Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 08-10-2008, 09:23 AM   #91
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Now to sort out the UK one.
Enforcer is offline   Reply With Quote
Old 08-10-2008, 10:26 AM   #92
Wants to make it harder
monkeyracer's Avatar
monkeyracer is an unknown quantity at this point
Quote: Originally Posted by Enforcer View Post
Latest version is now : 1.3.1
Quote: Originally Posted by JohnWPB View Post
I just downloaded again, after your last post, and the version states 1.3.1.0.
Did I download a special version or something? my version states 1.3.0.1 (see attached)
It remembers the last fuel order searched, but the way I have my skin set up, it doesn't show all the prices, just the one you need for each station. So, if I sort by diesel, for example, it will keep the stations sorted by diesel prices, but only display the unleaded prices for those stations. I think it all boils down to the fact that I'm using setvar and byvar for those labels:
In gas.skin:
Code:
L09,574,43,98,32,#FRed#,#FGreen#,#FBlue#,20,"BankGothic Md BT","byvar;SORTORDER;=reg<<=reg<<=plus<<=prem<<=diesel","CENTER" L09,574,93,98,32,#FRed#,#FGreen#,#FBlue#,16,"BankGothic Md BT","byvar;SORTORDER;rrgas_0_unleaded<<rrgas_0_unleaded<<rrgas_0_plus<<rrgas_0_premium<<rrgas_0_diesel","CENTER" L09,574,150,98,32,#FRed#,#FGreen#,#FBlue#,16,"BankGothic Md BT","byvar;SORTORDER;rrgas_1_unleaded<<rrgas_1_unleaded<<rrgas_1_plus<<rrgas_1_premium<<rrgas_1_diesel","CENTER" L09,574,208,98,32,#FRed#,#FGreen#,#FBlue#,16,"BankGothic Md BT","byvar;SORTORDER;rrgas_2_unleaded<<rrgas_2_unleaded<<rrgas_2_plus<<rrgas_2_premium<<rrgas_2_diesel","CENTER" L09,574,267,98,32,#FRed#,#FGreen#,#FBlue#,16,"BankGothic Md BT","byvar;SORTORDER;rrgas_3_unleaded<<rrgas_3_unleaded<<rrgas_3_plus<<rrgas_3_premium<<rrgas_3_diesel","CENTER" L09,574,325,98,32,#FRed#,#FGreen#,#FBlue#,16,"BankGothic Md BT","byvar;SORTORDER;rrgas_4_unleaded<<rrgas_4_unleaded<<rrgas_4_plus<<rrgas_4_premium<<rrgas_4_diesel","CENTER" L09,574,382,98,32,#FRed#,#FGreen#,#FBlue#,16,"BankGothic Md BT","byvar;SORTORDER;rrgas_5_unleaded<<rrgas_5_unleaded<<rrgas_5_plus<<rrgas_5_premium<<rrgas_5_diesel","CENTER" L09,179,43,300,32,#FRed#,#FGreen#,#FBlue#,20,"BankGothic Md BT","byvar;SORTORDER;=sorted by distance<<=sorted by price<<=sorted by price<<=sorted by price<<=sorted by price","LEFT" /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B404,674,133,104,58,"rrgas_distance",@rrgas_distancesort||SETVAR;SORTORDER;0@ B004,674,76,104,58,"rrgas_zipcode", B405,674,191,104,58,"rrgas_unleaded||SETVAR;SORTORDER;1", B406,674,250,104,58,"rrgas_plus||SETVAR;SORTORDER;2", B410,674,365,104,58,"rrgas_diesel||SETVAR;SORTORDER;4", B411,674,308,104,58,"rrgas_premium||SETVAR;SORTORDER;3", /DISCARDABLE
So from the above example, when I sort by Plus, the var SORTORDER is set to 2, but only until I close RR, then it defaults back to 0 (with and without the /DISCARDABLE tag). The next time I run RR, the plugin remembers that the order was sorted by plus, but the labels displayed are the unleaded prices for those stations.
