08-05-2008, 08:21 PM
#46
The Curator
Quote: Originally Posted by Enforcer
It has to be the way the plugin is handling the Indicator code.
Having a quick look at the way RR handles the Indicator codes with regards to extensions, it looks like the plugin has to return one of the following
'false' - if the indicator is not processed by this plugin
'true' - if it is and it's to be changed to true.
path to graphic file - if it's to show a graphic.
Now if a plugin returns anything other than 'true' or 'false' that indicator path will take on that value as it's path.
so if a plugin has been written that doesn't have the line
ReturnIndicator = "False" as a default for when it doesn't process it, it will mess that indicator and anyone else's indicator up.
Also another possibility.
If the value of IND is changed in the plugins indicator routine, that will also change the name of the indicator that RR will look for.
Ok, revised theory
It looks like whichever plugin it goes through last will have the indicators working. But will kill it for every other plugins indicators.
I'm looking at the source from 26 Oct 2007, which on deeper invetigation shouldn't be affected by this, so I can only suppose that something has been changed in the source code since then.
This is what I thought that ending thoughts were on the disscution between me,sonic, and guino. My plugins have always left that line just as it says in the comment directly above the line "ReturnIndicator="false".
08-05-2008, 10:35 PM
#47
Super Moderator
Plugin Manager
Quote: Originally Posted by monkeyracer
The root of the issue is that there are some plug-ins that need to be loaded in a certain order, if you have two that need to be loaded last, only one wins. Someone want to make a plug-in manager plugin?
Actually, Blue made a fantastic Plugin Manager for me for use in the DFX skin. It can turn on and off the plugins from within the skin, and saves the X, lines to an include file. Then all that is needed is X,PluginManager in the menu.skin.
The only problem, and not a fault of BLue's plugin, is they are simply in alphabetical order. There is no way for it to know what plugins are friendly, not friendly, need to be at the bottom, if there are 2 fighting to be at the bottom and loaded last ect....
08-05-2008, 10:36 PM
#48
Wants to make it harder
Ok, revised theory
Further update.
Just went back to 26th October 07 executable and the indicators work fine in two plugins, whereas they don't in the later versions.
So, what do we do to fix it?
Are we to now assume that there will be an official release instead of all these beta's floating around?
08-05-2008, 10:57 PM
#49
this order works for me:
/, X, Extension Name
X,powermon
X,RRStrings
X,Mp3Art
X,rrgas
but... that's really just a temporary solution...
08-05-2008, 11:20 PM
#50
Confusion Master
Well I think Guino needs to be made aware of my theory, and if it's true make the neccesary changes, however his time is mimited at the moment and there are quite a few 'quirks' at the moment.
Going back to an older version (12th October) but then you lose the weather and any other enhancements that are more recent updates.
08-05-2008, 11:40 PM
#51
The Last Good Gremlin
How about getting the changes to Mitchjs and have them included in his latest beta. His "soon to be released" beta seems to incorporate most of the latest updates (I think he and Guino have an arrangement.)
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
08-05-2008, 11:46 PM
#52
Confusion Master
Well I don't know what has changed since October/November last year to cause the indicator problem as the last source I have access to is Novembers, so I can't advise of the changes to be made.
However if Mitchjs is working from that one then the indicators won't be broken and need fixing.
08-06-2008, 02:24 AM
#53
It ain't easy being a green moderator
Location: Steps out the front of Henson's workshop or Sydney
hey E,
You hsve done RRGas for the US and UK, any chance of doing it for us in Aus?
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
08-06-2008, 08:35 AM
#54
Confusion Master
Quote: Originally Posted by meddler
hey E,
You got any websites in Aus that provides petrol prices?
08-06-2008, 08:54 AM
#55
Terminal flasher
as far as i can tell mitchjs release has fixed the indicator bug issue. All of my plugins are cooperating and adding one doesnt change any other.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
08-06-2008, 08:27 PM
#56
Confusion Master
<space reserved for something profound>
08-06-2008, 09:38 PM
#57
Grabbing it fast
08-07-2008, 12:17 AM
#58
http://motormouth.com.au/pricesearch.aspx
is one I have found so far. I will let you know when I find a site that is better.
EDIT:
http://carsguide.news.com.au/site/on...petrol-prices/ (this one show a google map of the stations)
08-07-2008, 12:21 AM
#59
Thanks.... It works great!
08-07-2008, 12:26 AM
#60
Wow Enforcer, that's awesome!
I am guessing this will be incorporated into the next DFX release, John?
| Thread Tools |
| Display Modes |
Linear Mode
