Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-28-2008, 01:09 PM   #1
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
RRExtended [ v1.14 Updated 7/26/09 ]
This is a both a HUGE collection of very useful cmds and a combination of all my smaller plugins, all in one plugin.
Feature Set
-RRCalc
-RRStrings
-RRSpeak (Curr ver req Sapi5)
-PlayWav
-RROSKTOCMD
-RRNUMOSKTOCMS
-RRFileCopy
-RRFileMove
-"ONSCREENCHANGE"
-DayNightEvents from my other plugin
-RRWarningWatcher
-RRResumer
-"BYSTR" Cmd
-RRVolRamper (req's RoadRunner build 10/10/08 or latter)
-RRFob
-RRFileMgr
-RRSkinGen
-RRHostWatcher
-RRPlyr
-TxtBoxToVar
-RunningApps ( from my other plugin and upgraded )
-ProcWaitClose
-IniKeyToVar
-VarToIniKey
-FileSrchRepl
-Global Timer(s)
-LoadFontList
-GetMouseColor
-SetFontPV
-SetFontPVColor
-IndPoller
-GpsIndFix ( from my other plugin )
-"PresetList" command
-"BYRANGE" command
-"BYSCRN" command
-"BYLBL" command *new
-TaskManager *new
-ElaspedTmr *new
-DateOSK *new
-TimeOSK *new
History
ver 1.14 [ Released 7/26/09 ]
Added Task Manager feature
Added ElaspedTmr feature
Added DateOSK feature, has two main cmds, "DateOSK" & DateOSKToCMD"
Added TimeeOSK feature, has two main cmds, "TimeOSK" & TimeOSKToCMD"
Added "BYLBL" command, works like the BYSCRN, simplifies rr cmds into one
Added Starting point for the plugin Demo Skin
Fixed "BYRANGE", was putting cmd to exec at the end of RR cmd que instead of doing a direct replacement of the "BYRANGE" cmd
Fixed Few Commands that would return a ONCOMMANDINVALID on a valid RRExtended cmd
Upd8d Plugin notes, added some missing info
ver 1.13 [ Released 6/24/09 ]
Added "BYSCRN" cmd, more simpler way to execute a cmd(s) if specified screen matches current.
ver 1.12 [ Released 5/11/09 ]
Added optional parameter to the "BYRANGE" CMD, allows for within,below,above specified range cmds
Added Missing GpsIndFix Notes
Added Sample GpsIndFix indicator images(iG Style)
Upd8d "BYRANGE" cmd notes
ver 1.11 [ Released 5/7/09 ]
Added GpsIndFix from my other plugin to this one
Fixed DNE, now also sets the RR lastsunmode variable when the sun mode changes
Added Additional DNE Debug Logging Info
Added New plugin Initialize method
Added "PresetList" cmd, will use a CL to list all Mixerpresets found in the RR variable $PRESETSPATH$(usually Root\MixerPresets\)
Added File check to PlayWAV cmd, keeps windows from playing default sound if/when file specified doesn't exsits
Added "BYRANGE" cmd, more simpler way to execute a cmd if within/out of the specifed range.
ver 1.10 [ Released 2/28/09 ]
Added IndPoller, indicator watcher that executes a cmd on ind status change
Fixed RunningApps, would not enable if only one app was listed to be watched
Upd8d RRExtended_Debug, will refresh its debug log on every run if enabled, setting old log to "RRExtended_Debug.old"
Fixed RRPlyr, Media song position slider, now is zero if no media loaded.
ver 1.09 [ Released 2/26/09 ]
Added SetFontPV, realtime font preview using a std RR label
Added SetFontPVCOLOR, realtime font color preview using a std RR label
ver 1.08 [ Released 2/24/09 ]
Upd8d GetMouseColor, now has a "SC" format too "R,G,B"
Fixed RunningApps_Enabled setting
Fixed Comma/period in the static gps settings for the DayNight feature
ver 1.07 [ Released 2/22/09 ]
Added LoadFontList, loads a CL with installed fonts
Added GetMouseColor, get color under mouse when executed
Added Example skins for above features
Upd8d Added some extra debuging to Global timers
Fixed Global Timer names, allows only one instance of each timer name
ver 1.06 [ Released 2/21/09 ]
Added Global Timers, Add/Del/Start/Stop/Reset
ver 1.05 [ Released 2/16/09 ]
Upd8d FileSrchRepl, added a parm to specify what char(s) to use if the search or replace strings contain the "||" chars.
ver 1.04 [ Released 2/12/09 ]
Added IniKeyToVar, reads from a standard ini file,a section key to a var
Added VarToIniKey, writes a var to a standard ini file's section key
Added FileSrchRepl, allows a search/replace on a txt file
Added RRStrings_SplitStr, split a string/var by a specified char(s)
ver 1.03 [ Released 2/2/09 ]
Fixed RRNumOskToCmd, not working properly
Fixed RREnter, now clears osk textbox on exit
Added DNE_Refresh cmd, to use the current saved settings w/o reloading skin (Req by chuck)
Added DNE_Enable cmd, realtime on/off of feaure w/o saving setting
Added TxtBoxToVar cmd, sets a var from the contents of a textbox
Added RRCalc_Func label, displays current function
Added RRPlyr, simple media player for wav/wma/mp3 files
Upd8d to the latest plugin standards.
Added RunningApps, creates ind's and custom events for running process
Added ProcWaitClose, halts cmd execution till specified process no longer exists, also w/ timeout
Ver 1.02 Updated 12/16/08
Fixed DNE settings issue, had to have all setting whether used or not
Fixed RRSpeak issue, Had to do the an issue in the RR ActiveSourceID feature
Added Hidden feature to be released after further testing.