My method is to write to the gaspref.txt two definitions; GASSORT (remembers the last method searched), and GASORDER (remembers the order number on the setvar), these are referenced when the RRGAS command is executed and the last method is sorted.
2007 Chrysler PT Cruiser TE
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
monkeyracer is offline   Reply With Quote
Old 08-10-2008, 10:55 AM   #93
Confusion Master
Enforcer's Avatar
No, that is the correct version. It is 1.3.1 but for some reason Windows sticks that extra .0. in between for some reason.
In gas.skin:
Code:
Looks like your sortorder value is not being held between restarts, try savetoini after the setvar
Old 08-10-2008, 09:36 PM   #94
mikeeps2 is an unknown quantity at this point
enforcer i test the gas price in my skin and working perfect , but i have a bug , in the botton for select range of miles , when i push that botton , the volumen down and up , if put the botton for other place in the skin working but where i have now no working perfect , do you know why ?
mikeeps2 is offline   Reply With Quote
Old 08-11-2008, 07:08 AM   #95
Confusion Master
Enforcer's Avatar
You probably have another button in the same place.
post your .skin file.
Old 08-11-2008, 09:50 AM   #96
no , i check many time , i dont have other botton in the same place , see my gas.skin file
MEDIACAR Skin
MEDIACAR gpsgas Skin
GAS_PRICEFINDER_OFF.jpg,GAS_PRICEFINDER_OFF.jpg,GA S_PRICEFINDER_ON.jpg,GAS_PRICEFINDER_DOWN.jpg
B,609,1,70,73,"rrgas_distancesort",
/, I, x, y, w, h, Code;INDICATORCODES
I,530,45,51,11,"ONLINE"
/, IMG, x, y, w, h, File Name, Option;IMGLAYER
IMG,530,45,51,11,"online_indicator.gif",ON
IMG,530,45,51,11,"online_indicator.gif",DOWN
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L,561,17,35,22,255,128,0,11,"Arial:B","CPU","LEFT"
L,522,17,35,22,255,128,0,11,"Arial:B","=CPU:","LEF T"
L,303,525,60,26,255,109,74,12,"DotMatrix","VOLUME" ,"LEFT"
B06,547,506,87,98,"VOL-","Volume-"
B07,631,506,87,98,"VOL+","Volume+"
B40,180,506,55,70,"NEXT",""
B41,120,506,55,70,"PREV",""
B21,15,506,90,70,"EXIT","Cancel"
/, Y, Back Slider file path
Y01,"\volume_slider\volume_*.jpg"
/, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
S01,303,520,215,45,303,16,215,45,H,01,"",013,"MAST ER","Master"
I06,715,506,91,95,"MASTERMUTE:b"
I,541,303,40,40,"rrgas_5_icon"
I,283,303,40,40,"rrgas_4_icon"
I,20,303,40,40,"rrgas_3_icon"
I,541,89,40,40,"rrgas_2_icon"
I,282,90,40,40,"rrgas_1_icon"
I,19,88,40,40,"rrgas_0_icon"
B,200,25,125,50,"rrgas_ZIPcode",
B,388,3,54,66,"rrgas_distance",
L,105,40,102,22,255,255,255,12,"HandelGotDLig:B"," =Postal Code",
L,223,37,75,25,255,255,0,14,"HandelGotDLig:B","rrg as_ZIPcode",
L,453,43,46,20,255,255,255,12,"HandelGotDLig:B","= Miles",
L,323,43,53,20,255,255,255,12,"HandelGotDLig:B","= Within","LEFT"
