Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 07-08-2008, 04:15 PM   #16
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
I'll have to have a look when I am at home, I don't have a camera here at work
Enforcer is online now   Reply With Quote
Old 07-08-2008, 07:13 PM   #17
Confusion Master
Enforcer's Avatar
The skin is called pdc.skin if not it won't work.
Also (I think) you need to load the skin with the PDC command and not load;pdc.skin
Old 07-09-2008, 02:23 AM   #18
Robby BMW's Avatar
Robby BMW is on a distinguished road
Normally the screen is automatically loaded when you engage reverse gear, however I added also the command "PDC" to test the plugin, so, as Enforcer said, you need to load the skin with the this command and not load;pdc.skin, otherwise the cameara will not be activated.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 07-17-2008, 01:50 PM   #19
MGD
MGD's Avatar
MGD is on a distinguished road
Sensors installed
Well, I've got my sensors painted and installed. Now I need the stuff to make it work.
Robby, I will send you an e-mail.
MGD is offline   Reply With Quote
Old 07-19-2008, 10:04 AM   #21
Robby BMW's Avatar
Nice installation, now you need only a backup camera to enjoy the plugin
Old 07-19-2008, 10:46 AM   #22
MGD
MGD's Avatar
Ha, I have the camera alright, will be installed this weekend.
All I need is the board and the PIC.
Old 07-20-2008, 05:40 PM   #23
fatmcgav is on a distinguished road
looks great Robby,
Quick q for you though - how'd you get RR to automatically switch to the plugin when you engage reverse?
Cheers
Gavin
fatmcgav is offline   Reply With Quote
Old 07-20-2008, 05:54 PM   #24
_Dejan_'s Avatar
_Dejan_ is an unknown quantity at this point
Quote: Originally Posted by fatmcgav View Post
looks great Robby,
Cheers
Gavin
USB unit send to plugin signal that you are put in R(Reverse) gear...
_Dejan_ is offline   Reply With Quote
Old 07-20-2008, 06:02 PM   #25
Ok, so the camera gets wired into the reversing signal, and then when it activates it triggers road-runner???
Gav
Old 07-20-2008, 06:51 PM   #26
Confusion Master
Enforcer's Avatar
The camera is secondary, it is the reverse sensor controller that signals the RRPDC plugin.
Old 07-23-2008, 08:30 AM   #27
Robby BMW's Avatar
Added Greek language in the config tool
Old 07-24-2008, 05:53 PM   #28
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
This is all greek to me anyway....
ThunderStick is offline   Reply With Quote
Old 07-24-2008, 07:03 PM   #29
f1racr is an unknown quantity at this point
Yeah I'm interested in this part of things too.
How does the reverse sensor controller know the cars in reverse ? Is it wired into the reverse light circuit ???
By reverse sensor controller we mean the box with the transmitter that all the sensors plug into right ? It'll be in the rear of the car and will send it's info to the USB based receiver that Robby designed.. ??
Just want to make it clear so I and others understand.
f1racr is offline   Reply With Quote
Old 07-24-2008, 07:28 PM   #30
Confusion Master
Enforcer's Avatar
Yes the reverse sensor main control is powered by the reverse light, so it is only active when you are in reverse.
When it is on the USB interface by Robby detects this and then sends a command to RR to go to the PDC screen.
Velleman K8055 USB I/O Board Extension plugin 307SW_NLD RR Released Plugins 200 04-06-2009 07:02 AM
Use serial port with extension plugin??? guillemasco RR Plugins 5 12-04-2006 07:26 PM
Extension plugin problems festy Road Runner 2 06-23-2006 07:20 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
Extension Plugin help .... Gobby Road Runner 1 06-09-2006 11:27 AM
