Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
View Poll Results: I want these features added
GeoCaching - Users can share GPS COORDINATES for GEOCHACE 8 27.59%
Automatic Trapster Downloads and Zone Updates - (INTERNET REQUIRED) 13 44.83%
Stand Alone Version - Not Dependent on RR for anything 8 27.59%
Skinnable Stand Alone Version 11 37.93%
Import Speed Zones to Garmin POI 10 34.48%
More RR integration (Indicators, Label Codes & what ever) 14 48.28%
Dynamic Settings Changer 6 20.69%
Works while GPS Screen is active in RR 15 51.72%
Multiple Choice Poll. Voters: 29. You may not vote on this poll
Old 01-23-2009, 09:36 PM   #1
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
Thumbs up SpeedZone w/GPS Position Alarm - GPS POSITION TRIGGER - 28SEP09
Quick Description 28SEP09
-Triggers pre-defined events based upon GPS position--
Trapster Supported Zones, Sample skins included, Dynamic Zone Perimeter Size, UnLimited Zones, iList support, Setup Program for easier setup, Can be used with any skin, Lots of Additional Indicators and Label Codes, Spoken Messages, Popup Messages, Email Capable Car Alarm System, Execute command line and RR command and LOTS LOTS MORE...
Recommended Computer Specs
CPU - P4 1.5ghz or greater
MEMORY - 512 mb
Hard Drive Space - 35mb (Trapster zone files can get larger than 20mb)
30 AUG 09 ALL THE BUGS FIXED.. SEE BELOW
DETECTS YOUR POSITION MONITORS YOUR SPEED and EXECUTES COMMANDS BASED ON GPS INFORMATION
Feature updates will be released in a beta release before an actual release will be made.
Beta releases available from link in 2nd post.
CLICK HERE
[MEDIA]http://www.youtube.com/watch?v=LzG5wsHmMFg[/MEDIA]
YouTube preview 5 APR 2009
CURRENT RELEASE: 28SEP09
-ONLY Ride Runner Supported
-Uses very little data from RR
-Speed Zones (TRULY UNLIMITED)
-Easy Skinning
-Faster Setup
-One touch zone entry
-Speed Zone Commands
-Speed Zone Popup messages
-Speed Zone Descriptions
-Spoken Messages in RR
- Car moving indicator
- GPS found indicator
- In a zone indicator
- Speed Trap Indicator
- Monitoring Indicator
-iList used for Zone Listings
-Delete Zones from with in RR
-Set any speed limit you wish
-Excellent Zone Detection
-Same name for multiple zones
-SPEED TRAP SETTINGS -Just include speed trap (or your language equivalent) in your zone name
(NO POPUPS, EXECUTE EXTRA SPEEDTRAP COMMAND,CHANGES SPEED LIMIT, ANNOUNCED AS "THIS IS A KNOWN SPEED TRAP AREA, DRIVE CAREFULLY")
-SPEED LIMIT CHANGE ONLY - Just include speed limit (or your language equivalent)in your zone name
(NO ANNOUNCEMENTS WITH CHANGE)
-HOME ZONE DETECTION - Just include home (or your language equivalent) in your zone name
(Announces "home zone detected', extra long wait after detection, command for home zone only executed once while in zone)
-BUG FREE (I HOPE)
-MULTIPLE LANGUAGES (Thanks pierotm777)
-PAUSE AND RESUME MONITORING
-IMPORT TRAPSTER.COM ZONES TO YOUR SPEEDZONES
-Excellent zone management
-Dynamic Zone Perimeter adjustments according to traveling speed and zone processing speed. (This improves zone detection a lot)
-ZONE SPECIFIC TONES
-unlimited zones
-GUI setup program (Trapster importer, Setpoint updater, Set a default speed limit, Easy Language Setup)
-Zone Diagnostic Screen (Displays time it took to scan all zones, How many zones it counted, How many zones you passed through, zone perimeter size in feet)
-Srolling Zone Messages (scrolls a message from bottom to top of skin when a zone is entered)
-Include GEOCHACHE in your zone name and it will display a GEOCACHE symbol when entered. This type of zone is not direction sensitive. 19APRIL2009
-Will scan over 1000 zones in less than .5 seconds. Now that is what we want
-Using a GPS interface instead of RR fo GPS INFO
-GUI multilanguage Setup Program
-Pauses when stopped in a zone
-Built in text to speech (REQUIRES SAPI)
-Calibrate Speed Zone for specific use with your GPS reciever (this will improve zone detection quite a bit)
-A lot more Label Codes
-If on the zones.skin screen, Speed Limit will jump the zone list to the zone you have just entered
-AUTO Trapster Updates - Included with download
-GEOGATE Feature - If a geogate zone is entered it asks for a password, if incorrect password is given it will log your GPS position, time and date then transmit that log attached to an email to your email address when an internet connection is available.