L,394,38,41,26,255,255,0,14,"HandelGotDLig:B","rrg as_distance",
L,718,469,58,20,255,255,255,12,"Arial:B","rrGAS_5_ DIESEL",
L,458,469,58,20,255,255,255,12,"Arial:B","rrGAS_4_ DIESEL",
L,198,467,58,20,255,255,255,12,"Arial:B","rrGAS_3_ DIESEL",
L,719,253,58,20,255,255,255,12,"Arial:B","rrGAS_2_ DIESEL",
L,459,253,58,20,255,255,255,12,"Arial:B","rrGAS_1_ DIESEL",
L,637,469,77,20,255,255,255,12,"HandelGotDLig:B"," =Diesel","CENTER"
L,378,468,77,20,255,255,255,12,"HandelGotDLig:B"," =Diesel","CENTER"
L,118,467,77,20,255,255,255,12,"HandelGotDLig:B"," =Diesel","CENTER"
L,639,253,77,20,255,255,255,12,"HandelGotDLig:B"," =Diesel","CENTER"
L,378,253,77,20,255,255,255,12,"HandelGotDLig:B"," =Diesel","CENTER"
L,284,246,84,22,255,255,255,14,"HandelGotDLig:B"," =Map","CENTER"
L,544,459,84,22,255,255,255,14,"HandelGotDLig:B"," =Map","CENTER"
L,546,245,84,22,255,255,255,14,"HandelGotDLig:B"," =Map","CENTER"
L,284,460,84,22,255,255,255,14,"HandelGotDLig:B"," =Map","CENTER"
L,23,461,84,22,255,255,255,14,"HandelGotDLig:B","= Map","CENTER"
L,22,244,84,25,255,255,255,14,"HandelGotDLig:B","= Map","CENTER"
L,117,251,77,20,255,255,255,12,"HandelGotDLig:B"," =Diesel","CENTER"
L,198,251,58,20,255,255,255,12,"Arial:B","rrGAS_0_ DIESEL",
L,718,445,58,19,255,255,255,12,"Arial:B","rrGAS_5_ PREMIUM",
L,458,445,58,20,255,255,255,12,"Arial:B","rrGAS_4_ PREMIUM",
L,198,443,58,20,255,255,255,12,"Arial:B","rrGAS_3_ PREMIUM",
L,719,230,58,20,255,255,255,12,"Arial:B","rrGAS_2_ PREMIUM",
L,459,230,58,20,255,255,255,12,"Arial:B","rrGAS_1_ PREMIUM",
L,637,445,77,20,255,0,0,12,"HandelGotDLig:B","=Pre mium",
L,378,446,77,20,255,0,0,12,"HandelGotDLig:B","=Pre mium","CENTER"
L,118,443,77,20,255,0,0,12,"HandelGotDLig:B","=Pre mium",
L,639,230,77,20,255,0,0,12,"HandelGotDLig:B","=Pre mium",
L,378,230,77,20,255,0,0,12,"HandelGotDLig:B","=Pre mium",
L,637,422,77,20,0,255,0,12,"HandelGotDLig:B","=Plu s",
L,378,422,77,20,0,255,0,12,"HandelGotDLig:B","=Plu s",
L,118,419,77,20,0,255,0,12,"HandelGotDLig:B","=Plu s",
L,639,206,77,20,0,255,0,12,"HandelGotDLig:B","=Plu s",
L,378,207,77,20,0,255,0,12,"HandelGotDLig:B","=Plu s",
L,637,398,77,20,255,255,0,12,"HandelGotDLig:B","=U nleaded",
L,377,398,77,20,255,255,0,12,"HandelGotDLig:B","=U nleaded",
L,118,395,77,20,255,255,0,12,"HandelGotDLig:B","=U nleaded",
L,639,182,77,20,255,255,0,12,"HandelGotDLig:B","=U nleaded",
L,378,183,77,20,255,255,0,12,"HandelGotDLig:B","=U nleaded",
L,553,408,68,20,255,255,255,11,"HandelGotDLig:B"," =Distance",
L,288,406,68,20,255,255,255,11,"HandelGotDLig:B"," =Distance",
L,29,410,68,20,255,255,255,11,"HandelGotDLig:B","= Distance",
L,555,192,68,20,255,255,255,11,"HandelGotDLig:B"," =Distance",
L,297,193,68,20,255,255,255,11,"HandelGotDLig:B"," =Distance",
B,117,251,77,20,"rrgas_Diesel",
B,119,229,76,20,"rrgas_Premium",
