02-24-2009, 01:27 PM
#136
The Curator
Found another issue on my end...crap!
Until I release another version change your
"RunningApps_Enabled=True" to "ProcRuningInd_Enabled=True"
That is the reason that it is not working... Try that and then report back.
Carputer1 has asked for a slight modification to the GetMouseColor feature, so I will be posting an update when I get home with the following additions/fixes:
*Comma/period in the static gps settings for the DayNight feature
*One more format for the GetMouseColor, adding a "SC" format to output a RGB in a "xxx,xxx,xxx" format to be a direct replacement for skin file format (carputer1 request)
*Changing the "ProcRuningInd_Enabled" setting that it's looking for to a "RunningApps_Enabled" which is what it should be.
02-24-2009, 01:28 PM
#137
The Curator
Quote: Originally Posted by Enforcer
oi, stop using one of my trademarks
Who are you talkin to and bout what?
02-24-2009, 01:43 PM
#138
Wonderfull !!!!!!!!!!!!!!!!!!!!! I see all indicators ...
Thanks Blue ZX3 . Your are the best !
02-24-2009, 01:57 PM
#139
The Curator
Might I also encourage you to try my RRSpeak instead of the say cmds that you were using ealier. You will not have to so the whole setting of WA's vol as it will auto do that or if using another source, should lower which ever one is current before speaking and returns it back to same after its done
Code:
"ONSTARTQUE.EXE","RRSPEAK;LANCEMENT DE GARMIN MOBILE PC||MENU;QUE.SKIN ||SETLABEL;!WARNING;GARMIN||SETLABEL;!WARNING1;MOBILE PC||WAIT;3||EXIT"
"ONSTARTNOTEPAD.EXE","RRSpeak;LANCEMENT DE NOTEPAD||MENU;NOTE PAD.SKIN||SETLABEL;!WARNING;NOTEP AD||SETLABEL;!WARNING1;NOTEPAD||WAIT;3||EXIT"
"ONENDQUE.EXE",""
"ONENDNOTEPAD.EXE",""
And use these settings
RRSpeak_Enabled=True
RRSpeak_ReduceVolBy=85
02-24-2009, 05:06 PM
#140
Confusion Master
You, using my 'upd8' in your descriptions of things that have been updated.
02-24-2009, 05:16 PM
#141
The Curator
Well, it was the only spelling that was the same length as the other desc's to keep it all nice looking....
02-24-2009, 06:26 PM
#142
Raw Wave
JUST A FYI, of course com cleanup tool runs on VISTA (maybe install .net)
but yr com objects for roadrunner Are not a mess, so dont worry about it
this would be improper use of the program
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
02-25-2009, 12:14 AM
#143
The Curator
v1.0.8 Posted
You know where to look....
02-25-2009, 03:19 AM
#144
THE EXPERIMENTER
02-25-2009, 04:45 AM
#145
Hello Blue Zx3,
I test this morning RRspeak who run very well .
BUT , RRSpeak_ReduceVolBy don't run . I had tested "RRSpeak_ReduceVolBy=20"
and I have the same volume when I listen to music (not reduced).
It is a nice day no?
02-25-2009, 04:57 AM
#146
Readme file error
Blue,
You have not change the settings on the "RRExtended Notes.txt" file for RunningApps .
[RRExtended]
RRExtended_Debug=False
RRWW_Enabled=False
RRWW_Watch1=volume;42;>;Volume
RRWW_Interval=2
RRWW_Snooze=5
RRSpeak_Enabled=False
RRSpeak_ReduceVolBy=75
RRResumer_Enabled=False
RRResumer_Interval=5
RRFob_Enabled=False
RRFob_Last=
RRSkinGen_Enabled=True
DNE_Enabled=False
DNE_DayEventTime=7:00 AM
DNE_NightEventTime=5:45 PM
DNE_Lat=0
DNE_Lon=0
DNE_OffSet=0
DNE_Mode=0
RunningApps_Enabled=False
RunningApps=notpad.exe;excel.exe
02-25-2009, 09:25 AM
#147
The Curator
I did, the "RunningApp_Enable" is the correct setting, I changed right after i corrected the code.
And this "RRSpeak_ReduceVolBy=20" isn't reducing by that much.. this setting is the percent to lower the vol by not what to lower it to and why i suggest the above setting of 85%, which is the same converted percent that you had in your cmds.
Check the RRExt log after you run a RRSpeak cmd and see what we have.
02-25-2009, 10:00 AM
#148
I use the 1.08 version and I confirm that if i have
RunningApps_Enabled=True, I don't see any process
ProcRuningInd_Enabled=True, I see all indicators .
These lines run very with a good reducing volume :
"ONSTARTNOTEPAD.EXE","RRSpeak;LANCEMENT DE NOTEPADE||MENU;NOTEPAD.SKIN||SETLABEL;!WARNING;NOT EPAD||SETLABEL;!WARNING1;NOTEPAD||WAIT;3||EXIT"
"ONENDNOTEPAD.EXE","RRSpeak;SORTIE DE NOTEPADE"
See my debug file .
02-25-2009, 10:28 AM
#149
heh...you've been busy...looking forward to using the latest features...
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
02-26-2009, 11:35 PM
#150
The Curator
Um...
Here we go again....first post...hehehe
| Thread Tools |
| Display Modes |
Linear Mode