Ver 1.01 Updated 12/6/08
Fixed DNE_Enabled setting issue
Added DNE_Mode for setting which fall back to use
Version: 1.00 Release date: 11/28/08
Initial plugin release
See the RRExtended Notes.txt for feature cmds & syntax's
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 10-28-2008, 01:52 PM   #2
MGD
MGD's Avatar
MGD is on a distinguished road
* RRSpeak *
Description
Functions the same as the internal cmds execpt that it can be set independantly of RR's voice setting.
Main reason for this was to make a work around for when RR starts saying all the executed cmds instead of
only speaking when told to speak.
Commands
"RRSpeak"
Syntax: "RRSpeak;<phrase to speak> or <ON>,<OFF>"
Example: "RRSpeak;Road Runner, welcome to thee number 1 front end!"
Result: Phrase spoken
Example: "RRSpeak;<ON>"
Result: Turns on RRSpeak for speaking and saves setting
You can do that already with the TALK command. Turn Voice off in rrconfig and use TALK instead of SAY. Only problem is the volume. TALK Command is overlaid. Are you planing on lowering the volume of other sources when RRSpeak is executed?
MGD is offline   Reply With Quote
Old 10-28-2008, 02:03 PM   #3
The Curator
Blue ZX3's Avatar
Well, I wasn't aware of the diff Talk/Say, but could do something to fix/add said issue.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-28-2008, 02:39 PM   #4
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Cool.
For RR Calc, can you add a "tickertape" feature?
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 10-28-2008, 02:46 PM   #5
The Curator
Blue ZX3's Avatar
When I revise that func, I'll see. Output to a CL? Could then save for latter if wanted.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-28-2008, 02:51 PM   #6
Sal R.'s Avatar
A CL is what I figured.
Old 10-29-2008, 11:49 AM   #7
Chuck's Avatar
Chuck is on a distinguished road
Blue do you think you could add a command called ONSKINCHANGE similar to ONSONGSTARTso when you go from skin to skin it would trigger it. You could use it for many things such as every time you go to a skin or exit from another skin to that skin you could have that trigger like.
Code:
"ONSKINCHANGE","Showwindow;windowname;true||MUTE||SETLABEL;MESG;gogo”,Clock.Skin "ONSKINCHANGE","PlayWav;$RRPATH$GAME\GAME.MP3",GAME.Skin
Would be nice if it was in RR it self but this woud be a good place for it.
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 10-29-2008, 01:17 PM   #8
The Curator
Blue ZX3's Avatar
That can and will be added, but called "ONSCREENCHANGE" and will be executed (before/after?) the "LOAD" or "MENU" cmds.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 10-29-2008, 01:37 PM   #9
Chuck's Avatar
I guess it would be after the load or menu or when “RRSCREEN” name changes so it would trigger after going into or after exiting a skin.
“ONSONGSTART” triggers after the song changes
2001 S10 ZR2
Old 11-07-2008, 02:07 PM   #10
The Curator
Blue ZX3's Avatar
Ok, this now executes a "ONSCREENCHANGE" when loading,exiting,escaping,canceling on any screen.
Also RRCalc will have a TicketTape via a customlist
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-07-2008, 02:17 PM   #11
Chuck's Avatar
Thank you Thank you Thank you
is the day/night thing going to be in this or the calendar?
2001 S10 ZR2
Old 11-07-2008, 03:10 PM   #12
The Curator
Blue ZX3's Avatar
I did think about adding it to the Calendar but after thinking about it, decieded not to. As fairly simple as it is, I may just add it to this as its more like the already built in auto-skin/gamma funcs and this is a collection of basic rr like cmds.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-09-2008, 06:19 AM   #13
Chuck's Avatar
I think this would put this plugin over the top.
Do stuff like this and always have it over write and wait for copy to complete before executing the next command.
Code:
"FILECOPY" "BACKUPRRINI","FILECOPY;$RRPATH$rr.ini;$SKINPATH$BACKUPFOLDER\rr.ini" "RESTORERRINI","FILECOPY;$SKINPATH$BACKUPFOLDER\rr.ini;$RRPATH$rr.ini||RELOADRR" "DAYSKIN","FILECOPY;$SKINPATH$DAYFOLDER\*.*;$SKINPATH$*.*||RELOADSKIN" "NIGHTSKIN","FILECOPY;$SKINPATH$NIGHTFOLDER\*.*;$SKINPATH$*.*||RELOADSKIN" "ALLPLUGINSOFF","FILECOPY;$SKINPATH$PLUGINFOLDER\PLUGINSOFF.TXT;$SKINPATH$PLUGINS.TXT||RELOADSKIN"
2001 S10 ZR2
Old 11-10-2008, 02:57 PM   #14
The Curator
Blue ZX3's Avatar
"RRFileCopy"
"RRFileCopy;<SOURCE>;<DESTINATION>"
WILL OVERWRITE ANY/ALL FILES IN DESTATION
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-10-2008, 03:52 PM   #15
Chuck's Avatar
Goody Goody Goody
Now when can I try it
2001 S10 ZR2
Volume too low on AUX line in, coming out of laptop. Silenkiller Car Audio 4 10-07-2008 08:45 PM
iPod Integration Coming Lazyflip Centrafuse 2 03-20-2008 01:14 AM
USB Hub not working after coming out of hibernation volum3rider Input Devices 25 09-11-2005 01:07 PM
NEW playstation II portable keyboard coming out soon clean customs Input Devices 3 03-04-2005 04:37 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
