Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 02-19-2009, 02:22 AM   #121
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
If you have the other ones registered then...IDK.
I'm running out of ideas....
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 02-21-2009, 07:02 PM   #122
The Curator
Blue ZX3's Avatar
Update v1.0.6
See first post.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 02-22-2009, 02:15 AM   #123
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
intresting.
carputer1 is offline   Reply With Quote
Old 02-23-2009, 02:13 AM   #124
The Curator
Blue ZX3's Avatar
Dare I say...
Update v1.0.7
See first post
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 02-23-2009, 03:03 PM   #125
THE EXPERIMENTER
carputer1's Avatar
Old 02-24-2009, 08:13 AM   #126
pierrotm777's Avatar
pierrotm777 will become famous soon enough
Pierrotm777 come back !!!
HI Blue Zx3,
I try and try again RRExtended on Vista or XP, and always the same issue .
Nothing .
So I had tried to see if RRExtended.dll is well registered .
I had found this thread :
RR Com Cleanup Tool
but RR Com Cleanup Tool don't run on vista .
I can't use your .cmd for registered the dll .
So , I had found this software :
Emsa Dll Register.
So , on the same thread I had found this link COM Explorer and , wonderfull , I see your dll .
But always same probleme .
Quote:
24/02/2009 13:44:37: Start -- Version: 02/02/2009
24/02/2009 13:44:37: OS Type: Vista
24/02/2009 13:44:37: VMC---> Set object successful
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Front Green In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Rear Blue In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Front Pink In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Rear Pink In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Rear Grey In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Rear Orange In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Rear Black In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "Rear Green In"
24/02/2009 13:44:37: VMC---> SOURCE: Playback Input line: "CD audio"
24/02/2009 13:44:38: Shell: "C:\Program Files\Ride Runner\Gamma\"
24/02/2009 13:44:38: No Phidgets interface detected.
24/02/2009 13:44:38: Plugin Manager: loading Global Plugins...
24/02/2009 13:44:38: Plugin Manager: loading Global Plugins Completed.
24/02/2009 13:44:38: LoadSkin: C:\Program Files\Ride Runner\Skins\Carwings_Dynamic\
24/02/2009 13:44:38: Plugin Manager: loading SkinDir Plugins...
24/02/2009 13:44:38: Plugin Manager: Plugin Found: MovieTimes
24/02/2009 13:44:38: Plugin Manager: Plugin Found: RRExtended plugin found but will be unable to create (most likely NOT registered)[skipped].
24/02/2009 13:44:38: Plugin Manager: Plugin Found: SkinTool
24/02/2009 13:44:38: Plugin Manager: Plugin loaded (SkinDir): MovieTimes
24/02/2009 13:44:38: Plugin Manager: Plugin loaded (SkinDir): SkinTool
24/02/2009 13:44:38: Plugin Manager: loading SkinDir Plugins Completed.
????HHHHHHHHHHHHHEEEEEEEEEEEEEEEEELLLLLLLLLLLLLLPP PPPPPPPPPPPPP??????????
pierrotm777 is offline   Reply With Quote
Old 02-24-2009, 10:09 AM   #127
Humm
I have some news.
I had uninstalled all Ride and Road Runner on my XP partition .
I had too all unregistered with Com Explorer .
I had used CCleaner for to clean my XP .
I had installed just the 2/2/2009 Ride Runner version .
I had registered with the cmd command .
I see your dll on Com Explorer , Well!
I run without your rr.ini option and I have this debug.txt file :
Quote:
24/02/2009 15:59:54: LoadSkin: C:\Program Files\Ride Runner\Skins\Carwings_Dynamic\
24/02/2009 15:59:54: Plugin Manager: loading SkinDir Plugins...
24/02/2009 15:59:54: Plugin Manager: Plugin Found: MovieTimes
24/02/2009 15:59:54: Plugin Manager: Plugin Found: RRExtended
24/02/2009 15:59:54: Plugin Manager: Plugin loaded (SkinDir): MovieTimes
24/02/2009 15:59:54: Plugin Manager: Plugin loaded (SkinDir): RRExtended
24/02/2009 15:59:54: Plugin Manager: loading SkinDir Plugins Completed.
If I add your rr.ini file , RRextended don't run .
Old 02-24-2009, 10:17 AM   #128
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
oi, stop using one of my trademarks
Enforcer is offline   Reply With Quote
Old 02-24-2009, 10:20 AM   #129
Ookkk
I had found than if i add all your options , the plugin don't run (rr.ini or skin.ini) !
If I add just these lines it is ok :
Quote:
[RRExtended]
RRExtended_Debug=True
RunningApps_Enabled=True
RunningApps=que.exe
But , I have no indicator !
And for the first time , I have a RRExended_debug.txt file with that:
Quote:
24/02/2009 15:58:04: RRSkinGen_Initz
24/02/2009 16:15:23: RRSkinGen_Initz
24/02/2009 16:16:31: RRSkinGen_Initz
24/02/2009 16:16:31: ---->Window Hooked
24/02/2009 16:16:31: ---->Window UnHooked
24/02/2009 16:16:47: ---->Window UnHooked
Is it good ?
Old 02-24-2009, 10:37 AM   #130
The Curator
Blue ZX3's Avatar
Thats better... if you could slowly add the option lines one at a time till you see that it causes that prob, and let me know which one it was so that i can take a look so that someone else might not have these issues that you were having..
After a little bit while running RR you should see some lines like this in the RRExt debug log, and if not you still have a prob somewhere...