B,118,204,74,20,"rrgas_Plus",
B,118,181,74,20,"rrgas_Unleaded",
B,30,188,67,20,"rrgas_Distancesort",
L,29,188,68,20,255,255,255,11,"HandelGotDLig:B","= Distance",
L,118,179,77,20,255,255,0,11,"HandelGotDLig:B","=U nleaded",
L,118,204,77,20,0,255,0,12,"HandelGotDLig:B","=Plu s",
L,118,228,77,20,255,0,0,12,"HandelGotDLig:B","=Pre mium",
L,198,228,58,20,255,255,255,12,"Arial:B","rrGAS_0_ PREMIUM",
L,718,422,58,20,255,255,255,12,"Arial:B","rrGAS_5_ PLUS",
L,458,421,58,20,255,255,255,12,"Arial:B","rrGAS_4_ PLUS",
L,198,419,58,20,255,255,255,12,"Arial:B","rrGAS_3_ PLUS",
L,719,205,58,20,255,255,255,12,"Arial:B","rrGAS_2_ PLUS",
L,459,206,58,20,255,255,255,12,"Arial:B","rrGAS_1_ PLUS",
L,198,203,58,20,255,255,255,12,"Arial:B","rrGAS_0_ PLUS",
L,553,431,67,20,255,255,255,11,"Arial:B","rrGAS_5_ DISTANCE",
L,288,431,68,20,255,255,255,11,"Arial:B","rrGAS_4_ DISTANCE",
L,29,433,67,20,255,255,255,11,"Arial:B","rrGAS_3_D ISTANCE",
L,555,217,68,20,255,255,255,11,"Arial:B","rrGAS_2_ DISTANCE",
L,296,218,69,20,255,255,255,11,"Arial:B","rrGAS_1_ DISTANCE",
L,29,215,68,20,255,255,255,11,"Arial:B","rrGAS_0_D ISTANCE",
L,198,179,58,20,255,255,255,12,"Arial:B","rrGAS_0_ UNLEADED",
L,459,182,58,20,255,255,255,12,"Arial:B","rrGAS_1_ UNLEADED",
L,719,181,58,20,255,255,255,12,"Arial:B","rrGAS_2_ UNLEADED",
L,199,395,58,20,255,255,255,12,"Arial:B","rrGAS_3_ UNLEADED",
L,458,397,58,20,255,255,255,12,"Arial:B","rrGAS_4_ UNLEADED",
L,718,397,58,20,255,255,255,12,"Arial:B","rrGAS_5_ UNLEADED",
L,547,350,229,20,255,255,255,14,"HandelGotDLig:B", "rrGAS_5_ADDRESS","LEFT"
L,547,371,229,20,255,255,255,14,"HandelGotDLig:B", "rrGAS_5_ADDRESS2","LEFT"
L,288,349,227,20,255,255,255,14,"HandelGotDLig:B", "rrGAS_4_ADDRESS","LEFT"
L,288,371,227,20,255,255,255,14,"HandelGotDLig:B", "rrGAS_4_ADDRESS2","LEFT"
L,24,349,233,20,255,255,255,14,"HandelGotDLig:B"," rrGAS_3_ADDRESS","LEFT"
L,24,370,233,20,255,255,255,14,"HandelGotDLig:B"," rrGAS_3_ADDRESS2","LEFT"
L,545,134,230,20,255,255,255,14,"HandelGotDLig:B", "rrGAS_2_ADDRESS","LEFT"
L,286,134,227,20,255,255,255,14,"HandelGotDLig:B", "rrGAS_1_ADDRESS","LEFT"
L,585,304,190,35,255,255,255,22,"HandelGotDLig:B", "rrGAS_5_NAME","CENTER"
L,329,305,183,35,255,255,255,22,"HandelGotDLig:B", "rrGAS_4_NAME","CENTER"
L,63,305,192,35,255,255,255,22,"HandelGotDLig:B"," rrGAS_3_NAME","CENTER"
L,586,91,189,35,255,255,255,22,"HandelGotDLig:B"," rrGAS_2_NAME","CENTER"
L,329,91,184,35,255,255,255,22,"HandelGotDLig:B"," rrGAS_1_NAME","CENTER"
L,64,93,188,35,255,255,255,22,"HandelGotDLig:B","r rGAS_0_NAME","CENTER"
L,105,10,106,20,255,255,255,12,"HandelGotDLig:B"," =Last Read at:","LEFT"
L,215,10,170,20,255,255,255,12,"HandelGotDLig:B"," rrgas_updated","LEFT"
L,23,134,229,20,255,255,255,14,"HandelGotDLig:B"," rrGAS_0_ADDRESS","LEFT"
