Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 08-26-2009, 03:49 PM   #211
toxic000 is an unknown quantity at this point
Hello,
can i use the Feature(s)
-LoadFontList or
-GetMouseColor or
-SetFontPV or
-SetFontPVColor
to change a Font and his Color in the Skin for Labels, that have a Variable?
And if yes, how looks the code for this?
toxic000 is offline   Reply With Quote
Old 08-26-2009, 04:14 PM   #212
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
well i use it like this with Blues rrextened version
L01,11,56,86,49,#Rangercol#,#FONTSIZE1#,#Font1#,"= Page 1","WRAP-CENTER",,
i save the values from the color and font stuff to the skin.ini
ie
skin.ini settings
FTCOLOR=255,255,255
FONTSIZE=18
FONTTYPE=Arial
then in your skin file all that have the changes in them i use
/DEFINE FONT1 "$FONTTYPE$"
/DEFINE FONTSIZE1 $FONTSIZE$
/DEFINE Rangercol $FTCOLOR$
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is offline   Reply With Quote
Old 09-04-2009, 01:45 PM   #213
MX6er is an unknown quantity at this point
Global Timer Help
I was hoping someone could point me in the right direction as I am just not getting it
I am trying to use the global timer to auto switch screen to another.
My goal is to have certain screen time out after a 1 or 2 minutes and reload the menu skin
Thanks for any suggestions!
MX6er is offline   Reply With Quote
Old 09-04-2009, 01:54 PM   #214
Valheru's Avatar
Valheru is an unknown quantity at this point
why not just use the IDL command in RR.
In the ExecTbl.ini file add a line like this "IDLE","MAIN",yourscreen.skin ... and just replace yourscreen.skin with the name of the screen you want to time out.
Then in the skin file add the line "IDL,60" as the fourth line of the skin.
Then yourscreen.skin will go back to the main menu after 60 seconds.
The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0
Valheru is offline   Reply With Quote
Old 09-04-2009, 02:04 PM   #215
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
That would be the simpler way to go...
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 09-09-2009, 04:48 PM   #216
Thanks very much! I appreciate the help. The more I learn about RR the more I am amazed at Guido and everyone else who works so hard on this project!!
Old 09-10-2009, 12:20 AM   #217
The Curator
Blue ZX3's Avatar
We don't quote it being #1 for just any ole reason...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 09-10-2009, 10:25 AM   #218
spamminator is an unknown quantity at this point
I'm using the presetList portion of RREX, and I want to have 4 buttons that go along with it: load, save, add, delete. Load and save work fine, and for add I thought all I would need would be:
"OSKTOVAR;SELPRE||!PRESET;$SELPRE$;EQ||PRESETL IST"
which should pop the OSK, take the entered name and save the EQ to that file, then reload the list. But, it seems like RR executes the second part of the command by the time the OSK pops up. So, the first time I click the button and enter TEMP on the OSK, it creates ".pst" as a file, then the second time I click it and enter TEMP2 on the OSK, it saves a "TEMP.pst", because that's the value of SELPRE at the start of the command. Is there a way to serialize the execution of those commands?
Lastly, is there a way from within RR to delete a file?
spamminator is offline   Reply With Quote
Old 09-10-2009, 11:26 AM   #219
The Curator
Blue ZX3's Avatar
You have to use a two seperate cmds to accomplish it.
This will bring up osk and then waits till you either OK it or cancel it. And has to have NO cmds after it, otherwise you'll end up with same results...
"OSKTOCMD;SELPRE;SavePreset"
Extra line for your exectbl file:
"SavePreset","!PRESET;$SELPRE$;EQ||PRESETLIST"
Yes, but you have to use it against a DL list. You can't just use a cmd to delfile;xxx. I believe that I did add a cmd like that allows to just specify a file's path to del...check the rrext doc's.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 09-19-2009, 06:50 PM   #220
Thanks! The OSKTOCMD worked great for adding a new preset.
For the delete, I couldn't find anything that specified a file for deletion in RREXT, but whipped up a quick autoit script to do it for me.
Is there a configurable $PRESETPATH$ anywhere, or is it always hardcoded to $RRPATH$MixerPresets?
Old 09-20-2009, 03:02 AM   #221
The Curator
Blue ZX3's Avatar
Yes, there is a path var $presetspath$ It is not HC'd, you can change it via the SETVAR cmd SETVAR;presetspath;c:\test
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 09-20-2009, 03:40 PM   #222
Couple things regarding the task manager:
- In the documentation, the second half of the labels are prefixed with "TaskMrg...", but I think this should be "TaskMgr...". For example, TaskMrg_CompIP is empty, but TaskMgr_CompIP shows the correct IP.
- I can't get TaskMgr_HomeDrive or TaskMgr_HDrvFree (with either spelling: Mrg or Mgr) to show anything. Do I need to do anything extra to get these to populate?
- When looking at the drive list, I can't jump back to the window list. TaskMgr_ListWindows becomes TRUE, but the CL still shows the drive list. Seems I have to switch to the process list and only then switch to the window list.
- Is it possible to create a label that contains the totals for free and used memory on the system?
Thanks.
Old 09-20-2009, 04:14 PM   #223
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Thanks.
Standard RR labels
FREEMEM
TOTALMEM
PAGEMEM
ALLFREEMEM
ALLMEM
PAGESIZE
Enforcer is offline   Reply With Quote
Old 09-20-2009, 05:28 PM   #224
Quote: Originally Posted by Enforcer View Post
Standard RR labels
FREEMEM
TOTALMEM
PAGEMEM
ALLFREEMEM
ALLMEM
PAGESIZE
For some reason I can get MEM to work, but both ALLMEM and FREEMEM show "RIGOT" in the label in the skin. In skinTool both show the correct values, just in my actual skin it shows up as RIGOT...
L32,610,463,180,25,#LCDR#,#LCDG#,#LCDB#,16,#LCDFon t#,"FREEMEM||=/||ALLMEM","RIGHT"
Any ideas?
Old 09-20-2009, 09:00 PM   #225
Confusion Master
Enforcer's Avatar
try it without the "RIGHT"
Volume too low on AUX line in, coming out of laptop. Silenkiller Car Audio 4 10-07-2008 08:45 PM
iPod Integration Coming Lazyflip Centrafuse 2 03-20-2008 01:14 AM
USB Hub not working after coming out of hibernation volum3rider Input Devices 25 09-11-2005 01:07 PM
NEW playstation II portable keyboard coming out soon clean customs Input Devices 3 03-04-2005 04:37 PM
