Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-30-2009, 08:50 AM   #241
pierrotm777's Avatar
pierrotm777 will become famous soon enough
Hi Blue,
I use this fonction :
RunningApps=gpsexec.exe who run very well.
I have adde an indicator in my menu.skin file:
I,528,33,38,33,"gpsexec.exe:b",300,500.
I think that the blink fonction don't exist in your plugin.
Is it possible to add it in a new release ?
Thanks.
pierrotm777 is offline   Reply With Quote
Old 10-30-2009, 11:29 AM   #242
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
That should handled by RR itself, I might have to look to see if it can deal with PI indicators..
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 10-30-2009, 01:05 PM   #243
Ok ,
Thanks Blue
Old 11-09-2009, 12:42 PM   #244
Toxic0n is an unknown quantity at this point
I am trying to have an alarm set to go when my temperature exceeds a certain threshold. I have added the following to rr.ini
RRWW_Enabled=True
RRWW_Watch1=$COOLANTTEMP$;93;>;Coolant temperature exceeding limits!!!
RRWW_Interval=2
RRWW_Snooze=5
RRWW_Alarm1 = RRSpeak; Coolant temperature exceeding limits
$COOLANTTEMP$ is a variable provided by iBusRR to RideRunner and it shows up fine on a different screen i.e. it returns a numerical value. However, the alarm does not go off and nothing happens when the limit is reached. All I did was run the setup file and then add the above commands to rr.ini. Is there any additional setup that needs to be done?
Toxic0n is offline   Reply With Quote
Old 11-09-2009, 03:24 PM   #245
The Curator
Blue ZX3's Avatar
No, It wasn't coded for var type labels and off the top of my head, I not sure of work around using the RRWW func. But you should be able to use the global timer func, byvar + eval to get the results you want...
Just thru this together so not 100% works as posted, and if not it's got to be close.
Code:
"ONSKINSTART","....||GblTmr_Add;CoolantCheck;2;CheckCoolantTemp" "CheckCoolantTemp","EVAL;result;>($COOLANTTEMP$,93)||BYVAR;result;DoNothing<<CoolantOverTemp" "CoolantOverTemp","RRSpeak; Coolant temperature exceeding limits" .
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-10-2009, 12:11 PM   #246
Code:
Thanks, I will give this a try.
EDIT: That did not work. I added it to rr.ini and I am using DFX 4.0. Do I need to add this the menu.skin file instead?
Volume too low on AUX line in, coming out of laptop. Silenkiller Car Audio 4 10-07-2008 08:45 PM
iPod Integration Coming Lazyflip Centrafuse 2 03-20-2008 01:14 AM
USB Hub not working after coming out of hibernation volum3rider Input Devices 25 09-11-2005 01:07 PM
NEW playstation II portable keyboard coming out soon clean customs Input Devices 3 03-04-2005 04:37 PM