L,23,155,229,20,255,255,255,14,"HandelGotDLig:B"," rrGAS_0_ADDRESS2","LEFT"
L,286,155,227,20,255,255,255,14,"HandelGotDLig:B", "rrGAS_1_ADDRESS2","LEFT"
L,545,155,231,20,255,255,255,14,"HandelGotDLig:B", "rrGAS_2_ADDRESS2","LEFT"
B01,534,240,101,39,"SETVAR;StationNum;2||GASNAV||R UN;$rrpath$gasnav.exe|2",
B01,274,242,100,37,"SETVAR;StationNum;1||GASNAV||R UN;$rrpath$gasnav.exe|1",
B01,14,239,96,40,"SETVAR;StationNum;0||GASNAV||RUN ;$rrpath$gasnav.exe|0",
B01,535,455,95,39,"SETVAR;StationNum;5||GASNAV||RU N;$rrpath$gasnav.exe|5",
B01,277,454,95,38,"SETVAR;StationNum;4||GASNAV||RU N;$rrpath$gasnav.exe|4",
B01,15,457,98,36,"SETVAR;StationNum;3||GASNAV||RUN ;$rrpath$gasnav.exe|3",
B01,534,240,101,39,"rrgas_2_showlocation","Refresh "
B01,274,242,100,37,"rrgas_1_showlocation","Refresh "
B01,14,239,96,40,"rrgas_0_showlocation","Refresh"
B01,535,455,95,39,"rrgas_5_showlocation","Refresh"
B01,277,454,95,38,"rrgas_4_showlocation","Refresh"
B01,15,457,98,36,"rrgas_3_showlocation","Refresh"
L,616,27,56,22,233,230,209,14,"HandelGotDLig:B","= SORT",
L,696,17,47,20,233,230,209,14,"HandelGotDLig:B","= CALC",
L,695,41,50,20,233,230,209,14,"HandelGotDLig:B","= TRIP","CENTER"
B,685,0,75,70,"load;gas_calculator.skin;Milage",
B01,0,0,100,75,"rrgas_REFRESH","Refresh"
END
Old 08-11-2008, 10:55 AM   #97
Confusion Master
Enforcer's Avatar
I have no idea why that is doing that. There is no way the plugin does anything to the volume.
And the skin above does not seem to have anything else in that area, so I have no idea.
Sorry
Old 08-11-2008, 11:20 AM   #98
Found it: Your volume slider clickable area is in the same place:
In the attachment you can see the clickable areas better:
Green = rrgas_distance clickable area
Yellow = MASTER volume slider clickable area
Red = MASTER volume slider viewable area
Just change the slider to this:
Code:
S01,303,520,215,45,303,616,215,45,H,01,"",013,"MASTER","Master"
And it will move it beyond the skin region.
It's hard to see this in the skineditor, since it doesn't show the box where the clickable area is, and that's partly why E didn't see it.
To clarify:
S01,303,520,215,45,303,16,215,45,H,01,"",013,"MASTER","Master"
The red coords are the visible location, the blue coords are the clickable location.
Hope that's all it was.
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 08-11-2008, 12:09 PM   #99
Confusion Master
Enforcer's Avatar
Code:
To clarify:
Good spot MR
I didn't see it because I am tired (didn't get any sleep last night), and besides I always forget about the clickable area of the sliders
actually he doesn't need to move the clickable bit of the slider off screen, just put it where it should be
Code:
S01,303,520,215,45,303,520,215,45,H,01,"",013,"MASTER","Master"
BTW, you sorted your sorting yet?
or should I get you the sorting hat?
