11-05-2008, 04:43 PM
#61
Terminal flasher
same here.. skin loads but labels dont populate.. only today and exit are shown. I've re-registerd and all that stuff too.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
11-05-2008, 04:53 PM
#62
The Curator
Sorry, I made the menu the cal, and forgot to put the "X,RRSched" line.
Just add that. Other than that it should work
11-05-2008, 04:54 PM
#63
The Curator
You also need to change the dat file as that has changed formats again.
11-05-2008, 05:14 PM
#64
So “RRSCHED_CAL” loads the main menu.skin now for the calendar?
11-05-2008, 05:19 PM
#65
The Curator
That just loads the calendar scrn, which i just copies the cal and renamed it to menu.skin
Make sure that your also add to the END of your "ONSKINSTART" cmd this cmd "RRSched_MissedCheck"
11-05-2008, 05:42 PM
#66
Ok the missed events menu came up on start even without the "ONSKINSTART",”RRSched_MissedCheck”.
It has 2 events 1 on 11-3 and 11-1 but in the calendar there is only a event on 11-9 and if I push the 11-9 event in the calendar the menu will not come up like before.
11-06-2008, 11:52 AM
#67
The Curator
The two included events are on the same day "11/9", the dates you are looking at are the next occurace date.
11-06-2008, 01:29 PM
#68
The Curator
Updated..
Ok, I rechecked the cmds and fixed the issues.
With this update it will detect missed events at both startup and when coming out of hibernation/standby which was at least 2 mins or longer.
11-06-2008, 03:43 PM
#69
So missed events do not show up on the calendar?
11-06-2008, 04:00 PM
#70
The Curator
In the case of the two examples, the missed events are really just the x days before reminder, as the actual event is on 11/9.
11-07-2008, 10:39 AM
#71
The Curator
I'll safely assume that with the last update, no news is good news?
11-07-2008, 10:52 AM
#72
i don't see no pop up or reminder...
"ONSKINSTART","RUNq;$SKINPATH$PlayFile\PlayFile.ex e|intro3.mp3||RRSched_MissedCheck"
that's what i have in my exetbl.ini..
11-07-2008, 11:17 AM
#73
Heh.
I'll get back to you...
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
11-07-2008, 11:23 AM
#74
The Curator
In the example dat file, the first date has to be in the same format as what your system setting is. The dat file example format is in a "m/d/yyyy", so if its different then you would just need to change the date format at the begining and end of the lines.
11-07-2008, 11:25 AM
#75
Terminal flasher
is that in the skins exectbl or the main exectbl. If you have ONSKINSTART in both exectbl.ini files then they will cancel each other out sometimes
And everything is working well for me Blue.. keep doin what ya do
03 Acura RSX Coupe
| Thread Tools |
| Display Modes |
Linear Mode