FUTURE
SKINNABLE STAND ALONE VERSION - WILL NOT USE RR (STARTED April 18th 2009, FINISH who knows... This will be a toughy)
-GEOCACHE - 50% (in beta version 23april2009)
-ZONE SPECIFIC TONES(coming soon)
-ZONE SPECIFIC WARNING IMAGES (coming soon)
-Automatic Configuration according to RR settings
Trapster - IMPORTING USING SETUP
(ENGLISH ONLY FOR NOW)
UNLIMITED TRAPSTER and OTHER ZONES
(a) Download the location points
from trapster.com
(b) Name the file to trapster.csv and copy to the speed zone folder
(c) RUN Setup.exe from speedzone plug in folder and import using the TRAPSTER IMPORT buttons on the menu.
(d) Wait this may take a while for large trapster files and if you have a previous import done.
Trapster - Auto Updater
DOWNLOAD AND IMPORT TRAPSTER ZONES AUTOMATICALLY
This is NOT a final release of my Formerly known as Speed Zone pluggin.
I renamed it because it is much more capable than simply detecting speed now.
Now it will make announcements, execute any command and remind you of speed limits based on position. It will also notify you of the default set speed limit selected by the user. There are an unlimited number of speed zones that can be set to announce reminders and trigger commands executed through RR or from command line.
It will trigger the speed zone when you are with DYNAMICALLY CONTROLLED ZONE PERIMETER and headed in the same direction you were heading when you set the zone.
For more information read the documentation that comes with the download and use the example skin to modify to your liking.
The source will not longer be released unless you have a Very good reason to have it.
IF YOU ARE INTERESTED IN CREATING A LANGUAGE FILE PM ME
Current Languages Available
ENGLISH (By:Thunderstick)
EBONICS (By:Thunderstick)
SPANISH (GOOGLE TRANSLATED)
GERMAN (GOOGLE TRANSLATED)
ITALIAN (GOOGLE TRANSLATED)
FRENCH (By: pierotm777)
Major Bug Fix for the Setup.EXE as of version 02AUG09
Auto Trapster Bug Fix, 07AUG09
MAJOR BUG FIX RELEASE 22AUG09
BUG FREE 27AUG09, FINGERS CROSSED
UPDATE
26SEP2009 - Setup.exe, Speedcommander.exe and Speedlimit.exe updates
24SEP2009 - Fixes to AutoTrapster not including previous zones when updating Trapster zones
29AUG09 - Changes made to accommodate slower or less powerful computers
PREVIOUS DOWNLOADS AVAILABLE CLICK HERE
DOWNLOAD AutoTrapster updater from here
the AutoTrapster version included with the 30AUG09 release does not work correctly
Use AutoTrapster updater instead of using the setup program for adding trapster zones for now on
The 24SEP2009 version works great, and has the new Auto Trapster included
As of 26SEP09 you can use setup.exe to update and import zones.
Last edited by ThunderStick; 09-28-2009 at 10:07 PM. Reason: Bug found with pause and start command...FIXED
ThunderStick is offline   Reply With Quote
Advertisement Sponsored links
Old 01-26-2009, 09:10 AM   #2
One Sharp Cheddar
Post Beta news
WHEN UPGRADING - READ THIS IMPORTANT -
REQUIRES SAPI
(1) BACKUP your zones.csv and zondata folder
(2) ERASE OR DELETE all of the previous files and folders in your speed zone folder except your speedzone.ini, zones.csv and zondata folder
(3) COPY all of the files and folders except speedzone.ini from the downloaded zip file to your speed zone folder
(4) RUN setup.exe in your speed zone folder
(5) PRESS save button and exit setup
(6) START RR and enjoy
This will ensure that everything is working correctly and is all up to date.
ALLWAYS READ THE README.TXT and Run the Setup.EXE when updating,
this changes alot
Old 02-27-2009, 08:57 PM   #3
One Sharp Cheddar
Wink BUG Tracker
IF YOU FIND A BUG OR ARE HAVING PROBLEMS PLEASE REPORT IT
BUGS FOUND
24SEP09 - The included version of autotrapster removed all non-Trapster zones when updating.
30AUG09 - 29AUG09 Version very slow - Fixed
-Message not resetting after car starts moving again - fixed <-------------------FINAL BUG
29AUG09 -OVERSPEED indicator not coming on - FIXED
- Not detecting trapster zones very well - FIXED
27AUG09 -GPS interface setting speed units to KNOTS - FIXED
-OVERSPEED warnings not working - FIXED
-Not deleting zones correctly - FIXED
-Not pausing when stopped - Fixed
-Zone warning images not moving to center screen - Fixed
-Not leaving trapster or Geogate zones - Fixed
-Getting an error message when RR closes - FIXED
23AUG09 - Setup program error (FIXED 23AUG09PM)
- Not leaving home zone (FIXED 23AUG09PM)
- Not Numbering zone names correctly on zone name list (FIXED 23AUG09PM)
16AUG09 - OMG TONS OF BUGS FOUND - SHOULD BE GOOD NOW 16AUG09
09AUG09 - GEOGATE causing a Line-1 error. Fixed 14AUG09
03AUG09 - GEOGATE not handling passwords correctly. FIXED 03AUG09 Release
01AUG09 - Import and Update button in Setup.exe not working right, FIXED Read the REadme.txt for instruction.