Old 08-11-2008, 12:27 PM   #100
If I want gas prices for near gryffindor, I'll code it in the sorting hat
I like my method of sorting, but I'll probably put the SAVETOINI method in the hAv1c+ v3 release which is coming soon.
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 08-11-2008, 01:02 PM   #101
lebshiff21 is on a distinguished road
Working great guys, thanks! The only thing I can't get working is the routing via the "MAP" button. When I click it, it does nothing. I'm using the gasnav.exe which was posted in this thread. When I switch to an older version of gasnav, it looks like it might work, but gives me an error:
I'm using IG4 and I believe I have a reshacked version (a friend did it for me, or at least said he did) - I can see the coordinates input screen under the destination menu. Here's my skin file if that makes any difference:
Code:
RoadRunner Skin RRScreen rrgas MENU_EMPTY3.png,traffic_off.png,GPS1_ON.png,GPS1_ON.png /, IMG, X, Y, Width, Height, LAYER IMG,0,0,800,480,"gas_buttons_off.png",OFF IMG,0,0,800,480,"gas_buttons_on.png",ON /, INC, FILENAME INC,LSXCOLORS.txt /, Y, Back Slider file path Y01,"vslider1\slider_*.gif" Y02,"vslider2\slider_*.gif" Y03,"slider_battery\slider_*.gif" Y04,"slider_signal2\slider_*.gif" Y05,"redslider\slider_*.gif" /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip S01,9,440,390,35,9,440,390,35,H,01,"vslider1\pointer.gif",013,"MASTER", S02,399,440,390,35,399,440,390,35,H,02,"vslider2\pointer.gif",013,"SONGPOS", S,480,4,44,20,480,4,44,20,V,03," ",015,"BATTERY_STRENGTH_PHOCO","Battery Strength" S,260,4,44,20,260,4,44,20,V,04," ",15,"SIGNAL_STRENGTH_PHOCO","Signal Strength" /, I, x, y, w, h, Code;INDICATORCODES I06,711,212,50,50,"rrgas_5_icon" I05,455,212,50,50,"rrgas_4_icon" I04,183,212,50,50,"rrgas_3_icon" I03,711,49,50,50,"rrgas_2_icon" I02,455,49,50,50,"rrgas_1_icon" I01,183,49,50,50,"rrgas_0_icon" /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B,0,0,203,39,"MAINBT37",@HOLDMAINBT37@ B,315,0,156,38,"MAINBT38",@HOLDMAINBT38@ B,580,-3,251,42,"rrgas_zipcode" B,155,365,158,75,"rrgas_unleaded","LOWEST" B,312,365,159,76,"rrgas_distance","RANGE" B,470,365,159,75,"rrgas_distancesort","DISTANCE" B01,2,90,257,117,"SETVAR;StationNum;0||GASNAV||RUN;$skinpath$gasnav.exe|0", B01,265,90,255,116,"SETVAR;StationNum;1||GASNAV||RUN;$skinpath$gasnav.exe|1", B01,527,90,253,116,"SETVAR;StationNum;2||GASNAV||RUN;$skinpath$gasnav.exe|2", B01,524,254,257,108,"SETVAR;StationNum;5||GASNAV||RUN;$skinpath$gasnav.exe|5", B01,265,254,253,108,"SETVAR;StationNum;4||GASNAV||RUN;$skinpath$gasnav.exe|4", B01,2,253,259,108,"SETVAR;StationNum;3||GASNAV||RUN;$skinpath$gasnav.exe|3", /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT L,648,393,147,31,#COL1WR#,#COL1WG#,#COL1WB#,#SIZE1#,#FONT1#,"=RELOAD","CENTER" L,5,393,147,28,#COL1WR#,#COL1WG#,#COL1WB#,#SIZE1#,#FONT1#,"=CLOSE","CENTER" L09,13,8,160,27,#COL3R#,#COL3G#,#COL3B#,#SIZE1#,#FONT1#,"rrgas_updated","SCROLL-LEFT" L,321,2,131,31,#COLGR#,#COLGG#,#COLGB#,#SIZE1#,#FONT1#,"= ||GPSSPD","RIGHT" L,468,4,9,30,45,45,45,18,"Arial","=l","LEFT" L,310,4,9,30,45,45,45,18,"Arial","=l","LEFT" L,156,392,156,28,#COL1WR#,#COL1WG#,#COL1WB#,#SIZE1#,#FONT1#,"=LOWEST","CENTER" L,318,392,147,28,#COL1WR#,#COL1WG#,#COL1WB#,#SIZE1#,#FONT1#,"=RANGE","CENTER" L,473,392,154,28,#COL1WR#,#COL1WG#,#COL1WB#,#SIZE1#,#FONT1#,"=DISTANCE","CENTER" L,614,14,77,22,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial:b","=ZIP