Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 11-23-2008, 03:49 PM   #46
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
I tried testing your plugin on my desktop and I got an error.
"ActiveX componenet cannot create object" that seems to be related to RRFob. The error does not appear when I set RRFob_Enabled=False.
I get the same error when exiting RR, but I can't pinpoint which of the functions is causing the error.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 11-24-2008, 10:39 AM   #47
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Um...when you log on...I have a newer dll for you...
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 11-28-2008, 07:03 PM   #48
The Curator
Blue ZX3's Avatar
Update..
Plugin Released, see first post.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-28-2008, 08:33 PM   #49
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
WooHoo! Downloading now!
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 11-29-2008, 03:19 AM   #50
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
2nd that
carputer1 is offline   Reply With Quote
Old 11-29-2008, 10:04 AM   #51
Chuck's Avatar
Chuck is on a distinguished road
Looking Good
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 11-29-2008, 04:20 PM   #52
kelmk's Avatar
kelmk is an unknown quantity at this point
Can I use the day/night events to switch the background image?
kelmk is offline   Reply With Quote
Old 11-29-2008, 05:12 PM   #53
The Curator
Blue ZX3's Avatar
You can do that, and any other day/nigth task that might need to be done...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-29-2008, 05:57 PM   #54
kelmk's Avatar
Do you know what the code is to change the background image?
Old 11-29-2008, 06:34 PM   #55
The Curator
Blue ZX3's Avatar
small fix for next version
RRCalc will right align the textbox to look more like a calc is supposed to look and keep the cursor at the right.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-29-2008, 06:38 PM   #56
The Curator
Blue ZX3's Avatar
You can use "SaveToSkin;background;<path to file to use>||Reloadskin".
You will need the reloadskin on the end because rr will use the same set background for each screen once it has been loaded, even if you change it after.
Your example event commands in your Exectbl.ini might look like this.
Code:
"DayTimeEvent","SaveToSkin;background;$RRPATH$BACKGROUND\Day.jpg||Reloadskin" "NightTimeEvent","SaveToSkin;background;$RRPATH$BACKGROUND\Night.jpg||Reloadskin"
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-30-2008, 01:25 PM   #57
THE EXPERIMENTER
carputer1's Avatar
ok from running the risk of getting called dumb again, i'm having problems here
1st off the day/night events, dos'nt seem to do anything,
1: X,RREXTENDED in plugins.txt and plugin in plugin folder (rr Root)
2: have the settings for this section in skin.ini
3: exetbl.ini i have
"DayTimeEvent","RUN;$skinpath$DAY_NIGHT.exe|DA Y"
"NightTimeEvent","RUN;$skinpath$DAY_NIGHT.exe|Nigh t"
"SunSetEvent","RUN;$skinpath$DAY_NIGHT.exe|DAY "
"SunRiseEvent","RUN;$skinpath$DAY_NIGHT.exe|Ni ght"
i'm assuming the the 1st 2 CMD's are for DNE_Enabled= false in skin.ini and the 2nd 2 are for DNE_Enabled= true.
but nothing is happening
2nd problem
RRNumosktocmd i do get the scr appear but the enter button (B,x,x,x,x,RRENTER)
is not working.
i'm using this line to launch
RRNUMOSKTOCMD;1;DAYTIME;SAVETOSKIN;DNE_DayEventTim e;#DAYTIME#
i thank you
Old 11-30-2008, 03:57 PM   #58
The Curator
Blue ZX3's Avatar
No, all four of those are the custom cmds that it executes at those times. The reason you are getting nothing is that your "DNE_Enabled=false" is turning off that feature.
Try setting that to true, other than that, i'm not sure what fall back your using for the time/loc, ie current gps, static gps coords, static time or nothing with will use the hard coded times.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-30-2008, 04:05 PM   #59
THE EXPERIMENTER
carputer1's Avatar
so its 1 or the other execute cmds
the switch yes i was hoping it was to turn off the automatic gps times so the end user can use their own times , which was read from the ini times .
because the gps mouse is on all the time i thought the plugin uses that and the switch ,switchs it off to use the fall back ,
Old 11-30-2008, 07:29 PM   #60
The Curator
Blue ZX3's Avatar
The enable setting completely turns the feature On or Off. As for the fall backs, they are built in and work in the order thats posted. As of current, there is no way to specify which method to use for the time calculation.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Volume too low on AUX line in, coming out of laptop. Silenkiller Car Audio 4 10-07-2008 08:45 PM
iPod Integration Coming Lazyflip Centrafuse 2 03-20-2008 01:14 AM
USB Hub not working after coming out of hibernation volum3rider Input Devices 25 09-11-2005 01:07 PM
NEW playstation II portable keyboard coming out soon clean customs Input Devices 3 03-04-2005 04:37 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
