Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 07-06-2008, 01:58 PM   #1
Robby BMW's Avatar
Robby BMW is on a distinguished road
Arrow RRPDC - RoadRunner park distance control extension plugin
This plugin is intended to work with my custom PDC USB interface.
A detailed description of the whole project can be found here.
How it works:
The plugin is automatically activated when you engage reverse gear, RoadRunner will switch to the plugin skin and alerts you about the presence of obstacles.
If a buzzer is connected to the hardware, this one gradually increases in frequency as you approach the object. A continuous tone denotes that you are within 0.30 m (about 0.98 ft) of the obstacle.
The plugin can be configured to show the distance in meters, inches or feet and optionally it can display a live video from a backup camera.
All the video capture devices that come with a WDM driver, such as framegrabbers in conjunction with a CCD camera or camcorder, USB cameras (webcams) and digital camcorders through Firewire (IEEE 1394), are compatibles with this software.
For example, in my car, I have installed one of these wide-angle mirrored camera and I have connected it to the composite video input of my Cinergy 600 Radio TV card.
Video of the plugin in action:
[media]http://it.youtube.com/watch?v=rqjL37QVe2M[/media]
How to install:
Copy the files provided in the RoadRunner folder (or better, in the PLUGINS folder) and the skin files in your favorite skin folder (you can also use the skin provided (that is part of my BMW-E36 skin) as a guideline to develop your own skin.
Register the DLL, from a command prompt type: regsvr32 <your plugin path>\RRPDC.dll
Add in your "MENU.SKIN" the command "X,RRPDC".
Launch the tool “RRPDC Config” and set all the stuff.
Added skin commands:
COMANDS/BUTONS:
“PDC” – Go to the plugin screen (for testing propouse).
“PDC_BUZZER” – Toggle mute/un-mute the buzzer.
"PDC_CAMERA" – Start the fullscreen camera view (doesn't require additional skin, a click on the screen will turn off the view).
INDICATORS:
“PDC_BUZZER” – Indicates if the buzzer is muted.
"PDC_STOP" - Indicates that the obstacle is at less then 0.30 m (0.98 ft).
LABELS:
"PDC_DISTANCE" – Shows the distance when an obstacle is under 2.00 meters (6.56 ft) in rear of the vehicle.
SLIDERS:
"PDC_SENSOR_A" – Shows visually the distance detected by the ultrasonic sensor A (Rear extreme left).
"PDC_SENSOR_B" – Shows visually the distance detected by the ultrasonic sensor B (Rear center left).
"PDC_SENSOR_C" – Shows visually the distance detected by the ultrasonic sensor C (Rear center right).
"PDC_SENSOR_D" – Shows visually the distance detected by the ultrasonic sensor D (Rear extreme right).
"PDC_SENSOR_E" – Shows visually the distance detected by the ultrasonic sensor A (Front extreme left).
"PDC_SENSOR_F" – Shows visually the distance detected by the ultrasonic sensor B (Front center left).
"PDC_SENSOR_G" – Shows visually the distance detected by the ultrasonic sensor C (Front center right).
"PDC_SENSOR_H" – Shows visually the distance detected by the ultrasonic sensor D (Front extreme right).
OTHER:
"Axx, X, Y, W, H, R, G, B" - Defines the live video "confine" position (you must also CLIP this area). Please note that the image from the camera always maintains its aspect ratio.
"Cxx, X, Y, W, H" - Clip window region, this tag must to have the same parameters of the tag above.
Look at the skin provided for more details on how to use these commands.
Screen shots:
- the plugin in action -
- the config utility -
- the config utility (advanced settings)-
The configuration utility is multilingual, curently it has been translated into:
English
Spanish - Thanks to Aveigal
Italian
German - Thanks to Zorro
French - Thanks to Coucouillu
Russian - Thanks to Kadyroff
Hungarian - Thanks to FPeter
Netherlands - Thanks to Servowire
Slovenian - Thanks to Dejan
Romanian - Thanks to Dexter4000
Portuguese - Thanks to Myrus
Turkish
Greek - Thanks to 85755
Danish - Thanks to Boelle
Finnish - Thanks to Tumeski
Klingon - Thanks to... Worf
Would you like to get it translated also in your language?
Downlad this file: "English.txt", translate it and post it back, I will be happy to include also your language.
Change log:
1.00:
-First release.
1.10:
- Fixed the indicators in agreement with this thread.
1.30:
- Added support for two devices (front and rear).
- Added configurable delays (users request).
- Added fullscreen camera view.
Downloads (Robby's Server):
RRPDC 1.30 Binary
RRPDC 1.30 Source
Downloads (Mirror):
(It could not be updated with the last release)
RRPDC 1.10 Binary
RRPDC 1.10 Source
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Advertisement Sponsored links
Old 07-06-2008, 02:04 PM   #2
almera's Avatar
almera is on a distinguished road
Thumbs up
Another excellent project, thanks again Robby..
almera is offline   Reply With Quote
Old 07-06-2008, 02:08 PM   #3
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
wow, this is just awesome, good job Robby!!
EL CAMINO is offline   Reply With Quote
Old 07-06-2008, 02:34 PM   #4
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
gobby? who is gobby?
Enforcer is online now   Reply With Quote
Old 07-06-2008, 02:38 PM   #5
almera's Avatar
maybe this one:
http://www.elfwood.com/art/k/r/krist...d_psd.jpg.html
Old 07-06-2008, 02:41 PM   #6
Robby BMW's Avatar
Maybe my second nikname
Old 07-06-2008, 02:49 PM   #7
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
I really need to rob a bank or something to get to put in some of these awesome plugin's!!
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 07-06-2008, 04:24 PM   #8
EL CAMINO's Avatar
ups, fixed!!
Old 07-08-2008, 02:40 PM   #9
MGD
MGD's Avatar
MGD is on a distinguished road
Well, did all the things you said, run the config tool, set everything, shows the image in the config tool, camera working. After that, start RR go to the camera skin but it does not show anything from the camera. Do I need an external program and embed it?
MGD is online now   Reply With Quote
Old 07-08-2008, 02:50 PM   #10
Confusion Master
Enforcer's Avatar
Have you registered the DLL?
Have you added the X,RRPDC to your menu.skin
Old 07-08-2008, 02:56 PM   #11
MGD
MGD's Avatar
Yep, registered the DLL, have X,RRPDC in my menu skin, it only shows the clip region.
Old 07-08-2008, 02:58 PM   #12
Confusion Master
Enforcer's Avatar
Pics?
Old 07-08-2008, 03:08 PM   #13
MGD
MGD's Avatar
here you go...
EDIT, forgot to tell you I do run DX 9.0c
Old 07-08-2008, 03:52 PM   #14
Confusion Master
Enforcer's Avatar
try taking the clip out.
Old 07-08-2008, 03:59 PM   #15
MGD
MGD's Avatar
That was the first thing I tryed..no luck.
I even copyed the XVideoOCX.ocx to System32 and registered it..still no good.
Velleman K8055 USB I/O Board Extension plugin 307SW_NLD RR Released Plugins 200 04-06-2009 07:02 AM
Use serial port with extension plugin??? guillemasco RR Plugins 5 12-04-2006 07:26 PM
Extension plugin problems festy Road Runner 2 06-23-2006 07:20 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
Extension Plugin help .... Gobby Road Runner 1 06-09-2006 11:27 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
