Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
View Poll Results: I want these features added
GeoCaching - Users can share GPS COORDINATES for GEOCHACE 8 27.59%
Automatic Trapster Downloads and Zone Updates - (INTERNET REQUIRED) 13 44.83%
Stand Alone Version - Not Dependent on RR for anything 8 27.59%
Skinnable Stand Alone Version 11 37.93%
Import Speed Zones to Garmin POI 10 34.48%
More RR integration (Indicators, Label Codes & what ever) 14 48.28%
Dynamic Settings Changer 6 20.69%
Works while GPS Screen is active in RR 15 51.72%
Multiple Choice Poll. Voters: 29. You may not vote on this poll
Old 08-08-2009, 04:02 AM   #76
pierrotm777's Avatar
pierrotm777 will become famous soon enough
Quote: Originally Posted by ThunderStick View Post
Tell you the truth, I havent.. It is still a theory. It may work. Create a zone and just include geocache in the name. When this zone is entered it will display a scrolled map on your screen. The idea eventually will be to allow users to share these zones and use them to mark landmarks, points of interest or other things you would like to share.
Kind of like a geocache club that uses a handheld GPS for a treasure hunting like game.
This eventually will work the same way.
Not sure how well it is working yet, but it should notify you when entered. Eventually if enough interest is generated we could maybe get a facebook thing going to support sharing the GEO CACHE zones. Who know where this will go, was just a fun idea I thought I would add....
To share poi or track is a very good idea.
But all guys use different Gps programs, (Garmin,Igo8,Sygic7.71,etc...).
Each program have his track and poi format.
Its is important to have a good translator for a best compatibility .
A good link to share Geocaching : Geocache.com
pierrotm777 is offline   Reply With Quote
Old 08-08-2009, 12:03 PM   #77
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
THis would have to be used with SpeedZone for geocahing
Maybe not though. It would be simple enough to translate GPS coordinates, the hard part is working with an internet server, creating a subscription system and having realtime use of the GeoCache information from the internet.
Honestly though, if all you wanted to do is share GPS coordinates and enter them in to SPeedzone this is a pretty simple task.
ThunderStick is offline   Reply With Quote
Old 08-08-2009, 12:11 PM   #78
One Sharp Cheddar
Small update,
AutoTrapster fix. 07AUG09
Old 08-11-2009, 01:53 AM   #79
CannonBaller is an unknown quantity at this point
Did you ever get this working?
Sorry haven't had the time until now.
I went over all the settings and install instructions, everything looks fine.
Still the same thing. Speedzone starts, opens the GPS app, and then comes back with that "-1....." error. Thats when the Speedlimit.exe app terminates.
As you say i can send you a copy of my whole RR folder. Problem is that is 108MB. Maybe i should send you an email with an FTP link where you can download it. Yea its big, but everything in there is needed. I even cut down the zones files to only 100 entries for testing.
if your profile supports emailing, i will send you my FTP and email details.
CannonBaller is offline   Reply With Quote
Old 08-11-2009, 09:31 PM   #80
One Sharp Cheddar
Drop me a PM, with the link. I will download when I get time.
Not sure what is going on.
Old 08-12-2009, 12:17 AM   #81
One Sharp Cheddar
I think I may have found the issues.. Not sure when this started but give me some time on this one.
In the mean time set your GPS comport correctly in RR as well. You will need to use a comport splitter such as XPORT.
It should work then.
Ill report back soon with a fixed version.
Old 08-12-2009, 08:49 AM   #82
One Sharp Cheddar
Found problem, will update first post after build
It was a problem with the GeoGate.. GO FIGURE
CHECK FIRST POST FOR FIXED VERSION
Old 08-12-2009, 10:38 AM   #83
Yea...now its working.
- Ok so Jun17 exe, still throws the error.
- The May1 exe works no problems so far. (speedlimit.exe v3.2.8.1)
So looks like a bug starting from your June release.
PS
i am using XPort and also tried direct comm to it.
Same results.
Old 08-12-2009, 11:05 AM   #84
One Sharp Cheddar
I foudn the bug, check first post in later on to download the fixed version.
GEO GATE issue.
Old 08-12-2009, 11:17 AM   #85
One Sharp Cheddar
OK Bugs fixed and new version uploaded...
Old 08-12-2009, 01:16 PM   #86
Well...i just updated and tested with the full Aug 12 release.
The error is still there.
So again i put the May1 Speedlimit.exe back in, and no problems.
Old 08-12-2009, 01:25 PM   #87
However....for the May1 exe.
As soon as i exit RR, that error pops up.
But doesn't seem to be any isssues so far while RR is running.
(btw speedlimit.exe stays running the whole time RR is).
So not sure if that helps.
And i will be testing the May1 exe a little later today when i get on theroad.
So far only been stationary.
Old 08-12-2009, 03:13 PM   #88
Bad translated french file
Can you to change your EULA\french.lng file by mine please .
The translation is better .
File Type: zip french.zip (819 Bytes, 5 views)
Old 08-12-2009, 08:59 PM   #89
One Sharp Cheddar
Speed Limit does not check for RR constantly, so the reason you get that error is because RR closes and Speedlimit is trying to communicate with it. There really isnt much I can do for this. In the future there will be a plan for this. But for now it really isn't a problem.
Old 08-12-2009, 09:53 PM   #90
Well thats for the May1 exe. And i got a chance to test it today on the way back form work. It stayed active even after returining from hibernate.
And i received a few alerts, so all good.
However you Aug 12 release does not work at all.
As soon as RR starts, Speedzone splash screen comes up, the GPS app loads, and right after that the -1 error pops up as usual, which kills the speedlimit.exe.
I even tried to hit the START button to reload it again, with no luck.
It just seems like for some reason the speedlimit.exe app is not communication with RR at some point during the initiation process.
Only build i can get to succesfully work is the May1.
So right now. I have your latest Aug 12 release running, but with the May1 speedlimit.exe.
I will post up my zipped RR folder for you.
New Age Garmin - FINAL RELEASE 01OCT09 ThunderStick RR Released Skins 136 11-06-2009 11:02 PM
RELEASE: Map Monkey v1.1.3 Ninja Monkey Map Monkey 163 02-12-2009 11:27 AM
Speed Limit / Speed Zone Plugin RELEASED ThunderStick RR Plugins 54 12-20-2008 02:03 AM
New OBDII scantool - Beta testers? tmort Engine Management, OBD-II, Engine Diagnostics, etc. 173 01-08-2008 07:44 PM
Hacking into Fan speed switch... Dexter Hardware Development 10 07-12-2005 12:11 PM
