08-05-2008, 12:19 PM
#16
Hey monkeyracer, in post number 2 is the folder with the images attached.
Here is the new GASNAV.exe. You need to have iGuidance modifyed with the Coordinate fix.
08-05-2008, 12:25 PM
#17
Indicators look ok. here is my GAS folder as they work. Unzip to Road Runner Folder.
08-05-2008, 12:45 PM
#18
Confusion Master
Try running only this plugin, I'm wondering if there is an issue with multiple plugins and indicators.
Also what versions of RR are people running.
08-05-2008, 01:04 PM
#19
Wants to make it harder
I'm using the weatherfixed beta. If the x,rrgas is the last plugin loaded, it works fine.
I've got the GASNAV working too. Only problem it seems is if I've already got a route entered it doesn't play nice...
edit: added
Code:
ACTIVATE;!IntellinavWCls!iGuidance||SENDKEY;%F||SENDKEY;C||ACTIVATE;RoadRunner||
to the command so that it clears any previous route. Once I'm done filling up, I can just go to "recent" destinations to continue the route
Edit again: if there is no route, it brings up the Current Location instead, so I don't know...
08-05-2008, 01:17 PM
#20
Super Moderator
I also am running the Weather beta. It may be another plugin as you mentioned interfering... will do some tests here and see...
MGD, I almost did an options pop up myself... then I decided I could squeeze them in at the top
08-05-2008, 01:23 PM
#21
Try this new GASNAV.exe. It will cancel any previous route and the n select the new one.
#22
ok, flame me. i know im missing something. its not working (at least for me). only have X,RRGAS on menu skin, button cmd to start (load) the gas is rrgas. I click it and nothing happens........
CAR:2001 Ford Crown Victoria
PC: Acer EEE 900HA with Vista with CF 2.0.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:Garmin
Screen:Xenarc 700TSV
The Florida Meets Thread
08-05-2008, 01:29 PM
#23
Super Moderator
Plugin Conflicts
I just found that another plugin was interfering... The TIMEEXEC plugin that Guino did a year or so back. It is designed to fire events at certain times of the day. I turned it off, reloaded the skin and the indicators are now showing up.
08-05-2008, 01:43 PM
#24
Super Moderator
I think I know what the problem is.... reach around the back of your laptop, find the little round plug and pull it out.... close the lid and step away!
LOL
(You did ask nicely)
#25
Check your Skin Name. It has to be "GAS.Skin", nothing else.
@John, I did not run that pluin from Guino thatswhy my indicators were working. Good find.
08-05-2008, 01:57 PM
#26
The Curator
Thanks goes to notepad, not Enforcer....
Nice...just hope that this lasts as long as the old one did!
08-05-2008, 02:03 PM
#27
Confusion Master
You need the plugin.
Only a few beta testers have it at present, some should be fairly obvious to you, so unless one of them has slipped you a copy under the counter you won't have it yet.
I will probably release it to the masses later on today or tomorrow, with a few tweeks suggested by John, until then paitence young padwan.
08-05-2008, 02:04 PM
#28
Confusion Master
Well it's an extension plugin, so a lot easier to change if necessary.
08-05-2008, 02:05 PM
#29
Super Moderator
When I started emabling plugins again, when I enabled the RRMedia plugin, the icons once again stopped working. Something has to be done once and for all with the plugins messing with each other. I know absolutely nothing about it unfortunately...
I know there was discussion at great length involving Guino, Sonic and Blue.... I just dont know what the final out comes was, if there was one....
08-05-2008, 02:07 PM
#30
Confusion Master
Have you tried switching the order?
| Thread Tools |
| Display Modes |
Linear Mode
