Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 07-24-2008, 07:54 PM   #31
f1racr is an unknown quantity at this point
Great, thanks for clearing that up, just wanted to be clear on that.
f1racr is offline   Reply With Quote
Old 07-29-2008, 10:41 AM   #32
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Damn it...i don't think I have enough room on my pico for all this stuff...how awesome...
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 08-05-2008, 05:05 AM   #33
jean001luc is an unknown quantity at this point
Is it possible to utilise the camera witihin RR without using the sensor kit? Reason for this is I use the sensor seperately and want to have it available even if the PC is switched off. What I am looking to do is to use a manual switch (connected to reversign lights?) to tell RR that I have gone in to reverse at which time it displays the image. I am not concerned about the sensor input as the existing unit will alert me regarding distance to the object behind.
Thank you
jean001luc is offline   Reply With Quote
Old 08-05-2008, 08:24 AM   #34
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
you would either need a relay board or try to use the com port with some trickery.
Both have be done so a little search should give you an answer.
Enforcer is offline   Reply With Quote
Old 08-09-2008, 06:16 AM   #35
Robby BMW's Avatar
Robby BMW is on a distinguished road
Thank you
There is a better way to use the sensor seperately.
You can connect the sensor main unit to the USB interface trough a cable as explained in the thred, without remove the receiver from the display.
In this way, you can use the original display and the PC simultaneously.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 08-18-2008, 09:11 AM   #36
suneet_ag is an unknown quantity at this point
Robby, Can you add an option to display two sensers in front and two sensors in rear in your plugin? If one installs the sensors in the front he has no option but to use the display which shows the sensors in the rear.
suneet_ag is offline   Reply With Quote
Old 08-18-2008, 11:52 AM   #37
Confusion Master
Enforcer's Avatar
Just change the pdc.skin and slider graphic files to repesent this.
Old 08-19-2008, 07:21 AM   #38
Robby BMW's Avatar
Old 08-21-2008, 01:56 PM   #39
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
small request of sorts....
I'm trying to implement this and the TMI into my flash skin. Unfortunately, flash cant use slider code in any shape or form. So is it possible to define variables or labels for each angle of slider. It doesnt even need to use the sliders range, just 4 to 1 or whatevers easiest.
Doah. just now saw the source is posted lol.. i guess i can do this myself
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 08-23-2008, 07:40 AM   #40
Robby BMW's Avatar
You might have some difficulty in recompiling the code, if so, send me the source with yours changes and I will recompile it for you.
Old 08-23-2008, 07:59 AM   #41
Terminal flasher
will do thanks robby
03 Acura RSX Coupe
Old 09-14-2008, 01:27 PM   #42
Griff1's Avatar
Griff1 is on a distinguished road
Has this plugin been updated yet as per = http://www.mp3car.com/vbulletin/rr-p...-updating.html
P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,ROADRUNNER, iGo8, Custom Freedom 2.1
Griff1 is offline   Reply With Quote
Old 09-14-2008, 02:14 PM   #43
Confusion Master
Enforcer's Avatar
Well the source is in the first post, so it wouldn't be too difficult to update it.
Old 09-14-2008, 02:38 PM   #44
Griff1's Avatar
Excuse me i'm blind,thanks E.
I don't code but i'm gonna have a look anyway.
Old 09-14-2008, 02:59 PM   #45
Confusion Master
Enforcer's Avatar
If Robby hasn't done it by the time I sort out my hibernation issues I will make the necessary changes
Velleman K8055 USB I/O Board Extension plugin 307SW_NLD RR Released Plugins 200 04-06-2009 07:02 AM
Use serial port with extension plugin??? guillemasco RR Plugins 5 12-04-2006 07:26 PM
Extension plugin problems festy Road Runner 2 06-23-2006 07:20 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
Extension Plugin help .... Gobby Road Runner 1 06-09-2006 11:27 AM
