Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 08-12-2008, 07:55 PM   #121
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
1st Remove "rrgas_#_fdnavigate" from exectbl.ini
Add buttons with the following commands to the gas.skin
rrgas_0_fdnavigate
rrgas_1_fdnavigate
rrgas_2_fdnavigate
rrgas_3_fdnavigate
rrgas_4_fdnavigate
rrgas_5_fdnavigate
Enforcer is online now   Reply With Quote
Old 08-12-2008, 08:51 PM   #122
Wants to make it harder
monkeyracer's Avatar
monkeyracer is an unknown quantity at this point
rrgas_0_fdnavigate
rrgas_1_fdnavigate
rrgas_2_fdnavigate
rrgas_3_fdnavigate
rrgas_4_fdnavigate
rrgas_5_fdnavigate
He's using hAv1c 2.1, which uses labels with the exec; command instead of buttons for the gas nav, so in the exectbl.ini, go to the section where the gas commands are, after each command, replace them with:
Code:
"GAS0","rrgas_0_fdnavigate" "GAS1","rrgas_1_fdnavigate" "GAS2","rrgas_2_fdnavigate" "GAS3","rrgas_3_fdnavigate" "GAS4","rrgas_4_fdnavigate" "GAS5","rrgas_5_fdnavigate"
hope that helps
2007 Chrysler PT Cruiser TE
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
monkeyracer is offline   Reply With Quote
Old 08-13-2008, 05:38 PM   #123
mikeeps2 is an unknown quantity at this point
i have a litle problem , sometimes when i push the botton refresh or other botton , general is refresh botton , the letters and numbers are duplicated , i dont know why , if any one know , thanks
then i need close RR an open again and working fine
mikeeps2 is offline   Reply With Quote
Old 08-14-2008, 11:04 AM   #124
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
OK, just had a look at these.
The first one unfortunately uses images for the prices, this is what 'broke' the original gas prices.
so both unfortunately are not really suitable.
Is there any way to get text from the jpg picture and use that?
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 08-14-2008, 11:24 AM   #125
Confusion Master
Enforcer's Avatar
You would need to use OCR software.
OPtions are
1. try to download the jpg and use that image as an indicator. (dis : small image might not look good or be readable)
2. try to decode the jpg filename. (dis almost impossible and time cosuming if at all possible)
3. download image and try to OCR it. (extra software required plus extra time to ocr it)
Old 08-22-2008, 06:31 PM   #126
I'm having an issue with 1.4 (unreleased) and the rrgas_gps command, it just doesn't do anything. I have the GPS connected, 6-9 sats showing, and web connectivity, and I get nothing. I registered the .dll, made sure everything was good otherwise.
@john, sonic and thunder - are you guys having this issue too?
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 08-22-2008, 06:48 PM   #127
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
Works as advertised for me. Not using a GPS yet with it though.
ThunderStick is offline   Reply With Quote
Old 08-22-2008, 06:54 PM   #128
Ya, mine was working for everything but the GPS. I know E will be gone for a few days, so it may just have to wait, but if john or sonic aren't having this issue, I'd like to know what to do to fix it.
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 08-22-2008, 06:57 PM   #129
One Sharp Cheddar
Not aware of a rrgas_gps command. Must have missed that release.
Old 08-22-2008, 08:16 PM   #130
did you check your PM's? you're on the list for it:
Quote: Originally Posted by enforcer PM
New Button
...rrgas_gps - use current Lat and Lon from RoadRunner to generate Zipcode and then get prices.
...obviously internet connection is required and also a GPS feed to RoadRunner to test the new button.
...if all is well I will release this as version 1.4.
So, can you see if the update in your PM does anything with the GPS?
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 08-22-2008, 09:22 PM   #131
One Sharp Cheddar
OK I got it, the only thing I dont have a GPS antenna in the house. Ill give it a try tommorrow though, because I will be loading up the new skin in the car gettting it ready for a trial run.
Old 08-23-2008, 09:33 AM   #132
One Sharp Cheddar
I re-did sonicxtacy's gasnav so that it will work with this RRGAS plugin.
here is a link to the thread.
http://www.mp3car.com/vbulletin/rr-p...nav-rrgas.html
Old 08-23-2008, 09:37 AM   #133
have you had a chance to try the rrgas_gps command though?
This is supposed to use the current Lat and Lon to find the zipcode to find the results.
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 08-24-2008, 09:50 AM   #134
One Sharp Cheddar
I cant get my WIFI working in the car, I am going to take another crack at it today.
Do I need a ZIP.DAT in my rr folder for the zip codes?
If so, where do I get it?
Old 08-24-2008, 10:15 AM   #135
I was thinking that might be it... hmm...
here's a post john made about the zips.dat:
Quote: Originally Posted by JohnWPB View Post
the data mentioned above is roughly 70 megs. Thats quite a drag on the system if you have it set to fire the locate command every 60 seconds.
So on a typical 2 hour drive, you are reading 8.4 Gigs from the hard drive.... This should chew up the hard drive pretty fast, as well as probably really slowing the system down a bit.
The compilation of new sources to make the zips.dat more accurate, was not done by enforcer. Wiredwrx put it together, and posted it in the DigitalFX 2.0 thread. You can find it here in post #1945
In post #1960 BlueZX3 creates separate files for each state. This way you can just copy and paste whatever ones you want into the zips.dat file. This can really speed it up when it accesses as it only reads a couple states you put together that you drive frequently, and not all 8 megs with 50 states plus Puerto Rico.
Then in post 1972 meisner wrote a script to take the individual state.dat files and create a zips.dat file of the states that you want.
The in post 1976 meisner created a GUI for the zips.dat builder. Check the states you want, click go, and it creates a zips.dat with the info from the selected states.
In post 1963 Sonic makes mention of movie times (Done since that posting) and local news headlines.... I would like to the see the news one
I tried that, and still no go...
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
