02-05-2009, 09:36 PM
#91
Having a bit of trouble w/ the "BYSTR" command.
RR v020209
RRE v1.03
Hangs everytime it executes. Here's the snipet of the debug file:
Code:
2/5/2009 6:34:34 PM: Executing: SETVARBYCODE;temp2;LISTTEXT
2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "BYSTR;$temp2$;OTHER<SETCSTR><<NEW<SETNEWF><<BACK<<BTNCFGR><<<SETBTTN", False
2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "setcstr", False
2/5/2009 6:34:34 PM: Que Exec: True, btn_menu.skin, "SETVAR;btnedit;1", False
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Reason: cuz i'm an idiot...
02-09-2009, 02:28 PM
#92
Hi Blue,
Nice plugin. With the DNE section, does this fire off on resume from hibernate ? I'm asking because I don't think the Gamma gets set correctly after a resume with RREXT.
Val.
02-09-2009, 02:57 PM
#93
The Curator
It fires which ever event's time it is anytime that its past that time. That feature only fires off events, for which you have to define what you want RR to execute. If you want to exec a gamma cmd then you have to set that using the custom fired events.
02-09-2009, 03:43 PM
#94
hi blue ...
"DAYTIMEEVENT","SAVETOSKIN;BACKGROUND;$DAYBKGND$|| RELOADSKIN||DAYGAMMA"
"NIGHTTIMEEVENT","SAVETOSKIN;BACKGROUND;$NIGHTBKGN D$||RELOADSKIN||NIGHTGAMMA"
these are my day and night events ... but the gamma doesnt seem to kick in on a resume from hibernate ...
02-10-2009, 08:46 PM
#95
The Curator
C&P only the DNE settings from the rr.ini or skin.ini that you are using along with a debug log. Turn on RR's debug, leave for a day or one hib/res that should have one of those being executed and attach to your post.
02-12-2009, 11:58 AM
#96
Help needed
I Blue ,
This is a ver complete plugin .
I try the RunningApps option .
I have these lines on rr.ini file :
Code:
[RRExtended]
RRExtended_Debug=False
RRWW_Enabled=False
RRWW_Watch1=volume;42;>;Volume
RRWW_Interval=2
RRWW_Snooze=5
RRSpeak_Enabled=False
RRSpeak_ReduceVolBy=75
RRResumer_Enabled=False
RRResumer_Interval=5
RRFob_Enabled=False
RRFob_Last=
RRSkinGen_Enabled=True
DNE_Enabled=False
DNE_DayEventTime=7:00 AM
DNE_NightEventTime=5:45 PM
DNE_Lat=0.000000
DNE_Lon=0.000000
DNE_OffSet=0
RunningApps_Enabled=True
RunningApps=que.exe;notepad.exe
CODE and /CODE before and after on rr.ini file is it necessary or not ?
Do i to add X,RRExtended on Plugins.txt file ?
I had added these lines on my menu.skin file:
I,625,8,47,53,"QUE.EXE"
I,570,12,50,45,"NOTEPAD.EXE"
I had added this line on my Exectbl.ini file :
"ONSKINSTART","CWDSETUP||ONSTARTNOTEPAD.EXE||ONSTA RTQUE.EXE"
I use the last RideRunner version 2/2/2009
I see no indicator .
Where is my error ?
Can you help me please ?
Thanks again
02-12-2009, 12:26 PM
#97
THE EXPERIMENTER
yes you need to add X,RRExtended to plugins.txt if not already there.
its my understanding that the onstartXXX and onendXXX cmds
will show indicator when that app is running, as you have them in the onskinstart , unless the app is running from when you start the skin you won't see any ind show up.
plus how are you have the indcator show , have you used a image, or a label or a graphic in the on skins,
this is my understanding
02-12-2009, 12:36 PM
#98
The Curator
The code & /code was only for posting in the forums, so is not needed in the ini...
Using the latest RR, you really don't need to add any ref to the plugin as long as you have it in either the RR root\Plugins\RRExtended or skinpath\Plugins\RRExtended.
Those lines are correct, as long as there is an on image in that location(s).
"ONSKINSTART","CWDSETUP||ONSTARTNOTEPAD.EXE||O NSTA RTQUE.EXE"
Those (ONSTARTNOTEPAD.EXE & ONSTARTQUE.EXE) are events that get fired when those app start/stop by RRExt. A different example for those would be like..
This line would load the xxx.skin when the notepad.exe process exists
"ONSTARTNOTEPAD.EXE","LOAD;XXXX.SKIN"
This line would load the Menu screen when the notepad.exe process no longer exists.
"ONENDNOTEPAD.EXE","MAIN"
Same actions as above but using the QUE.exe process name.
"ONSTARTQUE.EXE","LOAD;XXXX.SKIN"
"ONENDQUE.EXE","MAIN"
02-12-2009, 02:10 PM
#99
Booooooo
I don't understand,
I had modified the Exectbl.ini file :
"ONSTARTQUE.EXE","LOAD;GMPC.skin"
And Nothing !!!!
02-12-2009, 02:40 PM
#100
The Curator
Only thing else that i can think of would be did you reg the dll by running the _Install.cmd in the plugin folder?
02-12-2009, 06:06 PM
#101
Raw Wave
FYI
X,pluginname
is depreciated, aka not the perferred method
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
02-12-2009, 10:54 PM
#102
The Curator
Updated..
See first post for info.
02-13-2009, 01:26 AM
#103
THE EXPERIMENTER
time to give this 1 another run for its money lol...
02-13-2009, 03:25 AM
#104
I had regitered on the folder's plugins with _Install.cmd .
02-13-2009, 10:11 AM
#105
The Curator
When I re-release v1.0.4, add/change "RRExtention_Debug=true" in your rr.ini. Then startup RR let it run a few...open notepad for a little bit then close..close RR. Attach the RRExtended_debug.txt found in the plugin folder.
| Thread Tools |
| Display Modes |
Linear Mode
