Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-29-2008, 01:17 AM   #31
brandensin is an unknown quantity at this point
blue, any suggestion on how to do this easy? I am trying to make 1920x1080 image for this plugin and i need to move all the labels and resize it accordingly. I can do this one by one, but is there better way? U know, there are so many labels...
brandensin is offline   Reply With Quote
Old 10-29-2008, 01:55 AM   #32
this is the current situation..
Old 10-29-2008, 04:29 AM   #33
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Firstly, that a nice HTPC skin and I don't know if its just me but your days do not look all the same height. Now, um... don't really know what to tell you. Does that skin even FIT in the skin editor..heheheh I just re-aligned Johns calendar, and what was easiest was to only have one group of items in the skin file at a time. Dub the file and then just delete all the grp sections but leave one save edit that one to get it all in correct spots, then cut that section and paste to another temp file. Do that with all the sections till you finish. After, just c&p all the diff sections back in the single skin file and dbl chk that all looks ok.
I know its a ton of items, but its the only way to do this in rr, sorry? Look on the bright side, at least all the lbl's,ind's,ect already have correct code entered.
No Pain, No Gain...
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 10-29-2008, 09:31 AM   #34
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
I guess i'm confused.. which of the two downloads is the most recent version? if i use the rrsched.zip i can get as far as putting a time and an occurence but then the only other option from there is the "back" button.
If i use the RRSched DLL&Skin.zip files nothing works only the skin comes up.
i'm also getting "Subscript Used with Non-Array Variable" autoit error using the demo skin
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 10-29-2008, 10:49 AM   #35
The Curator
Blue ZX3's Avatar
As of this moment, the RRSched.zip is all file, the other is the latest that replaces those to files.
There is no AI in this....so tis something else yellin at you..
I will update the main zip, little later this morning.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-29-2008, 11:55 AM   #36
The Curator
Blue ZX3's Avatar
K, Complete Dll and skin update. Update all of your files from the zip
This CMD ("RRSched_J2Month;x" where x is the month number) will jump right to that month in the current year.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-29-2008, 01:43 PM   #37
Terminal flasher
This is really looking excellent.. far exceeds what my original plan was.
03 Acura RSX Coupe
Old 10-29-2008, 02:02 PM   #38
The Curator
Blue ZX3's Avatar
Thanks!
Would you expect anything less??
And as always, much more to do on this.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-29-2008, 07:36 PM   #39
The Curator
Blue ZX3's Avatar
The "Today" will have two options as how to display the "Today" status. Default will now be to simply wrap the day number in brackets like so "[29]" or using a skin.ini setting of "RRSchedUseBrks=false" will display the "Today" instead of that days number.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-29-2008, 08:42 PM   #40
Sorry about my testing posts guys... damn forum wouldn't allow me to post.. wasn't sure if it was just me or what.... glad everything is back to normal...
now back to topic,
blue, u are right, the heights are inconsistent cuz i don't know how to create evenly divided perfect grid... Any suggestion on that one as well? i'll try to follow ur suggestion for all the label move.
Old 10-30-2008, 04:43 PM   #41
Chuck's Avatar
Chuck is on a distinguished road
so far so good
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 10-30-2008, 05:25 PM   #42
The Curator
Blue ZX3's Avatar
Just take it easy there Chuck...nothing is final yet and probably more changes to the current standards...
I got a big chunk of the timer code done the other day, so its coming along nicely so far...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-30-2008, 11:03 PM   #43
The Curator
Blue ZX3's Avatar
Progress update...
With RR running.....
All of the occurrence modes are now fully working!!
The "ONCE" mode also works as John has described above.
The Calendar is also fully live, meaning that it self updates to the current date 1/min if not current.
Being that the calendar is now live, it does have a side effect. If your browsing around and the min ticks over it will jump you back to current. One way that would be easy to impliment would be to have a calendar "pause" cmd that would allow browsing until your done then just unpause it and it will go back to being live (would have an ind/lbl status too).
Thoughs???
Next to work on will be dealing with and detecting missed events.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-31-2008, 04:25 AM   #44
Chuck's Avatar
Maybe just have it go to the current date when you go in to the calendar like I do in the button.
Code:
"RRCALENDAR","RRSCHED_CAL||RRSCHED_TODAY"
2001 S10 ZR2
Old 10-31-2008, 09:12 AM   #45
Terminal flasher
Quote: Originally Posted by Blue ZX3 View Post
Progress update...
Thoughs???
that sounds good. Should be easly to tell your browse commands to override the Live return feature until the "TODAY" command is executed.
03 Acura RSX Coupe
Tags
calendar, schedular, task
RRMedia Plugin by Blue ZX3 [v1.2.2 Released] Blue ZX3 RR Released Plugins 746 Today 12:58 AM
timer ext plugin now RRsched carputer1 RR Plugins No Longer Supported 77 10-27-2008 11:46 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
