Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 04-27-2009, 11:30 AM   #106
lambosprit's Avatar
lambosprit is on a distinguished road
vtcom. Your log file looks fine but I would still try the things I suggested. I may not have cracked the logging issue yet.
Sonic. Did you set your debuglevel as I suggested before you did the test? This may have been what actually fixed it for you. As for the installer it does overwrite the .ini file. The problem is I'm adding to it quite regularily at the moment and dont want people to ignore it when they should be updating to the new one.
lambosprit is offline   Reply With Quote
Old 04-27-2009, 02:12 PM   #107
Dartman_71 is an unknown quantity at this point
Quote: Originally Posted by lambosprit View Post
Dartman. I added the + command but its not in the skin. You will have to do this yourself. On this point does anyone know why * is used. I know about # and + but not star.
Thank you very much for this great plugin and developing it, you are the man Now I have more questions, how to close mobilecall.skin when hangup? Is't possible to stop BSWrapper logging? Could/can you add option to get caller names from MobilePhone_PC text file? it would be nice to see caller name in mobilecall.skin.
I don't reseive anything with mobilephone_dc and mobilephone_rc commands? Should I have different custom list than SC01?
In some countries and operators you need star if you wanna make call transfer or some service like that.
Keep up excellent work.
Dartman_71 is online now   Reply With Quote
Old 04-28-2009, 10:39 AM   #108
vtcom is an unknown quantity at this point
im back with some good news.
i uninstalled rr and the plugin and installed the latest rr
(before i only had a old version with updates installed)
and installed the plugin and all is well no more problems
with the log coming out of hibernate
vtcom is offline   Reply With Quote
Old 04-28-2009, 10:43 AM   #109
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
actually no set the level. And i've still not seen the debug error. I believe its fixed.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 04-28-2009, 11:55 AM   #110
lambosprit's Avatar
good. I'll take it as fixed then.
I introduced a few bugs with the new saving of recieved and dialed calls. Working on fixing them now.
Old 04-28-2009, 06:35 PM   #111
lambosprit's Avatar
to close the mobilecall.skin just add an exit to your button command so
mobilephone_hangup||exit
I will be improving the logging on the wrapper dll soon so that it can be switched off.
The mobilephone_dc and rc commands are used to load the txt files into road runner custom lists. However the code to populate these txt files was wrong. I've fixed it but just testing to make sure. You should also check your ini settings so as not to use the .\ for the phonebook path. For some reason vb gets confused about the current directory so set it to a full path.
Old 04-29-2009, 01:53 AM   #112
Nomader's Avatar
Nomader is on a distinguished road
can i ask a quick question?
what version of bluesoleil is everyone using? the trial? does it have a time limit?
Nomader is offline   Reply With Quote
Old 04-29-2009, 09:14 AM   #113
Terminal flasher
I'm using 6.4.249. The trial will not work because it doesnt allow you to enable the headset profile i believe. You can however find it online with a search.
03 Acura RSX Coupe
Old 04-29-2009, 12:33 PM   #114
Same here 6.4.249 registered and paid! Trial version have also 2M transfer limit.
Old 04-29-2009, 03:14 PM   #115
Nomader's Avatar
my phone is symbian nokia 5800 which is not on the list.. i selected another symbian phone and most things look like the work in blusoleil..i can browse my phone etc..
which service does this plugin use? is it dial up networking? or com port?
Old 04-29-2009, 05:03 PM   #116
EricE is on a distinguished road
I am registering my interest here. I have an iPhone which I know is not directly supported by BlueSoleil. BUT, some have said that this plugin *should* work with any phone that supports headset functionality through BT which the iPhone definetly does. So unless someone responds saying they were not able to make anything work with this plugin and the iPhone I am going to load it up and give it a try. All I want to be able to do is pause playback upon phone ringing, dialing out, or during a phonecall.
Update: In looking at the downloads in the first post of this thread there are two files with no description on either. After downloading them both I can see that the .rar file is the older version and the .zip file is the newer version. Do I have that right?
Update: I just tested the bluesoleil drivers with the bluesoleil dialer. The dialer does know when a call is incoming and it can place outgoing calls so it seems to me that what I want to do is possible.
I'll have to try it now with my earpiece and see if the phone can work the two devices simultaneously. After that I'll try the plugin from this thread and see what can be done.
Update: The phone won't work with two "headphones" at the same time. It seems to use whichever connected first. So the bluesoleil should do what I want as long as I give up on using the earpiece at all. Hmmm.
EricE is offline   Reply With Quote
Old 04-30-2009, 08:12 AM   #117
lambosprit's Avatar
there are two versions of bluesoleil that work and they are listed in the readme file. I tried a cracked version for testing but it kept crashing , then tried the trial version which works but has a 2mb download and 15day limit. The software is dirt cheap though which is why I chose it.
The plugin uses the bluesoleil sdk so neither dial up nor com port. The way bluesoleil connects to the phone is decided by itself. On this point I did get dial up networking working on the old version but haven't put it in the new wrapper version yet.
as for the two versions in the first post I was keeping the original rar because it didn't use the wrapper which wasn't fully tested. I should delete it now as the wrapper seems to be ok.
The headset is something I haven't implemented yet. It is possible to use headset AND handsfree but I wanted to get hands free working as this is the most use on a carputer as far as I'm concerned.
all the above is on the list and I have a long trip away from home soon so will have the time to do it.
Old 04-30-2009, 11:07 AM   #118
Hmmm. It should be able to use both a handsfree and a headset huh? Well, that is for later, at the moment I just need to figure out how to build/implement a skin that will popup when a call comes in.
When I look at the Authorization tab for BlueSoleil I see:
Bluetooth Serial Port (com6)
Bluetooth Serial Port (com7)
Bluetooth Advanced Audio
Bluetooth object push
Bluetooth File Transfer
Bluetooth Basic Imaging Service
Bluetooth Quick Print Service
Bluetooth Personal Area Network
Which of those are you using for the Handsfree as it isn't clear to me.
P.S. The mobilephone_readme.txt in the .rar is formated better than the same file in the .zip. The one in the .zip is messed up with no Carrage returns.
Old 04-30-2009, 11:46 AM   #119
Nomader's Avatar
i am having trouble conecting my phone..
as soon as RR is started i see the dialup networking connecting for 10 seconds then disconecting again and again..the plugins skin it self does not show any life signs
Old 04-30-2009, 12:32 PM   #120
Are you planning on implementing an OnCall indicator? The one thing that seems missing is if I place a call from my phone there is no indicator to RR to tell it I am on a call and therefor pause the playback.
nGhost 2.0.0 Final is out! kev000 LinuxICE 53 07-16-2009 10:16 PM
Bluetooth problems their solutions Clintebb Bluetooth Hardware 9 12-26-2007 09:03 AM
Hello World plugin paulpv CF Plugins 5 06-08-2006 11:07 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
