Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-15-2009, 09:24 PM   #136
MyOtherRideIsUr is an unknown quantity at this point
Enforcer: Thank you so much for making this plugin. I got it working today, and as a driver in NYC it is AWESOME! Now I can check out whats going on at the tunnels and bridges and plan my route accordingly. I also installed the gas plugin and was super impressed. I used it today to find and compare prices before filling up.
So I'm not a total mooch, I went back to your site and clicked every ad I found.
Once again, thanks for the great plugins, and I hope you continue your projects.
MyOtherRideIsUr is offline   Reply With Quote
Old 10-15-2009, 10:38 PM   #137
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Thanks for the ad clicks, much appreciated.
Glad they are both working for you.
It's good to have feedback, positive or negative.
Enforcer is offline   Reply With Quote
Old 10-26-2009, 05:10 PM   #138
Dougw133 is an unknown quantity at this point
I know it took long but I have labeled several Philadelphia area Cams as best I could. Here is a text file with them.
Traffic Cameras in philly.txt
Also here is a map of the Philadelphia area cams, but when I pull the map up in RR traffic cams none of the cameras are there.
Dougw133 is offline   Reply With Quote
Old 10-26-2009, 06:49 PM   #139
Confusion Master
Enforcer's Avatar
There are some PA District 11 cameras getting coords in the next DB update.
I'll add those descriptions as well. Cheers
Old 10-26-2009, 09:10 PM   #140
Cool, thanks a lot!
Old 11-04-2009, 04:47 PM   #141
Confusion Master
Enforcer's Avatar
Singapore database updated.
Old 11-06-2009, 02:27 PM   #142
Confusion Master
Enforcer's Avatar
New Portugal Database
Old 11-17-2009, 05:25 PM   #143
bulek is an unknown quantity at this point
Hi,
I just cannot get traffic cams to work with Riderunner and DigitalFx 4.0 skin. It keeps me sending that "if ... don't appear, you need to install internal traffic cams plugin".
Have few basic questions :
- how much time does it take to start ?
- where can one get databases (only UK is attached to release) - for example for Slovenia ? It's mentioned in country codes...
- I'm really confused on different between Traffic International, RRTraffic , etc.... which one is right ?
Thanks in advance,
regards,
Bulek.
bulek is offline   Reply With Quote
Old 11-18-2009, 06:59 AM   #144
Confusion Master
Enforcer's Avatar
The current DFX is designed to use the Standalone Trafficcams (Trafficcams International), although I don't think John released the actual skin files he did for it.
RRTrafficcam is the one to use with RoadRunner/RideRunner, but you will either have to download the BMV2 or iDrive skin files and use them with DFX or design some DFX skins yourself.
How to setup RRTrafficcam in any skin is in the readme.txt
Once you have RRTrafficcam running you can select other databases from a list and they will download automatically (may take a few minutes).
Traffic Cams International v1.3.0 (1.4 Beta available) Enforcer Other Cool Stuff 673 11-06-2009 02:30 PM
