Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 11-07-2008, 10:13 PM   #76
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Seems to be working okay here...
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 11-08-2008, 12:09 AM   #77
brandensin is an unknown quantity at this point
system shortdate setting : mm/dd/yy
I don't have exetbl.ini file in rr dir..
It used to popup before, don't know why it stopped..
brandensin is offline   Reply With Quote
Old 11-09-2008, 06:46 AM   #78
Chuck's Avatar
Chuck is on a distinguished road
You probably know this but just thought I mention it.
Buttons that speak their commands.
"RRSched_MissedCheck” and of course the buttons that do not do anything yet.
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 11-10-2008, 07:42 AM   #79
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
I don't use speak.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 11-10-2008, 08:50 AM   #80
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
it sounds like to me that an option needs to be added to plugin commands which tells RR whether or not to speak the command.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 11-10-2008, 09:45 AM   #81
The Curator
Blue ZX3's Avatar
I don't understand why it would speak anything with that command as its just a cmd with no params. Usually the ones that end up making RR speak is the ones that have one or more params as by RR std cmd, to make it speak its like the second or third param that gets spoken but certainly not the case with that cmd.
And ya, this needs to be addressed somehow.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-24-2008, 11:34 AM   #82
The Curator
Blue ZX3's Avatar
Small update, added a 5 second delay before the execution of the missed event check. This basically gives rr time to finish up on startup, same thing when resuming from standby or hibernation.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 12-13-2008, 08:40 AM   #83
tolisn's Avatar
tolisn is on a distinguished road
Is there a tutor somewhere so I can setup this plugin?
I placed the "X,RRSched" command in the menu.skin file but the plugin has replaced my main menu and is the first thing that is shown when RR starts. I want to be able to call the plugin with a button press or by taping the screen section where the date is shown. How would I go about doing that?
The road is long but we are getting there.
tolisn is offline   Reply With Quote
Old 12-13-2008, 09:26 AM   #84
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
if you downloaded the plugin from the 1st post , you use it like its another skin, not add it to your exsisting skin, blue set it up so the 1st screen you see is the plugin screen . you need to convert it all over to your using skin, if you want to use it.
carputer1 is online now   Reply With Quote
Old 12-13-2008, 09:32 AM   #85
tolisn's Avatar
Any help on how I would go about doing that so I can use it in my RR skin
Old 12-13-2008, 09:43 AM   #86
THE EXPERIMENTER
carputer1's Avatar
just take all the skin files out of the downloaded plugin add them to your skin ,
X,rrsched to your menu .skin, look in blues readme for the launch cmd, a nd add it to where you want , not at the right comp to specife what that cmd is,
Tags
calendar, schedular, task
RRMedia Plugin by Blue ZX3 [v1.2.2 Released] Blue ZX3 RR Released Plugins 746 Today 12:58 AM
timer ext plugin now RRsched carputer1 RR Plugins No Longer Supported 77 10-27-2008 11:46 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
