Go Back   MP3Car.com > Mp3Car Technical Software > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 12-15-2008, 11:12 AM   #1
Wanted's Avatar
Wanted is an unknown quantity at this point
Thumbs up IBUSServiceRR - IBUS Interpreter like IBUSCOMM
Hi all, i wrote this little prog that can help anyone who uses CarPC in BMW with Steering Wheel Buttons, because sometimes IBUSCOMM crashes randomly and some other problem's like double act on VOL+ VOL- presses. Now it's fixed (i hope)))))
It absolutely the same as IBUSCOMM but with/without some functions.
Realised at now:
0. Written as Windows Service!!! Full crash and restart support. Error Logging!
1. All messages that reside in IBUSCOMM are interpreted.
2. NO Shutdown timer (IBUS Idle timer) if someone nedds i can wrote...
3. NO support of Wildcards in IBUS Messages Templates. (Who need?)
4. NO Amp Emulation at now.
5. BMW CDPlayer requests supported. Auto reply. As in IBUSCOMM
6. Settings in .ini file the same as in IBUSCOMM but little changes:
6.1 [RTSwitchScreens] - Section. U can add more Screen changes for R/T key press
RTSwitchScreens=True - (RT Button Switch Screens True/False)
RTScreen1=AUDIO from RTScreen1, RTScreen2 .. to .. RTScreen[n] i think 255 is good)))
RTScreen2=GPS
RTScreen3=CAMERA
7. Added RepeatInterval parameter in Message Templates section (for any Button) u can setup an Repeat Interval wich program needs to wait before react again to this button!
8. LOG File is Placed in directory with IBUSService.exe max size is 1Mb. When size exceeds - log is cleared.
Installation Instructions:
Extract all files from archive to any folder on your HDD.
place MSCOMM32.OCX into C:\WINDOWS\SYSTEM32 folder
Press Start->Run...
Run this command: regsvr32 C:\WINDOWS\SYSTEM32\MSCOMM32.OCX
press OK
Press Start->Run...
type: cmd [press enter]
type: cd [type full directory with IBUSService] [press enter]
FOR INSTALL SERVICE:
type: IBUSService /install [press enter]
FOR UNINSTALL SERVICE:
type: IBUSService /uninstall [press enter]
Start->Settings->Control Panel->Administration->Services
Select 'IBUS Receiver Service' press Right Mouse Button, press Properties in float menu.
Start type set to 'Auto'. Press Apply settings. Right mouse click->Start. Thats all!
All settings and parameters values u can find in .ini file it is the same as i IBUSCOMM. Thx Franck for good program.
i think that's all for now. Feel free to try/use it and say something here about
P.S. I hope my English is not awful
15/12/2008 Moscow
Wanted is offline   Reply With Quote
Advertisement Sponsored links
Old 12-16-2008, 06:51 AM   #2
Wanted's Avatar
Fixed RRSwitchScreen settings. Now fully work.
Old 12-25-2008, 09:34 AM   #3
Asterix1965's Avatar
Asterix1965 is an unknown quantity at this point
hello,
I installed Ibusservice and I must say that finally I don't have more crash.In future will be possible to have the features available type temperature readings on ibuscomm? I hope I will because some functions are very nice to be included in the skin. Thanks for the work done so far.
Asterix1965
Asterix1965 is online now   Reply With Quote
Old 12-25-2008, 09:50 AM   #4
Wanted's Avatar
Quote: Originally Posted by Asterix1965 View Post
hello,
Asterix1965
Hi.
I think it possible, it depends on my free time only
In future i'll try to fully implement cooperation with RoadRunner!
Old 12-25-2008, 11:34 PM   #5
efun is an unknown quantity at this point
Can someone make a CAN-BUS service for current BMW model?
efun is offline   Reply With Quote
Old 01-05-2009, 01:54 PM   #6
Wanted's Avatar
Why do you need CAN-BUS? Buy I-BUS adapter and all will be fine!
Old 01-05-2009, 09:01 PM   #7
My car was BMW 3 Series E90 (made in 2007.03), it used CAN-BUS. Does I-BUS adapter support this car?
Old 01-09-2009, 06:16 AM   #8
Wanted's Avatar
Yeah, if you can do it by yourself you can make IBUS-2-COMport adapter.
Schema is here http://forum.pccar.ru/showpost.php?p=72085&postcount=32
It's simple, just 7-8 elements and it done! Or you can buy Reslers interface!
Old 01-09-2009, 08:28 AM   #9
Thanks wanted! There are many such products (CAN-BUS reader) in the market, so read the data from bus is easy, but it is not easy to find the packet pattern of BMW CAN-BUS in internet.
Old 01-09-2009, 08:45 AM   #10
Wanted's Avatar
Maybe, i really don't know anything about CAN-BUS in BMW so i can't help. Sorry
Old 02-17-2009, 04:08 PM   #11
swordfishunter is on a distinguished road
any updates on getting speed / temps etc?
swordfishunter is offline   Reply With Quote
Old 02-17-2009, 05:15 PM   #12
Wanted's Avatar
Nope, i don't have much time for it. Maybe later.
Old 02-27-2009, 07:22 AM   #13
tobmag is an unknown quantity at this point
I have that one there allready, used by Navcoder so I dont think I can use your file as well? any suggestion?
BR//Tobmag
tobmag is offline   Reply With Quote
Old 02-28-2009, 07:14 AM   #14
I changed to your dll but I cant get it to work anyway. Everything installes OK but I cant get any comunication with the Ibus, changed the com port fom 7 to 1 which I use but still nothing. Any suggestion?
BR//Tobmag
Old 03-02-2009, 02:53 AM   #15
Wanted's Avatar
BR//Tobmag
Do you register new dll with regsvr32 ???
Is it work's with another IBUS processing software?
Going to make a BMW e46 IBus HOWTO, need a kickstart Fmstrat Newbie 12 11-10-2008 06:55 PM
IBusCom / IBuscomM / IBusRR -- HELP!!! Marc-X RR Plugins 7 04-16-2008 11:23 AM
Freeice, girder and Ibus woes kelmk Input Devices 0 04-11-2008 08:05 PM
Ibuscomm and Girder ringltangbob Input Devices 0 09-07-2007 05:23 PM
Hi from a noob, and a couple of questions primarily re e46 bmw IBUS integration stuthemong Road Runner 3 02-06-2007 05:40 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
