Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 10-29-2009, 05:25 PM   #586
l1nk's Avatar
l1nk is an unknown quantity at this point
Quote: Originally Posted by lambosprit View Post
This is a screenshot of what it looks like when working. Notice the green circle above the conn button. This indicates that RR has connected with your phone successfully.
Is this a real screenshot? I have the same nokia model but can't see battery and signal slider...
l1nk is offline   Reply With Quote
Old 10-29-2009, 07:32 PM   #587
lambosprit's Avatar
lambosprit is on a distinguished road
It is but this nokia model doesn't output the battery and signal codes so it defaults to 5 bars. You have to have images with the correct name in the folder you specified in your ini file. Or if your using the new slider code you have to have valid sliders in your skin but if you're using the same phone you'll just get the 5 bars I'm afraid.
lambosprit is offline   Reply With Quote
Old 10-30-2009, 04:32 PM   #588
l1nk's Avatar
Ok, so it's correct. I haven't graphic bars (don't know why, I'll check) but I have the numeric values on the skin and both shows "5", even if on the display phone they aren't to the max!
Tried also with an n95 8gb but no success.
Anyone knows some cheap phone with battery and signal support on bluetooth connection?
Old 11-02-2009, 10:13 AM   #589
MGD
MGD's Avatar
MGD is on a distinguished road
moto old razr did that on phonecontrol.net from Zorro, should work on this one also
MGD is offline   Reply With Quote
Old 11-03-2009, 07:40 PM   #590
velvet245 is an unknown quantity at this point
nokia 5800
Hey, first of all, great plugin you made there 0o.
I'm just starting out with my first few little testruns with riderunner on my normal desktop pc, just to see if it will suit my needs ^^. One of the things I really like, is having a handsfree set, so I'd like to try this plugin out a little.
There's one problem though, my mobile phone (nokia 5800 expressmusic) isn't in de list of models supported by Bluesoleil. Using the n96, or 5700 models in bluesoleil, does install an api on the phone, but as to be expected, its not compatible and so it won't update my contacts in the normal browser. Let alone it functioning in the mobilephone plugin.
I did send a support message to the guys at bluesoleil (I read they're pretty helpful), but I'd like to know if you guys know any way to make this work on my phone?
If this isn't going to work, then I'm considering buying another phone to use with this app exclusively. Wich of the models work best with the api, as far as you guys know?
velvet245 is offline   Reply With Quote
Old 11-07-2009, 01:58 AM   #591
anuchit is an unknown quantity at this point
Can I mute or stop dvd when incoming call?
I test on VLC,MPC,WMP have same bug
can speed up volume when use handfree? and slow down volume when hangup or finish to talk.
anuchit is offline   Reply With Quote
Old 11-07-2009, 03:36 AM   #592
Excuteme sorry its can not stop when play only title
Old 11-07-2009, 05:00 PM   #593
lambosprit's Avatar
If you have an incomming call rr is sent a pause command. This should pause video or music.
as for all the volume change requests , I'm waiting for Spidermunz whose arranging some fancy new stuff in RR that'll I'll make use of. Not sure where he's got to with it though as its been a while. Might be time to pester him
Old 11-09-2009, 05:22 AM   #594
l1nk's Avatar
Ok, just buyed one used pink razrv3 on ebay. I'll test it next weekend then I'll post results here. Thank you
Old 11-10-2009, 09:19 PM   #595
Mini Sumo is an unknown quantity at this point
ok I'm having trouble getting the dll's to register ? where do I need this file ?
The BSWrapper uses VC++ so needs to have the VC++ Redistributable installed. Its called vcredist_x86.exe and should be in the install folders.
not sure I understand which folder it needs to be in ? I also did the post 77 recommended fix and that didn't help either. For some reason they are not getting registered ?
Thanks,
Mini Sumo Was here
Mini Sumo is offline   Reply With Quote
Old 11-11-2009, 10:49 AM   #596
Hi guy
I test your plugin and I found alittle delay and echo.. but It work for me look great..
I install asio4all and setting ( pic)
and install andrea audiocommaner and set microphone wizard
It seem better than before I not use..
I use normal microphone .
Old 11-11-2009, 12:13 PM   #597
Can you make asio4all vertual device plugin for ivt bluesoeil seem foobar
I think myselft.
it work about latency compensation of sound because it prefer direct soundcard to speaker.
Old 11-12-2009, 07:53 AM   #598
Wolvers is an unknown quantity at this point
Can you speak to him about radio on and off as well as I don't think the radio mute commands in the buttons on my skin are working as I'd like? I think it's unmuting the radio when I press the call/dial button when the radio is not being used and subsequently the caller hears radio as well as me.
Any word from BS about echo cancellation?
I still haven't figured out why your plugin makes my radio audio skip.
Wolvers is offline   Reply With Quote
Old 11-12-2009, 04:16 PM   #599
sargeants's Avatar
sargeants is an unknown quantity at this point
I installed this and got it working so far. I do notice a delay and on the other end they can hear themselves after a delay as well.
Any tweaks or adjustments for the echo cancellation? I'm using an Andrea mic like from the store.
03 Hyundai Elantra GT
HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
RideRunner; cmdRR tall skin (in creation)
Elantra Worklog
86 Pontiac Fiero SE 2m6
Sony MP3 CD deck
eventual carpc install
sargeants is online now   Reply With Quote
Old 11-12-2009, 06:53 PM   #600
Keem is on a distinguished road
Did you just plug in the andrea mic and have it work? I am having issues getting it to work for me.
Keem is offline   Reply With Quote
nGhost 2.0.0 Final is out! kev000 LinuxICE 53 07-16-2009 10:16 PM
Bluetooth problems their solutions Clintebb Bluetooth Hardware 9 12-26-2007 09:03 AM
Hello World plugin paulpv CF Plugins 5 06-08-2006 11:07 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