2/19/2009 12:38:31 AM: Doing ProcessExists
2/19/2009 12:38:31 AM: ----->Checking if QUE.EXE IS RUNNING
2/19/2009 12:38:31 AM: -----> QUE.EXE IS NOT RUNNING
AND/OR
2/19/2009 12:38:31 AM: -----> QUE.EXE IS RUNNING
AND/OR
2/19/2009 12:43:34 AM: ----->Status: QUE.EXE HAS STARTED
2/19/2009 12:43:34 AM: ----->Status: Executing > ONSTARTQUE.EXE
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 02-24-2009, 11:36 AM   #131
Last news
With these lines (all) , RRExtended run very well :
Quote:
[RRExtended]
RRWW_Enabled=False
RRWW_Watch1=volume;42;>;Volume
RRWW_Interval=2
RRWW_Snooze=5
RRSpeak_Enabled=False
RRSpeak_ReduceVolBy=75
RRResumer_Enabled=False
RRResumer_Interval=5
RRFob_Enabled=False
RRFob_Last=
RRSkinGen_Enabled=True
DNE_Enabled=false
DNE_DayEventTime=7:00 AM
DNE_NightEventTime=5:45 PM
DNE_Lat=45,253865
DNE_Lon=-0,266360
DNE_OffSet=0
RunningApps=que.exe;notepad.exe
But I don't see any indicator !
On ExexTbl.ini file, I had added these lines :
Quote:
****************** RREXtended **************************
"ONSTARTQUE.EXE","SETVOL;WINAMP;255||MENU;QUE.SKIN ||SAY;LANCEMENT DE GARMIN MOBILE PC||SETVOL;WINAMP;40||SETLABEL;!WARNING;GARMIN||SE TLABEL;!WARNING1;MOBILE PC||WAIT;3||EXIT"
"ONSTARTNOTEPAD.EXE","SETVOL;WINAMP;255||MENU;NOTE PAD.SKIN||SAY;LANCEMENT DE NOTEPAD||SETVOL;WINAMP;40||SETLABEL;!WARNING;NOTEP AD||SETLABEL;!WARNING1;NOTEPAD||WAIT;3||EXIT"
"ONENDQUE.EXE",""
"ONENDNOTEPAD.EXE",""
On my menu.skin I have these lines who replace "online" and "phoco..." indicators (just for a test):
Quote:
I,575,10,47,53,"NOTEPAD.EXE"
I,624,9,47,53,"QUE.EXE"
Old 02-24-2009, 12:10 PM   #132
The Curator
Blue ZX3's Avatar
Well now that you have gotten this far do you see any of those lines in the rrext log now?
And what were those two lines set to before? 0.0000000?
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 02-24-2009, 12:20 PM   #133
Yes , I had retried on my Vista partition the same modification :
DNE_Lat=45,253865
DNE_Lon=-0,266360
and RRExtended run very well :
Code:
24/02/2009 18:16:39: Start -- Version: 02/02/2009 24/02/2009 18:16:39: OS Type: Vista 24/02/2009 18:16:39: VMC---> Set object successful 24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Front Green In" 24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Rear Blue In" 24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Front Pink In" 24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Rear Pink In" 24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Rear Grey In" 24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Rear Orange In" 24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Rear Black In" 24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "Rear Green In" 24/02/2009 18:16:39: VMC---> SOURCE: Playback Input line: "CD audio" 24/02/2009 18:16:40: Shell: "C:\Program Files\Ride Runner\Gamma\" 24/02/2009 18:16:40: No Phidgets interface detected. 24/02/2009 18:16:40: Plugin Manager: loading Global Plugins... 24/02/2009 18:16:40: Plugin Manager: loading Global Plugins Completed. 24/02/2009 18:16:40: LoadSkin: C:\Program Files\Ride Runner\Skins\Carwings_Dynamic\ 24/02/2009 18:16:40: Plugin Manager: loading SkinDir Plugins... 24/02/2009 18:16:40: Plugin Manager: Plugin Found: MovieTimes 24/02/2009 18:16:40: Plugin Manager: Plugin Found: RRExtended 24/02/2009 18:16:40: Plugin Manager: Plugin Found: SkinTool 24/02/2009 18:16:40: Plugin Manager: Plugin loaded (SkinDir): MovieTimes 24/02/2009 18:16:40: Plugin Manager: Plugin loaded (SkinDir): RRExtended 24/02/2009 18:16:40: Plugin Manager: Plugin loaded (SkinDir): SkinTool 24/02/2009 18:16:40: Plugin Manager: loading SkinDir Plugins Completed.
But I don't see any indicator .
Old 02-24-2009, 12:38 PM   #134
The Curator
Blue ZX3's Avatar
K, now I see the issue... the old comma/period thing. I will add a check for this and get that fixed in the next update.
I was asking about the RRExtended_Debug.txt. we now know that the PI is getting loaded so I don't care about RR's debug log anymore. Delete it ("RRExtended_Debug.txt") and then restart up RR, let run for a few and then post some of the "RRExtended_Debug.txt" contents..
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 02-24-2009, 01:05 PM   #135
This is my last RRExtended_debug.txt file:
24/02/2009 19:02:19: RRSkinGen_Initz
24/02/2009 19:02:19: ---->Window Hooked
24/02/2009 19:02:19: ---->Window UnHooked
24/02/2009 19:03:34: ---->Window UnHooked
Volume too low on AUX line in, coming out of laptop. Silenkiller Car Audio 4 10-07-2008 08:45 PM
iPod Integration Coming Lazyflip Centrafuse 2 03-20-2008 01:14 AM
USB Hub not working after coming out of hibernation volum3rider Input Devices 25 09-11-2005 01:07 PM
NEW playstation II portable keyboard coming out soon clean customs Input Devices 3 03-04-2005 04:37 PM
