Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 02-28-2009, 03:21 PM   #151
GiODi will become famous soon enough
Great work on the plugin. Anyway you can add functionality to poll an indicator and run a command when it switches?
GiODi is offline   Reply With Quote
Old 02-28-2009, 09:10 PM   #152
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Wash, rinse, & repeat....
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 02-28-2009, 09:13 PM   #153
I think I'm in love.
Old 03-03-2009, 02:26 PM   #154
hugenius79's Avatar
hugenius79 is on a distinguished road
Can someone give me a spoon feed with the IndPoller in this plugin
Im not a programmer but understand some RRcode
I understand what it suppose to do... Help ?
hugenius79 is offline   Reply With Quote
Old 03-03-2009, 03:06 PM   #155
The Curator
Blue ZX3's Avatar
#1 Enable the feature, add/change "IndPoller_Enabled=True" in either rr.ini or skin.ini
#2 Add "IndPoller_Add;MUTE;2;Mute_Ind_Changed" to the end of the "ONSKINSTART" CMD in which ever skin your using, should look like this:
"ONSKINSTART","........||IndPoller_Add;MUTE;2;Mute _Ind_Changed"
Then add the cmd you want to execute ( if more than a single cmd, create a new cmd to execute the multiple cmd via a single cmd) to the exectbl.ini file, like
"Mute_Ind_Changed","Audio||WAIT;2||Load;Audio_brow ser.skin"
Using that example will check every 2 seconds if the "Mute" indicator status has changed. If the status changed, will execute "Mute_Ind_Changed", which will go to the audio screen then wait 2 seconds, then loads the audio browser screen.
Clear enough for you now? I was thinking of making just making a small demo skin that shows more/same examples of how to use some of these great features.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 03-08-2009, 01:32 PM   #156
pierrotm777's Avatar
pierrotm777 will become famous soon enough
Hey Blue,
All run very well BBUUTT, often , the [RRExtended] line is erased on
my rr.ini file , and RRExtended don't run again .
Do you know why ?
pierrotm777 is offline   Reply With Quote
Old 03-09-2009, 02:37 AM   #157
The Curator
Blue ZX3's Avatar
That line is just there to help keep it organized like all the other major sections. Nothing depends on that line being there! So if your having problems, there is something else causing it/them.
And for which ever you problem is always turn on the RRExt debug and check its log. I have tried to log as much as i can when i'm testing it my self and just leave the lines in the code for latter when someone else might be having a problem to hopefully figure out what is causing it.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 04-04-2009, 04:24 PM   #158
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
For the INITOVAR command arent the INI Keys and Values allready Variables?
Just wondering.. I know most of them are.
ThunderStick is offline   Reply With Quote
Old 04-04-2009, 09:10 PM   #159
The Curator
Blue ZX3's Avatar
That cmd would mostly be used for a skin cmd that could set a setting for a outside app that uses a std ini file layout unlike RR's ini layout as there already std RR cmds that deal with the rr.ini and skin.ini files.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 04-30-2009, 07:46 PM   #160
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
At the last Chicago meet, I mentioned I wanted a way to pause my music when I turn my key off and automatically restart when the key is turned back on. Well I was in Atlanta all last week with family who decided to go shopping two days - ALL DAY. My system is setup to turn the screen off 1 minute after losing AC power and in 2 hours suspend. Needless to say we were never in a store long enough for it to suspend, but having to manually PAUSE/RESUME music everytime we got out of the car got old fast. So I got serious about automating this task.
I already have a timer setup that fires every 15 seconds for audiosource label updates and I figured that interval was sufficient for PAUSE/RESUME also. But how? I googled for an external program to do it to no avail. I tried to figure out if a plugin like POWERMON could be modified to do it (unfortunately POWERMON is no longer supported). I tried to create something with RRCode, but didn't get far. I tried EVAL, but that required too much setup and only worked intermittently. Then I looked at RREXTENDED mated with POWERMON. And here is my code:
In EXECTBL.INI add to ONSKINSTART: "SETVARBYCODE;pstate;powermon_powersrc"
//This resets the variables
In EXECTBL.INI add a timer:
Code:
"TIMER","SETVAR;PSTATE1;$PSTATE$||SETVARBYCODE;pstate;powermon_powersrc||SETVAR;ONBATTERY;$PSTATE1$+$PSTATE$||BYSTR;$ONBATTERY$;External+Battery<PAUSE><<Battery+External<RESUME><<<RELOADLIST"
What this does is copy the Power Source label from POWERMON (Battery or External) and creates a variable, ONBATTERY that is a record of the last two states of that label. There are four possible combinations:
External+External - No change still on AC
Battery+Battery - No change still on Battery
External+Battery - Just changed from AC to Battery
Battery+External - Just changed from Battery to AC
The first two fall under the "Else" statement of the BYSTR and fire the RELOADLIST.
Changing from AC to battery means I cut the car off and fires a PAUSE.
Changing from Battery to AC means the key is back on and fires the RESUME.
NO MORE INTERVENTION FROM ME FOR QUICK STOPS. I'm sure this would be helpful to others with laptop installs also. Thanks again Blue ZX3, Festy, and Sal R.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 04-30-2009, 08:14 PM   #161
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Hmm, I just "let the music play". I am not too worried about it starting exactly where I left it.
Obviously if you are listening to audio books or watching a film, I can see where it would be good to pause it.
Enforcer is offline   Reply With Quote
Old 05-07-2009, 04:26 AM   #162
The Curator
Blue ZX3's Avatar
Updated, C #1 Post
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 05-07-2009, 06:05 AM   #163
GpsIndFix_Enabled
Hi Blue Zx3,
I had not found nothing in the notes.txt file for the new option GpsIndFix_Enabled.
How do you use it please .
Old 05-07-2009, 08:01 AM   #164
sxtnitehawk is an unknown quantity at this point
Quote: Originally Posted by Blue ZX3 View Post
-"PresetList" command *new
-"BYRANGE" command *new
History
ver 1.11 [ Released 5/7/09 ]
Added "PresetList" cmd, will use a CL to list all Mixerpresets found in the RR variable $PRESETSPATH$(usually Root\MixerPresets\)
Added "BYRANGE" cmd, more simpler way to execute a cmd if within/out of the specifed range.
i knew i'de be able to help the community in some way
Thank you Blue for all of your hard work
Planning: [|||||||||-] 90%
Purchased: [||||||||--] 80%
Installation: [----------] 0% (awaiting arrival of parts)
sxtnitehawk is offline   Reply With Quote
Old 05-07-2009, 10:13 AM   #165
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Cool.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Volume too low on AUX line in, coming out of laptop. Silenkiller Car Audio 4 10-07-2008 08:45 PM
iPod Integration Coming Lazyflip Centrafuse 2 03-20-2008 01:14 AM
USB Hub not working after coming out of hibernation volum3rider Input Devices 25 09-11-2005 01:07 PM
NEW playstation II portable keyboard coming out soon clean customs Input Devices 3 03-04-2005 04:37 PM
