Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 02-12-2009, 11:32 AM   #76
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
No.
Yes.
Enforcer is offline   Reply With Quote
Old 02-27-2009, 08:32 AM   #77
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
Is there a way to have the distance "buzzer" come through the actual PC? My buzzer isn't working on my USB unit out of nowhere and I loved the beep-beep-beep as I would get closer to the target.. If this could happen via the PC/Car Speakers that would rock..
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 02-28-2009, 04:46 PM   #78
f1racr is an unknown quantity at this point
I've been asking the exact same thing for the Centrafuse plugin version of this.......... hopefully we'll get what we're after, but I suppose they'll have a million different requests thrown at them all the time so I'm just being patient, but I think it would be a very useful feature for a lot of users so hopefully worth their time to add it in.
f1racr is offline   Reply With Quote
Old 03-02-2009, 11:22 AM   #79
Robby BMW's Avatar
Robby BMW is on a distinguished road
May I suggest to solve the problem with your buzzer connected to the USB interface.
Certainly it could be also possible to implement the beep-beep through the PC, but the benefits to having it directly from the USB interface are manifold:
It's immediately available when the PC is turned on, even if it has not finished to boot.
No problems with the volume level, too low or too high when you're listening music.
And, above all, it's in real time, no delay due to the data processing on the PC.
By the way, what problem have you got with the buzzer?
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 03-02-2009, 11:25 AM   #80
Raw Wave
tbird2340's Avatar
I would love to solve the problem with it on my USB device.. I have no idea what happened.. It just stopped working.. I emailed Dejan about it but haven't heard back from him..
Old 03-03-2009, 11:05 AM   #81
Robby BMW's Avatar
Have you tried to connect the buzzer directly to a power source between 5 to 12 volts (such as a 9 V battery) to see if it works?
If it works, the problem could be due by the transistor BC547B burned, or, more simply, the buzzer may have been disabled trough the command "PDC_BUZZER".
Old 03-03-2009, 01:43 PM   #82
Raw Wave
tbird2340's Avatar
Sigh, I'm such an idiot.. I didn't know that volume button in the skin disabled the buzzer on the actual unit.. I was pressing it the one day to see if the sound would come through the car speakers so I must have disabled it..
Hit it today and it works.
Old 03-03-2009, 02:37 PM   #83
Robby BMW's Avatar
That button toggles ON/OFF the buzzer and the status is stored in the E2PROM memory of the USB interface, so if you disable the buzzer, it will remain disabled until you press it again.
Old 03-28-2009, 09:39 AM   #84
TxAxZxZ's Avatar
TxAxZxZ is on a distinguished road
Where could I get the buzzer from? I was thinking radio shack. I purchased a kit from Dejan and the buzzer was an optional device (not supplied with kit).
EDIT: Just answered my own question with a little research. Sorry about that fellas
Jeeputer Project
- Design <<< 100% >>>
- Construction <<< 99.5% >>>
TxAxZxZ is offline   Reply With Quote
Old 03-28-2009, 10:13 AM   #85
_Dejan_'s Avatar
_Dejan_ is an unknown quantity at this point
Hi,
If you buy whole kit from me with sensors then you can take buzzer from LCD screen.
Open it(you will see two screws) and you will se inside one buzzer with two wires(red&black). Check on front side of buzzer which wire is +(is writen one + on it) because Im see few kits where black wire is + and red is ground :S
Then check on main thread where is scheme which wire you must put in which pin on connector...
With PS holmes check if you have enabled buzzer(speaker must be in normal colors)...
_Dejan_ is offline   Reply With Quote
Old 03-28-2009, 12:48 PM   #86
TxAxZxZ's Avatar
Dejan,
I bought the kit from you. I opened the display (the half moon looking display with distance in the middle of L and R). I opened it up and there is no buzzer located in it. No worries though, I found one at radio shack for $5.00
Jeeputer Project
Old 03-28-2009, 03:26 PM   #87
_Dejan_'s Avatar
Dejan,
Hm,
Did you look on USB board maybe Im already connect it... I know that on last 4-5 kit's which Im sell Im take buzzer and connect it into connector and locate it in plastic case or board.
P.S. Buzzer must be DC 5V
Old 03-28-2009, 04:52 PM   #88
TxAxZxZ's Avatar
You sure did...man that thing is tiny. How loud is it? Do I need to install the board close close to the dash to hear it?
Jeeputer Project
Old 03-29-2009, 11:44 AM   #89
_Dejan_'s Avatar
So you have it in box? Yes it is tiny. I think you will hear it if you have it somewhere in the dash, maybe you will hear it if you have it in boot... Try it and you will see...
Old 06-26-2009, 10:34 AM   #90
Robby BMW's Avatar
New release (1.30) in the first post of this thread.
- Added support for two devices (front and rear).
- Added configurable delays (users request).
- Added fullscreen camera view.
Velleman K8055 USB I/O Board Extension plugin 307SW_NLD RR Released Plugins 200 04-06-2009 07:02 AM
Use serial port with extension plugin??? guillemasco RR Plugins 5 12-04-2006 07:26 PM
Extension plugin problems festy Road Runner 2 06-23-2006 07:20 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
Extension Plugin help .... Gobby Road Runner 1 06-09-2006 11:27 AM
