01-09-2009, 10:09 AM
#61
Raw Wave
This is sooooo bad ***.. What cameras are people using? I don't have a TV card but I guess I could install one if need be.. Easiest would be a USB camera?
Thanks!
01-09-2009, 10:25 AM
#62
It work with USB cameras, composite camera with external video input card. If I remember must use WDM drivers.
01-09-2009, 10:26 AM
#63
Raw Wave
Curious what specific model # cameras people are using..
01-12-2009, 04:47 PM
#64
Raw Wave
Would this work for a video capture device coupled with a composite camera?
01-12-2009, 05:30 PM
#65
it's good i have this and work perfectly.
mobo asrock K7S41gx- Amd atlon 1,2Ghz -512Mb ram- hd 2,5" 160Gb- lilliput 7" 619 touch-gps Holux- bluetooth digicomm palladio-usb park assist (RRPDC) -obdII elm327-hubusb trust
01-24-2009, 04:13 AM
#66
I am a newbie to write plugin. Just looked into the source code of RRPDC and can not understand how the slider works. GetDataFromDevice() was called on timer event, but no code in this sub to update the slider.
01-24-2009, 09:28 AM
#67
Confusion Master
The sliders are updated from the sensor() array values in the RRExtension.cls.
The sensor() array values are updated in the GetDataFromDevice() routine.
01-24-2009, 09:45 AM
#68
So once the sensor() array was updated, the slider will refresh automatically? No need to call the ReturnSlider() function explicitly? I can not find any trigger or event to do this.
01-24-2009, 10:51 AM
#69
Confusion Master
ReturnSlider is called from within RoadRunner (as is everything within the RRExtension.cls) at a set period, normally I think every 1/10th second (this can be changed by the user)
01-24-2009, 04:08 PM
#70
Raw Wave
I'm trying to set this up in RR now.. The add "X,RRPDC" to the menu.skin... I'm guessing the "X" should be actual value? For the stupid what do I put there?
01-24-2009, 04:11 PM
#71
Raw Wave
Also, I get this when opening the config:
I've copied the included files over and registered the dll fine. Any ideas?
01-24-2009, 06:13 PM
#72
Confusion Master
Nope, x is x.
You need to download MSCOMCTL.OCX and register it.
If you do a search for it there should be a few posts explaining how to do that.
02-06-2009, 06:31 AM
#73
Hi, I'm building one interface, all is done but it miss the bin file to flash the PIC, do you have an idea where can I found one?
I use the normal LED PDC kit and not using wireless.
02-06-2009, 06:39 AM
#74
Im answer you in general thread. You can't get it.
02-12-2009, 10:54 AM
#75
can this be used on centrafuse (i assume the answer is no, if thats the case then is there a plugin like this for centrafuse)
| Thread Tools |
| Display Modes |
Linear Mode