CODE","LEFT" L,694,8,92,27,#COL3R#,#COL3G#,#COL3B#,#SIZE1#,#FONT1#,"rrgas_zipcode","CENTER" L,718,337,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_5_DIESEL", L,458,338,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_4_DIESEL", L,199,338,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_3_DIESEL", L,719,175,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_2_DIESEL", L,459,175,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_1_DIESEL", L,637,338,77,20,#COL1WR#,#COL1WG#,#COL1WB#,12,#FONT1#,"=Diesel","LEFT" L,377,338,77,20,#COL1WR#,#COL1WG#,#COL1WB#,12,#FONT1#,"=Diesel","LEFT" L,118,338,77,20,#COL1WR#,#COL1WG#,#COL1WB#,12,#FONT1#,"=Diesel","LEFT" L,639,175,77,20,#COL1WR#,#COL1WG#,#COL1WB#,12,#FONT1#,"=Diesel","LEFT" L,378,175,77,20,#COL1WR#,#COL1WG#,#COL1WB#,12,#FONT1#,"=Diesel","LEFT" L,118,175,77,20,#COL1WR#,#COL1WG#,#COL1WB#,12,#FONT1#,"=Diesel","LEFT" L,22,169,77,20,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"=MAP","CENTER" L,22,331,77,20,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"=MAP","CENTER" L,284,169,77,20,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"=MAP","CENTER" L,284,331,77,20,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"=MAP","CENTER" L,543,169,77,20,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"=MAP","CENTER" L,543,331,77,20,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"=MAP","CENTER" L,198,175,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_0_DIESEL", L,718,318,58,19,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_5_PREMIUM", L,458,318,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_4_PREMIUM", L,199,318,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_3_PREMIUM", L,719,155,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_2_PREMIUM", L,459,155,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_1_PREMIUM", L,637,318,77,20,255,0,0,12,#FONT1#,"=Premium","LEFT" L,377,318,77,20,255,0,0,12,#FONT1#,"=Premium","LEFT" L,118,318,77,20,255,0,0,12,#FONT1#,"=Premium","LEFT" L,639,155,77,20,255,0,0,12,"Arial","=Premium","LEFT" L,378,155,77,20,255,0,0,12,#FONT1#,"=Premium","LEFT" L,637,298,77,20,0,157,39,12,#FONT1#,"=Plus","LEFT" L,377,298,77,20,0,157,39,12,#FONT1#,"=Plus","LEFT" L,118,298,77,20,0,157,39,12,#FONT1#,"=Plus","LEFT" L,639,135,77,20,0,157,39,12,#FONT1#,"=Plus","LEFT" L,378,135,77,20,0,157,39,12,#FONT1#,"=Plus","LEFT" L,637,278,77,20,255,255,0,12,#FONT1#,"=Unleaded","LEFT" L,377,278,77,20,255,255,0,12,#FONT1#,"=Unleaded","LEFT" L,118,278,77,20,255,255,0,12,#FONT1#,"=Unleaded","LEFT" L,639,115,77,20,255,255,0,12,#FONT1#,"=Unleaded","LEFT" L,378,115,77,20,255,255,0,12,#FONT1#,"=Unleaded","LEFT" L,553,279,68,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","=Distance", L,288,279,68,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","=Distance", L,29,279,68,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","=Distance", L,555,115,68,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","=Distance", L,297,115,68,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","=Distance", L,29,115,68,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","=Distance", L,118,115,77,20,255,255,0,12,#FONT1#,"=Unleaded","LEFT" L,118,135,77,20,0,157,39,12,#FONT1#,"=Plus","LEFT" L,118,155,77,20,255,0,0,12,#FONT1#,"=Premium","LEFT" L,198,155,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_0_PREMIUM", L,718,298,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_5_PLUS", L,458,298,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_4_PLUS", L,199,298,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_3_PLUS", L,719,135,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_2_PLUS", L,459,135,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_1_PLUS", L,198,135,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_0_PLUS", L,558,303,58,