to work.
I think I have to do it this way because I want DIGITALOUT1 to turn off when DIGITALOUT0 turns off but I don't want DIGITALOUT1 to turn on when DIGITALOUT0 turns on.
Should this work? If not, is there a better way? Thanks.
cambre is offline   Reply With Quote
Old 11-09-2009, 11:25 AM   #274
MGD
MGD's Avatar
MGD is on a distinguished road
BYIND is not an event, it is a command. You need to put the BYIND line in the exectbl.ini file from the skin and create a button for that command.
Exectbl.ini
"SWITCHAUDIO","BYIND;DIGITAL0STATUS;HOLD<<RELE ASE"
Button command
B,10,10,100,100,"SWITCHAUDIO"
MGD is offline   Reply With Quote
Old 11-09-2009, 07:54 PM   #275
ACCLR8N is an unknown quantity at this point
Where's RunMe1st.cmd?
I downloaded RRFusion from the first page and I'm not seeing the RunMe1st in the folder when I uncompress it. What blatantly obvious step am I missing?
ACCLR8N is offline   Reply With Quote
Old 11-10-2009, 09:41 AM   #276
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
hmm should be there ... perhaps an anti-virus blocked it? In Any event, you can make your own
-Create a new txt file in the RRFusion folder
-Open the file and put the following in it:
Code:
regasm RRFusion.dll /codebase pause
-save the file
-rename to runMe1st.cmd. Make sure the actual extension is .cmd... NOT .cmd.txt
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 11-12-2009, 11:08 PM   #277
hmm my indicators 12-16 dont work
anyone has the same problems or a solution>?
Old 11-13-2009, 05:28 AM   #278
Batmaninls is an unknown quantity at this point
Did you short it out by chance...
Batmaninls
www.evorbust.com
Batmaninls is offline   Reply With Quote
Old 11-13-2009, 06:01 AM   #279
no no board works fine... buttons work fine. the indiciators in the skin dont change....all of them work but 12-15 (or 16 whatever designation you want to go by).. i assume this is a rrfusion problem...? these were the outputs the V3 port didnt have if i remember correctly...
Old 11-13-2009, 08:55 AM   #280
Terminal flasher
i'll check it today.. very possible somethings wrong in the code considering i dont own a v4
03 Acura RSX Coupe
Old 11-13-2009, 05:04 PM   #281
sweet. btw awesome plugin....
im a poor student so i cant donate but i do have access to a vinyl printer.... send me an file (preferably a vector image .ai) and i can print you a nice customized sticker... car logo or whatever you want postage is on me and i have black, white, red, blue for colors. i can print up to 36 inches wide....
Old 11-15-2009, 12:18 PM   #282
Terminal flasher
thanks for that and i appreciate the offer. I'll actually consider it . My wife uses vinyl stickers for scrapbooks n such.
I think i figured the issue out on the indicators. i will upload a new .dll tomorrow.
03 Acura RSX Coupe
Old 11-15-2009, 07:21 PM   #283
i switched the functions where i don't need indicators (momentary windows switches to the 12-16 ports ...and all works fine
offer still stands of course...
also hooked up my voltage divider today so that i can read out cars battery voltage. Next step is to "program" some kind of logic that will star the car once battery reaches less than 11.5volts and shuts it down 10 minutes later.
Old 11-15-2009, 11:05 PM   #284
ok ran already into my first problem. how can i trigger commands once a analog input drops or exceeds a certain value>?
from treshhold.ini
Analog0 = RAW;480;<;CRITICAL BATTERY VOLTAGE
i dont see how i could execute commands here...but maybe someone has an idea...\
Old 11-16-2009, 09:28 AM   #285
Terminal flasher
from treshhold.ini
whenever a threshold is crossed the command RRFUSION_ALERT# will run.. where # is the port number. In your EXECTBL.ini, you can set RRFUSION_ALERT# to run whatever you want it to run
"RRFUSION_ALERT#","YOURCOMMANDHERE"
BTW, what type of buttons are the buttons that you're having indicator issues with? Toggle, Momentary, or the Timer based buttons.
03 Acura RSX Coupe
*NEW* USB Input/Output Board -- Fusion Brain 2k1Toaster Fusion Brain 1122 11-07-2009 12:21 AM
Integrate fusion brain commands into road runner buttons scotty562 FB Software 15 09-22-2008 09:02 AM
Noob has some biginner questions about the Fusion Brain phreaknes Fusion Brain 14 04-29-2008 03:57 AM
pc reboot on sd startup duanes7 StreetDeck 3 12-14-2007 09:55 AM
Skin Direction, Help.. Fusion Brain Integration Also. Ryann RR Skins 5 10-22-2007 09:40 PM
