Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 09-01-2008, 07:44 PM   #151
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by Chuck View Post
Works good
There are some undisclosed commands, that was one of them
Enforcer is online now   Reply With Quote
Old 09-01-2008, 07:48 PM   #152
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by b3tts32 View Post
anyone have a screen built for lsx? it would be greatly appreciated!
It shouldn't be too difficult to convert the original Gas Price screen for LSX
Old 09-01-2008, 10:51 PM   #153
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Nice one Enforcer
It's nice to tap the screen and get the gas prices around your current location, instead of having to first figure out what Zipcode or should I say POSTcode, that you are in first.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 09-02-2008, 06:50 AM   #154
Confusion Master
Enforcer's Avatar
So, you are saying it works then?
How about the slider?
Old 09-02-2008, 12:36 PM   #155
Super Moderator
JohnWPB's Avatar
Yikes, I forgot you added the slider code! I will have to try that out, what was the slider name and info again? Is it the RRGas that you mentioned in the first post, as the code for the slider?
Old 09-02-2008, 01:00 PM   #156
dmistry is an unknown quantity at this point
John, to be redundant from another post
"Will this make it in to the DFX4.0 Service Pack?"
dmistry is offline   Reply With Quote
Old 09-02-2008, 01:28 PM   #157
Super Moderator
JohnWPB's Avatar
Ok, I just added a slider and the code, and it does not appear to be working. When the gas prices are loading, the screen appears, and when down loading the screen disappears. However the slider is not getting updated.
I can send a:
Setvar;RRGAS;20000
with the skin tool, and you can see the slider jumps to around the 1/4 mark or so.
Here is a screen cap of the progress: (Sorry Bad Punn )
Old 09-02-2008, 01:36 PM   #158
Confusion Master
Enforcer's Avatar
Hmm, I know it didn't work when I put in in a skin, but I thought that was just me, as the debugging code indicates it sends back the updated info, but RR seems to ignore it for some reason.
Old 09-03-2008, 02:54 AM   #159
Super Moderator
JohnWPB's Avatar
Is the plugin taking the - 0 100% complete or loaded percent, and converting it to the 0 to 682000 (Cant remember the high limit number, but that's close to it).
If not 100% (or 100 sent to RR to display) would not be enough to even notice the slider move.
Old 09-03-2008, 05:29 AM   #160
Confusion Master
Enforcer's Avatar
it's sending a number between 0-65536 not a %
I think if you turn debug on it should say what value it is trying to send.
Last edited by JohnWPB; 09-03-2008 at 10:04 AM. Reason: (SORRY! Edited the last post, didnt realize you Posted back that FAST!, and just edited the last message in a hurry.
Old 09-03-2008, 08:47 AM   #161
Super Moderator
JohnWPB's Avatar
I do not see any code in the debug that is updating the slider code:
rrgas_ZIPcode
NUMOSKTOCMD;GASCODE;rrgas_newcode
ENTER
rrgas_newcode
menu;gas_loading.skin
rrgas_prerefresh
Just to verify, the code / variable for the slider should be $RRGAS$ right?
Old 09-03-2008, 09:20 AM   #162
Confusion Master
Enforcer's Avatar
RRGAS is the slider code.
And are you looking at the Roadrunner debug or the RRGAS debug?
Old 09-03-2008, 09:55 AM   #163
Super Moderator
JohnWPB's Avatar
Ahhh was looking at the RRDebug... let me turn yours on and post back
EDIT: Ok, I just tried Debug=true on the gas.ini and did not get a log. I searched this thread for debug, and cant find anything on how to enable it.
I also looked in the RRSkinCommands.txt as well as in the readMe.txt in the gas zip file.
Old 09-03-2008, 01:28 PM   #164
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
As with my plugins that have their own debug log, I just poll the debug status from rr as that way you can see everything if there is an issue instead of having each plugin have its own debug off/on setting..
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is online now   Reply With Quote
Old 09-03-2008, 02:18 PM   #165
Confusion Master
Enforcer's Avatar
debug=true in the gas.ini should produce a debug.txt file in the rrgas folder.
However I have just looked at the source and it looks like I commented out the code to debug print the slider values sent.
BTW does this version play any nicer when RR starts up?