16JUN2009 - Auto Language screwing up when language file not available. - Now defaults to ENGLISH if autolanguage file selection not found - HOTFIX in post 1
05MAY2009 - CALIBRATIONS are not sensitive enough - FIXED 07MAY2009 version
29APR2009 - Descriptions not setting correctly - FIXED
22APR2009 - Speed zone direction not reporting "NORTH" correctly - Fixed in 23APR2009 version
11APR2009 - Speed limit opening with more than one instance - Fixed
11APR2009 - Not Adding descriptions - Fixed
11APR2009 - Not allways recieving GPS information from RR - Fixed
29MAR2009 - Speed limit returning to default speed limit after leaving a zone - Fixed in release 29MAR2009B
29mar2009 - Language files missing entries - fixed 29mar2009
29MAR2009 - TRAPSTER importer adding to list not working - fixed 29mar2009
27MAR2009 - After detecting a trapster zone not resetting when zone is left - Fixed 27mar2009
27MAR2009 - Indicators not working - Fixed 27mar2009
27mar2009 - To many zones caused zone detection errors - Fixed 27mar2009
23MAR2009 - Language Files incorrect GPS Direction label. East is South and South is East. They got switched. - Fixed 27mar2009release (You may have to erase all of you east and south bound zones unless you edit them manually)
23MAR2009 - Speed Zones not changing speed limit - fixed for next release
21MAR2009 - Adding Zones, FIXED 21 MARCH 2009
11MAR2009 - Deleting a zone not working, FIXED 21 MARCH 2009
09MAR2009 - Announcing incorrect zone name when you enter a zone. FIXED and release 11mar2009 PM
Old 03-07-2009, 07:32 PM   #4
One Sharp Cheddar
Smile Special thanks
SPECIAL THANKS TO
CannonBaller - TESTING
pierrotm777 - Helping with multi-language setup
Last edited by ThunderStick; 08-29-2009 at 02:00 PM. Reason: Changing Reason for post
Old 03-08-2009, 08:54 PM   #5
Flyingboat's Avatar
Flyingboat is an unknown quantity at this point
Reading about this plugin makes me salivate.
Could this be used to trigger outputs to a Fusion Brain for suspension adjustments?
Yes, I'm a NOOB
Flyingboat is offline   Reply With Quote
Old 03-08-2009, 11:04 PM   #6
One Sharp Cheddar
It can basically run any command
Old 03-08-2009, 11:13 PM   #7
One Sharp Cheddar
bug found,
wasnt announcing correct zone name when entered. problem solved.. fixed version relased.
Old 03-11-2009, 01:11 AM   #8
One Sharp Cheddar
Big bugs in first few days of release, working good now though as of 11mar09
Old 03-13-2009, 02:36 AM   #9
One Sharp Cheddar
NEXT RELEASE COMING SOON
-SPEED TRAP SETTINGS (Just include speedtrap in your zone name)
-SPEED LIMIT CHANGE ONLY (Just include speedlimit in your zone name)
-HOME ZONE DETECTION (Just include home in your zone name)
-BUG FREE (I HOPE)
Old 03-20-2009, 04:55 AM   #10
pierrotm777's Avatar
pierrotm777 will become famous soon enough
I had just downloaded your 11/3 version .
I translate it as soon as and upload it
pierrotm777 is offline   Reply With Quote
Old 03-21-2009, 01:47 PM   #11
One Sharp Cheddar
Major bug fixes
Multi-Language Support
One touch speed zones
Pause and Resume Monitoring
lot's more....
read first post
Old 03-22-2009, 12:55 PM   #12
One Sharp Cheddar
trapster now supported
Old 03-23-2009, 09:11 AM   #13
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
i'll test the trapster support today~! Thanks!
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 03-23-2009, 10:13 AM   #14
One Sharp Cheddar
Now if I can only find out how to get GPS data directly from USB post instead of polling from RR... HMMMM..
anyone that can help with this..
Old 03-28-2009, 05:54 PM   #15
One Sharp Cheddar
Major update, lots of bugs fixed. No known bugs remaining
New Age Garmin - FINAL RELEASE 01OCT09 ThunderStick RR Released Skins 136 11-06-2009 11:02 PM
RELEASE: Map Monkey v1.1.3 Ninja Monkey Map Monkey 163 02-12-2009 11:27 AM
Speed Limit / Speed Zone Plugin RELEASED ThunderStick RR Plugins 54 12-20-2008 02:03 AM
New OBDII scantool - Beta testers? tmort Engine Management, OBD-II, Engine Diagnostics, etc. 173 01-08-2008 07:44 PM
Hacking into Fan speed switch... Dexter Hardware Development 10 07-12-2005 12:11 PM
