Quote: Originally Posted by
HuntingKnightSM
How is this plugin coming?
Pretty well, I havent worked on the GPS Alarm feature for about a month because I just havent had the time. Dont worry though I will continue with it soon.
upspace
Facing several problems
1. I get the EULA again and again although confirmed
2. There is no EULA for german, so I copied the English one
3. Trying to import a Trapster file in the setup.exe, I receive AutoIt Error, Line-1: Error: Subscript used with non-Array variable
(1) You allways get the EULA when opening the Setup program
(2) There may not be a german language file in your EULA folder check for german.lng.
If it is missing copy the english.lng file and rename it german.lng
Sorry german may not be supported.
(3) Again this is an issue with german selection.
How this works is it finds you default windows language selection. Then uses the language file in speedzone according to your windows default language.
Copy the english.lng file and rename it to german.lng, then copy the eula.english file and rename it to eula.german. This should fix the problem. It will be all in english but will be operational.
I have added a check for this in the next version which will default to english if no language file is present for your default windows language.
SPEEDZONE program also had the same problem with language autoselection. German is supported there but did not let you select a different language than the autoselection. This bug has also been fixed.
Quick fix in first post
