Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 09-13-2008, 10:20 PM   #31
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
Quote: Originally Posted by EL CAMINO View Post
ohhhh, i see now, that means we might have to read those values from an ini like before, or from skin.ini, what you think is better? i'll vote for skin.ini.
Skin.ini works for me cause I run three different primary skins and that way I can have it sized exactly for each since they're not the same.
OBTW, I'm working on an RRcode section for the EXECtbl.ini that will automatically switch TRACKNAME and AlbumART in the menuXXX.skins for this plugin, I am stumped by one issue right now that has to do with how you stop the audio when starting the uTube playing. It works fine if RRTube is run from audio, but if its run from FM, the FM isn't muted. Have you considered using the mute command instead - that should work with all audio sources.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 09-16-2008, 04:11 AM   #32
brandensin is an unknown quantity at this point
El, when searched, i get -1, subscript used with nn-array variable... Not all the time but almost half the time... Any clue?
brandensin is offline   Reply With Quote
Old 09-16-2008, 09:01 AM   #33
El, how about a button for list of files you saved/downloaded. I understand you can access them from video, but would be nice to play them inside rrtube skin...
Old 09-16-2008, 12:59 PM   #34
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
can you tell me what was that search that give you that error?
EL CAMINO is offline   Reply With Quote
Old 09-16-2008, 02:01 PM   #35
EL CAMINO's Avatar
try this version, and let me know how it goes. as for the radio issue, i'll see what i can do.
Old 09-16-2008, 02:02 PM   #36
EL CAMINO's Avatar
yes why not.
Old 09-16-2008, 02:31 PM   #37
"mariah carey" or "mariah" Not sure if its search word related.. I think i got some results using the same words.. Just don't seem to work consistently
Old 09-19-2008, 11:39 AM   #38
darth sidious lite
Fiberoptic's Avatar
Fiberoptic will become famous soon enoughFiberoptic will become famous soon enough
Was any of the stuff over at Open Pandora helpful in writing your plugin? http://openpandora.googlepages.com/
I love Pandora and use it in my car all the time. I actually use the open pandora window right now because it is so simple.
Fiberoptic is offline   Reply With Quote
Old 09-19-2008, 08:44 PM   #39
EL CAMINO's Avatar
i did a pandora plugin as well some time ago, it is included in my dead skin(polaris) for RRtube i did some research in youtube's api and thanks to pandoras plugin legacy, it was fairly easy to put this together, i was planning to use a flash based controller, but the way RR handles flash, might be useless in most CarPc. so i went this route, thanks for the link i will take a look and see if i can ge something out of it.
Old 10-03-2008, 09:48 AM   #40
i found this, "E.m. Youtube Video Tool" It's working awsome so far.. multiple download and very fast... I've downloaded a tons of music video last 30 min...
Old 10-03-2008, 11:16 AM   #41
EL CAMINO's Avatar
cool!!!, that means i can stop working in your requests!!!
Old 10-03-2008, 12:35 PM   #42
yes and no. it's a great tool.. but it's only free for 14 dayz... So, u got 14 days EC...
Old 11-04-2008, 01:34 PM   #43
navputer's Avatar
navputer is an unknown quantity at this point
I am not sure why this does not work....
I can play .flv files in Media Player Classic fine that I have downloaded from the plugin in RR but the player will not show in the skin. I have added .flv to the video types in rr.ini. (put in alphabetical order; my test PC has it at the end - does it make a difference?). Should I check the option to use "built in player" as well?
The other thing is that I can get this to work on my test PC so I've seen it work but not on my carpc
What else should I check?
Gee
navputer is offline   Reply With Quote
Old 11-04-2008, 10:19 PM   #44
EL CAMINO's Avatar
so the plugin works, and the problem is playing flv videos, right? make sure to not have any corrupted files in your downloaded videos folder.
Old 11-05-2008, 12:14 PM   #45
navputer's Avatar
Right...I will check the download folder.
Gee
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
