Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
View Poll Results: I want these features added
GeoCaching - Users can share GPS COORDINATES for GEOCHACE 8 27.59%
Automatic Trapster Downloads and Zone Updates - (INTERNET REQUIRED) 13 44.83%
Stand Alone Version - Not Dependent on RR for anything 8 27.59%
Skinnable Stand Alone Version 11 37.93%
Import Speed Zones to Garmin POI 10 34.48%
More RR integration (Indicators, Label Codes & what ever) 14 48.28%
Dynamic Settings Changer 6 20.69%
Works while GPS Screen is active in RR 15 51.72%
Multiple Choice Poll. Voters: 29. You may not vote on this poll
Old 09-01-2009, 10:51 AM   #121
pierrotm777's Avatar
pierrotm777 will become famous soon enough
Quote: Originally Posted by ThunderStick View Post
Oh yeah,
The Graphical User Interface will be completely skinnable using RR's skin editor. It has it's own label and command set (about 30 different labels and 20 different commands).
I can't wait
pierrotm777 is offline   Reply With Quote
Old 09-02-2009, 09:16 PM   #122
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
The standalone version will not be for use with RR and may not be able to embed it yet either.
So far it is a truly standalone solution.
The RR version (what is currently available) will be the best one to use if using RR.
ThunderStick is offline   Reply With Quote
Old 09-10-2009, 04:58 PM   #123
Toxic0n is an unknown quantity at this point
Tried to get this working, but as soon as I added the lines from the text file with the instructions to the main execbtl.ini, all my button labels have disappeared. I am using the Digital FX skin. As soon as I deleted the lines, I can see my labels again.
Also, how long does it take to download the trapster file? I setup the autoupdater with my logon information, it seemed to connection successfully and then was stuck at "Downloading zones files" for about 10 minutes before I gave up. This was over my iPhone's 3G connect.
Sorry if the wording is not exact, I tried this about two weeks ago so I may not remember what it said exactly.
Toxic0n is offline   Reply With Quote
Old 09-10-2009, 05:26 PM   #124
CannonBaller is an unknown quantity at this point
I ran into the same issue. Eventuall I figured i out.
Check my post(#65) in this threat
http://www.mp3car.com/vbulletin/rr-p...ml#post1333230
Basically the DFX4 skin can ony have one ONSKINSTART command. The reason your buttons are disappearing is because you added a new ONSKINSTART. So the other one wont execute.
You'll see in my post, that all you have to do is setup a new command variable, then add the command to the orginal ONSKINSTART line.
(I just noticed a slight error in the my post, seems there is an extra space in between the "SPEE DZONE". ignor it, there are no spaces. must be "SPEEDZONE")
CannonBaller is offline   Reply With Quote
Old 09-10-2009, 09:06 PM   #125
Thank you, I will give this a try!
Old 09-24-2009, 06:41 PM   #126
One Sharp Cheddar
DOWNLOAD AutoTrapster updater from here
the version included in the download from the first post does not work correctly
Use the new AutoTrapster updater instead of using the setup program for adding trapster zones for now on. Internet connection required
Old 10-06-2009, 05:53 AM   #127
I Thunderstick,
In Europe and specially in france the road traffic sign are different that you in US .
Is it possible to add an option in speedzone to see the traffic sign like in france .
I give you a link : Road France Traffic Sign
Is it possible also to have a saved picture of a zone that you save and when you return in this zone to post the image of this saved zone ?
Old 10-07-2009, 05:02 AM   #128
One Sharp Cheddar
IF you go in to the images folder in the speedzone folder you can change any of those you want.
Old 10-07-2009, 05:04 AM   #129
One Sharp Cheddar
The speedlimit signs will have to be about the same dimensions because Speed Zone places labels on top of the images for the actual speed limits.
Old 10-07-2009, 06:39 AM   #130
No problem because in EU the speed limit are a red circle with a black number and a white background .
New Age Garmin - FINAL RELEASE 01OCT09 ThunderStick RR Released Skins 136 11-06-2009 11:02 PM
RELEASE: Map Monkey v1.1.3 Ninja Monkey Map Monkey 163 02-12-2009 11:27 AM
Speed Limit / Speed Zone Plugin RELEASED ThunderStick RR Plugins 54 12-20-2008 02:03 AM
New OBDII scantool - Beta testers? tmort Engine Management, OBD-II, Engine Diagnostics, etc. 173 01-08-2008 07:44 PM
Hacking into Fan speed switch... Dexter Hardware Development 10 07-12-2005 12:11 PM
