Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-01-2009, 11:56 AM   #406
msperano is an unknown quantity at this point
Mike says thanks, I knew I saw it somewhere that fixed it right up.
Mike
msperano is offline   Reply With Quote
Old 10-02-2009, 03:26 AM   #407
jakal's Avatar
jakal is an unknown quantity at this point
Quote: Originally Posted by Enforcer View Post
Well the email in forum inbox said your account had been registered an hour before you posted your previous post, as did the information in the admin control panel.
LOL thats because I registered again thinking maybe my request got deleted.
jakal is offline   Reply With Quote
Old 10-16-2009, 08:10 PM   #408
pepsimachine is on a distinguished road
still never got the zip from gps to work, im at a loss.
pepsimachine is offline   Reply With Quote
Old 10-18-2009, 12:10 AM   #409
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Looking at your debug you posted earlier it looks like the file that was downloaded with the postal code diodn't match the format the program is expecting, therefore it couldn't extract the zipcode.
Now putting the url into a webbrowser here gives me a correct format file.
So I can only conclude that the file you are downloading is either corrupt, the website didn't like your IP Address so has sent a non available type page or your firewall may have blocked the site.
Try putting the url into a browser and see what page you get (should be an XML format)
Enforcer is offline   Reply With Quote
Old 10-21-2009, 05:47 PM   #410
i do get an xml page, i had already tried entering in each url into a browser to see what i got. i dont even see an xml file being downloaded to any folder in the plugin, should the plugin be downloading the file, or does it open and read it on the fly? how does the plugin access the internet to retrieve the information, from an external browser/program or just connects to http with itself?
Old 10-21-2009, 07:12 PM   #411
Confusion Master
Enforcer's Avatar
can you send me a copy of the xml you get?
the plugin downloads the page, sucks it up and then deletes it.
It downloads it internally (using a MS webbrowser control, so it's basically using IE)
Old 10-21-2009, 07:34 PM   #412
i pm'ed you a copy of the xml. i think the problem may more likely be that i'm using a slimmed down version of windows xp, with minimal browser function. the browser operates for what i need it to, like i can go to google, and view web pages and such, but maybe there is a component that i am missing that your plugin requires. should i check for any missing dll files in the i.e. folder??
Old 10-21-2009, 07:47 PM   #413
Confusion Master
Enforcer's Avatar
Well the XML you sent me is fine and if downloaded correctly should work fine.
have a look in windows\system32 for
ieframe.oca
ieframe.dll
Old 10-21-2009, 08:05 PM   #414
i have neither of those files. i checked my laptop, which has a full windows xp sp2 install, and the laptop doesnt have the files either. both are running i.e. 6.0
i downloaded ieframe.dll and placed it in the system32 folder, which didnt seem to help. i couldnt find ieframe.oca for download on google
EDIT: i also did a full reinstall of i.e. 6 using method 3 described here: http://support.microsoft.com/?kbid=318378
Old 10-21-2009, 08:29 PM   #415
Confusion Master
Enforcer's Avatar
The oca may just be needed for development machines. the dll is the important one.
Old 10-21-2009, 09:14 PM   #416
updating to i.e.7 fixed the problem. however, i would much rather use i.e.6 for the ability to remove all the toolbars making it more skinnable. i might try installing roadrunner on the freshly installed laptop with a full copy of xp sp2 and i.e.6 to see if i can re-create the issue
Old 10-21-2009, 09:32 PM   #417
Confusion Master
Enforcer's Avatar
Yeah, my development machines all have 7 on now.
I think I also had an issue with another user running the standalone petrol app. he was running 6 and an upgrade to 7 fixed it.
Old 10-22-2009, 07:29 PM   #418
i guess i'll just have to use ie7 as i really wanted the gas function. looks like ie6 just doesnt want to provide the necessary tools for this to work right. now onto getting the gasnav to work.
thanks for all your help
Old 10-22-2009, 08:01 PM   #419
Confusion Master
Enforcer's Avatar
If I had a PC with IE6 on I could probably do a version for that. But I don't at the moment.
