View Poll Results: I want these features added
GeoCaching - Users can share GPS COORDINATES for GEOCHACE
8 |
27.59% |
Automatic Trapster Downloads and Zone Updates - (INTERNET REQUIRED)
13 |
44.83% |
Stand Alone Version - Not Dependent on RR for anything
8 |
27.59% |
Skinnable Stand Alone Version
11 |
37.93% |
Import Speed Zones to Garmin POI
10 |
34.48% |
More RR integration (Indicators, Label Codes & what ever)
14 |
48.28% |
Dynamic Settings Changer
6 |
20.69% |
Works while GPS Screen is active in RR
15 |
51.72% |
08-13-2009, 01:02 AM
#91
One Sharp Cheddar
Ill try out what I got in the car in the morning.
Truly, my carpc project has been on the back burner for a while. So there are probably some bugs with the speed zone code that need to be worked out.
08-15-2009, 10:48 PM
#92
So I'm assuming you were able to download OK then.
I also sent you a PM with the DEBUG log results.
08-16-2009, 01:26 PM
#93
One Sharp Cheddar
Sorry still unable to download from your FTP server..
Try the latest relese in the first post or from mediafire.
I did find a ton of problems in the code this morning.
I can't believe all that I am finding now...
Anyway.. let me know how this works.
Should be good. I think ive said that before.
08-17-2009, 12:00 AM
#94
Probably because your IE is still in FTP PASive mode. If you uncheck it, it will dwld, no probs.
And i just tried your Aug16 on my test system. So far so good. This could be the one!!
I'll be putting this in my car tommorrow, let you know how it goes.
08-17-2009, 12:02 AM
#95
On another note.
Is there any chance of being able to edit some of the non-user spoken warnings.
(example: the overspeed warning)
Or is this hard coded and too difficult to implement?
08-17-2009, 08:25 AM
#96
One Sharp Cheddar
Quote: Originally Posted by CannonBaller
On another note.
You can edit any of the text the program uses by editing the language files.
Using notepad to edit english.lng, you can edit line 18 through 27. THese lines are used for the over speed limit warnings.
08-19-2009, 10:25 PM
#97
One Sharp Cheddar
Releases are on hold until bugs are worked out...
08-20-2009, 02:44 PM
#98
So what i the latest release Aug16 or Aug19?
Also...(i will test again tonight)
The Aug16 Speedlimit.exe, it doens't actually track anythiing.
(eg does not call out zones or overspeeds)
I had to go back to the May 1 release.
I'll give you some more bug details later.
08-20-2009, 11:23 PM
#99
One Sharp Cheddar
I got a version now, but I am having trouble with being able to change speed limits.
That is the only issue I have right now.
Release coming SOON...
08-22-2009, 01:06 PM
#100
One Sharp Cheddar
UPDATE:
-Fixed the bugs and releaed a new version.. EVERYTHING should work as advertised now
-Auto Trapster updated to accomodate changes to trapster website
08-23-2009, 02:22 PM
#101
Setup stop after Merci
Hi Tunderstick,
Setup stop after the first GUI .
- no files languages .SETUP found in /Language folder .
- the 17/08/2009 setup.exe file run well but not the 22/08/2009 .
08-23-2009, 08:32 PM
#102
One Sharp Cheddar
Just use the setup from 17/08/09.. Not too sure what happened here with the 22/08 version. Found this out today.
08-23-2009, 08:39 PM
#103
One Sharp Cheddar
BUGS found in 22 AUG 09 version
Setup program error - Use a previous release that works.
Not leaving a home zone after entered - Just delete you home zone for now
08-23-2009, 08:58 PM
#104
One Sharp Cheddar
Quote: Originally Posted by pierrotm777
Hi Tunderstick,
You could also try just copying the .stp files in the Language folder to .setup files.
This should fix this problem as well.
I was working on organizing the language files and I must have missed a few things.
Sorry about this... By the way, your french language file is now included.
08-23-2009, 09:42 PM
#105
One Sharp Cheddar
Ok, squashed the bug with setup. Just a language file issue, NO MORE
Flattened the bug that would not allow you to exit a home zone and also fixed another bug that was miss numbering Zone names in the Zone Name List.
Anyway, I truly think this is it. I cant think of anything else that is wrong.
LMK of any other bugs found. Release in first thread 23AUG09PM
| Thread Tools |
| Display Modes |
Linear Mode