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","rrgas_5_DISTANCE", L,293,304,58,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","rrgas_4_DISTANCE", L,33,304,58,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","rrgas_3_DISTANCE", L,560,139,58,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","rrgas_2_DISTANCE", L,300,140,58,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","rrgas_1_DISTANCE", L,30,139,58,20,#COL1WR#,#COL1WG#,#COL1WB#,11,"Arial","rrgas_0_DISTANCE", L,198,115,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_0_UNLEADED", L,459,115,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_1_UNLEADED", L,719,115,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_2_UNLEADED", L,199,278,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_3_UNLEADED", L,458,278,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_4_UNLEADED", L,718,278,58,20,#COL1WR#,#COL1WG#,#COL1WB#,12,"Arial","rrgas_5_UNLEADED", L,539,254,235,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_5_ADDRESS","LEFT" L,541,266,235,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_5_ADDRESS2","LEFT" L,279,254,234,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_4_ADDRESS","LEFT" L,281,266,234,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_4_ADDRESS2","LEFT" L,17,254,238,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_3_ADDRESS","LEFT" L,19,266,238,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_3_ADDRESS2","LEFT" L,536,90,237,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_2_ADDRESS","LEFT" L,538,102,237,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_2_ADDRESS2","LEFT" L,281,90,231,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_1_ADDRESS","LEFT" L,283,102,231,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_1_ADDRESS2","LEFT" L,585,211,190,35,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"rrgas_5_NAME", L,329,211,183,35,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"rrgas_4_NAME", L,63,211,192,35,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"rrgas_3_NAME", L,586,48,189,35,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"rrgas_2_NAME", L,329,48,184,35,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"rrgas_1_NAME", L,64,48,188,35,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"rrgas_0_NAME", L,21,90,229,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_0_ADDRESS","LEFT" L,23,102,229,20,#COL1WR#,#COL1WG#,#COL1WB#,11,#FONT1#,"rrgas_0_ADDRESS2","LEFT" L,22,437,61,21,#COL3R#,#COL3G#,#COL3B#,#SIZE1#,#FONT1#,"=_","LEFT" L,352,444,34,28,#COL8R#,#COL8G#,#COL8B#,#SIZE1#,#FONT1#,"=+","RIGHT" /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B01,629,365,175,71,"rrgas_refresh", B02,-1,365,156,71,"CANCEL","Cancel" END
Any help would be greatly appreciated! Thanks again for all the hard work.
lebshiff21 is offline   Reply With Quote
Old 08-11-2008, 01:40 PM   #102
What does GASNAV refer to in your exectbl.ini?
It sort of looks like the skin is trying to do two searches at the same time, and the auto-it executable doesn't allow two instances.
I also don't know what your SETVAR;StationNum;X is for, with the newly posted GASNAV (from this post here) you don't need to set the VAR first.
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 08-11-2008, 02:27 PM   #103
I just looked in my exectbl.ini and there's nothing in there for GASNAV
What should my button lines look like for the gas.skin file?
Old 08-11-2008, 02:32 PM   #104
monkey and enforcer , thanks , that is the problem , when i change that number , working perfect now , thanks
Old 08-11-2008, 03:07 PM   #105
MGD , here the gas_options.skin and gas.skin
