Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 08-03-2009, 05:03 PM   #91
boelle is an unknown quantity at this point
just tried to install this
did the regserv thing but the config util does not lunch and there is no item added to the menu
installed as instructed... menu.skin attached
the RRPDC-1.30 folder is in C:\Programmer\RideRunner\Plugins
the only thing i could not figure for sure is where the skin folder should go, for now i copied the skin folder to C:\Programmer\RideRunner\Skins\Carwings_Dynamic_Li te\Plugins\RRPDC-1.30
boelle is offline   Reply With Quote
Old 08-03-2009, 05:56 PM   #92
did manage to launch the config tool... but still no menu item in RR
Old 08-18-2009, 08:10 AM   #93
i got hold of everything except how do you force it to use either the front or back cam? is that done on the basis of the distance?
could be nice with a short utube video showing that or some screenshoots, not only for me but for other users as well
i guess that when in reverse it will stick to the rear cam no matter what the front distance shows
Old 09-05-2009, 05:19 AM   #94
*BUMP*
how is the change from rear to front made?
Old 09-12-2009, 06:14 AM   #95
*BUMP*
got my cam today... and still have thoughts about a cam in front, not only for parking but also for night vission
but the first page says that the plugin works when you go in reverse gear, but that does not quite add up with the screen shots for the config util that says its based on distance..
so far i have figured that the kit dejan makes has to be powered all the time, but will the plugin show distance for both front and rear at the same time? or does it switch automatic?
lets say you are between 2 walls with 10 meters between and the car is 5 meters.. that leaves 2,5 meters at both ends when excatly half way between the walls... now as i go forward and break the setting of 2 meters it should show the distance for the front... but how about image? and now if i reverse it will show the distance to the back when i go less than 2 meters and it will show the rear cam ( as you can set what cam to use for the rear )
a small "for dummies guide" could be usefull
Old 09-18-2009, 10:23 AM   #96
another cool feature to this would be guidelines that is put on top of the picture to assist judgement if the car would fit where you have in mind parking
Old 10-13-2009, 10:51 AM   #97
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
Quote: Originally Posted by joey4 View Post
can this be used on centrafuse (i assume the answer is no, if thats the case then is there a plugin like this for centrafuse)
Quote: Originally Posted by Enforcer View Post
No.
Yes.
What is the plugin that is like this for Centrafuse?
No way to port this one to Centrafuse?
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 10-13-2009, 01:16 PM   #98
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
http://forums.fluxmedia.net/plugin-d...ol-plugin.html
Enforcer is offline   Reply With Quote
Old 10-13-2009, 01:21 PM   #99
Raw Wave
tbird2340's Avatar
Thanks a lot.
Old 10-14-2009, 08:13 AM   #100
tommy_xx84 is an unknown quantity at this point
Hi Robby, i've to ask you one things....
in your opinion, is possible use your plugin and connect this camera to my carputer on my vw golf ???
http://cgi.ebay.de/VW-Heckklappenoef...d=p3286.c0.m14
is the original backup camera, but i don't know the video how is sent (pal, ntsc ecc) ....
tommy_xx84 is offline   Reply With Quote
Old 10-22-2009, 04:04 PM   #101
robby, i've done my skin to embed the video from my cinergy 600 by 1 button, but i think there's somethings wrong...
if i was playing music with player....all is ok....i go into the pdc skin, i see the video ecc...and the music don't stop....
BUT
if i was playing the radio (always cinergy 600), when i'll go to the pdc skin, the radio stops...and if i want listen something, i've to click the next button....
same when i'll go back from the pdc skin... if i'm listening the radio....the radio stops again and i've to click some player buttons...(next ecc...) to hear it...
is correct?? or there's a bug???
Old 10-23-2009, 08:32 PM   #102
Micke_L is on a distinguished road
Great looking plugin ! But I noticed it was missing a swedish translation so, here it comes.
File Type: txt Swedish.txt (888 Bytes, 6 views)
Micke_L is offline   Reply With Quote
Old 11-01-2009, 03:33 PM   #103
when i try to enable my backupcam in config i get this:
and when i then save and rerun the config i get this:
my ini for the moment:
[UNITS OF MEASUREMENT]
DistanceUnit=0
[AUDIO SETTINGS]
PausePlayer=False
ChangeVolume=False
VolumeLevel=10
[VIDEO SETTINGS]
VideoEnabled=True
VideoDevice=0
VideoInput=0
VideoStandard=AnalogVideo_None
[SKIN SETTINGS]
AutoStartDelay=0
AutoExitDelay=5
FrontEnabled=False
AutoStartDistance=100
[CONFIGTOOL LOCALIZATION]
Language=0
any idea what could cause the error?
Velleman K8055 USB I/O Board Extension plugin 307SW_NLD RR Released Plugins 200 04-06-2009 07:02 AM
Use serial port with extension plugin??? guillemasco RR Plugins 5 12-04-2006 07:26 PM
Extension plugin problems festy Road Runner 2 06-23-2006 07:20 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
Extension Plugin help .... Gobby Road Runner 1 06-09-2006 11:27 AM
