08-14-2009, 03:27 AM
#106
Super Moderator
Thanks for the update! I now have my album covers back
08-14-2009, 03:42 AM
#107
The Last Good Gremlin
Yeah, but I cant find YT_ART anywhere. Isn't it supposed to be in the plugin's dir?
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
08-14-2009, 02:03 PM
#108
following the rules from RR coding Team, i'm starting to use the recommended paths for saving, so i use.
C:\Documents and Settings\Administrator\My Documents\RideRunner\Plugins\YouTube
08-18-2009, 10:06 AM
#109
skin not work in dfx4
Hi ,
i test the last RRtubeEx version (without .exe) in my dfx4 skin
and if i do a search the skin answer me that .
Somebody has a youtube.skin file for dfx4 please?
08-20-2009, 01:03 PM
#110
Stuck
Hi guys, this would probably be my first post , I’ve been trying to get this to work for me but cant seem to figure out where i am going wrong. To start off, I’m really new to this so will definitely ask stupid questions  . I've managed to get the youtube screen to load on DFX 4.0 but can’t seem to get further than that. When I search, it shows "Searching..." but nothing happens. When I hit play (just to check cuz i can’t search anything), the player opens up not embedded but as a separate window.
Any clue where I'm going wrong?
Also, it would be great if someone did a small installation write up for "geniuses" like me
Thanks for all the help.
08-20-2009, 03:16 PM
#111
you can download the latest version and follow the instructions, start with the readme.txt file. i can see you are using the AutoIt version(Old Version), or, you can wait for the next DFX release, which is coming with this plugin fully integrated.
08-20-2009, 03:18 PM
#112
Quote: Originally Posted by pierrotm777
Hi ,
like the error screen says, be sure to have internet access, DFX update is coming, if you want to wait...
08-21-2009, 01:27 AM
#113
Thanks El Camino for the reply, i'll wait for the new DFX release. I did do everything exactly as described in the readme, might have left out something, will redo again.
Thanks again.
08-21-2009, 01:59 AM
#114
I just realized an interesting effect: your plugin has a jpeg called def.jpg. For some reason, with the jul and aug RideRunner executables, this jpeg has become the default art jpeg for everything - audio, radio, video, etc. How did that happen?
Luckily, as soon as RR finds the art associated with the playing audio/video source it switched to te right one but this one is lurking just behind it. Very interesting.
08-21-2009, 03:26 AM
#115
The revision (July) that is in my car does this with my Nav startup screen that is a jpeg. It usually happens when I exit the audio_player skin and come back into it after running navigation. If I don't run nav it is blank until I change a song and then it loads the correct album jpeg again. My skin is an early version of my nGen skin so I figured I would see if it does it once the skin is complete.
2006 Mustang with indash CarPC
| Parts list | | | | D945GCLF2 | 2GB RAM | 20GB HDD | | Opus 120W PSU | Lilliput 8" | Directed HD | | RideRunner | nLite XP | iGO8 |
Reason: checked my rev
09-14-2009, 05:53 AM
#116
I just got around to wringing out the latest release and I can't download the videos. I get the following error from Filecop:
Code:
Run-time error '-2147024890 (80070006)':
System Error &H80070006 (-2147024890). The handle is invalid.
Anyone know how I can fix this?
09-15-2009, 09:55 AM
#117
error
I get the following error on search, any1 got a workaround?
09-20-2009, 03:43 AM
#118
Super Moderator
What are the commands again to search YT for the currently playing track? Its nowhere in this thread, or in the readme file. It seems to be totally undocumented. I think it is something you msg'd me about, and I forgot to write down  I used the skin tool to test the commands back when you told em to me, and they worked perfectly.
09-20-2009, 11:09 AM
#119
look in add to ExecTBL,
Code:
/,a way to use current track to search videos by artist and title.
"TRACKToYT","SETVARBYCODE;YT1;TagArtist||SETVARBYCODE;YT2;TagTitle||Youtube||YT_SEARCH;$YT1$ $YT2$"
09-20-2009, 03:02 PM
#120
Super Moderator
Aha! Thank you! that should do the trick!
| Thread Tools |
| Display Modes |
Linear Mode
