Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Plugins > RR Released Plugins
Old 02-19-2009, 04:24 PM   #1
lambosprit's Avatar
lambosprit is on a distinguished road
.net Bluetooth Mobilephone Plugin
***** To make sure the dll is registered properly use carwings skin in the riderunner release. Go to plugin manager and you should see mobilephone with all info and whether its enabled. (see post 3 for screen shot) *********
If not try the approach in post 77 of this thread.
version 1.14
Added new return slider controls. Called mobilephone_batslide and mobilephone_sigslide. They use the values you
set for BatteryImageCount and SignalImageCount in the ini file to work out the slider points so they must be set
properly to get the correct output. Only you can do this as all phones are different and most phones dont support
this feature so don't be surprised if it doesn't work.
Changed mobilephone_incommingcall to only be true when the phone is ringing and not when you're in a call. This
fixes the mobilecall popping up error.
version 1.13
DTMF is now enabled. Any key press made while in a call will automatically be treatd as a DTMF code. Only 0-9 and * and #
are valid.
Added new command mobilephone_transaudio which transfers audio to phone or headphones.
Fixed so that mobilecall.skin only called when phone ringing and not just in a call or when making a call.
Added ongoing calls to the incall indicator. Fixes unmute of music before call finished.
version 1.12
Fixed the pausing issue when making outgoing call
added new button commands to mute/unmute the phones mic and speaker.
mobile_disconnect now disables autoconnect. mobile_connect re-enables autoconnect if it was set to true in ini file.
this allows you to disconnect the phone to uses a headset and reconnect when finished talking.
BSWrapper now allows debug to be switched off via its new ini file.
Changed plugin so the onclselclick and onclclick and custom list commands only work if the skin file name
starts with mobilephone. This is to stop interaction problems with other plugins.
New installer to make life easier I hope.
Changed versioning so its now 1.12 with build so I can track versions better.
I've also removed the vc++ runtime installer as it was making the file too big.The readme has a link to were it can be downloaded if need be.
version 1.0.0.11
Fixed incall indicator so works for both incomming and outgoing calls.
Changed default caller name to phone number rather than Unknown.
Network operator is now translated to meaningful text.
version 1.0.0.10
Dialed calls and recieved calls phonebook now shows caller name if number in mobilephone_pc.txt
new label mobilephone_callername shows name if number in mobilephone_pc.txt.
version 1.0.0.9
Fixed phonebook storing of recieved and dialed calls.
fixed mobilephone_photopath indicator when call comes in.
version 1.0.0.8
New logging system
added mobilephone_+ command variable.
removed restriction to only take commands from mobilephone.skin
Dialled calls and recieved calls are now log when made / accepted throuh the plugin. No calls made / recieved outside of the plugin are stored!
Version 1.0.0.7 released.
Fixed bug in installer. you must now add X,mobilephone yourself to the menu.skin file if still using road runner.
Works with plugin manager now.
Now uses MENU instead of LOAD when calling mobilecall.skin
Version 1.0.0.6 released.
Implemented auto answer feature. The call will be answered after a defined number of seconds ringing. Setting to 0 or not having switches off.
Added mobilephone_cancelaa. This allows the auto answer to be cancelled for the current call.
Redial last number. mobilephone_pickup will now pickup call if ringing, dial call if mobilephone_dialbox has a number or redial the last number if mobilephone_dialbox is empty.
Auto connect. Will reconnect to the phone if the connection is lost for some reason.
Added mobilephone_disconnect. Use it in the exectbl.ini file with "quit" to shutdown mobilephone on RR quit. eg. "QUIT","mobilephone_disconnect||bye".
NOTE: skin must use QUIT rather than EXIT for this to work.
Multiple phone addresses. You can now enter multiple phone addresses seperated by a ;. Mobilephone will connect in the list order. Only one phone will be connected to.
Pausing winamp or video. When the phone is ringing or you make a call the PAUSE command is sent if STATUS=PLAY. Then when hangup is presse the PLAY command is sent.
When ringing occures the dll now tells RR to load the mobilecall.skin regardless of current skin screen.
Release 1.0.0.5
This version uses my stand alone wrapper dll so is a pretty major rewrite so I've left the original version here as well just in case.
I've also added to the skin files so now I've improved the original one plus made the BMV2 phoco one work with this plugin. Its in the skin folder but would have to be renamed to use it. There is less functionality in this screen than lucifers.
Its a bluetooth mobilephone plugin using .net and the BlueSoleil software for bluetooth.
I've made use of Lucifers ATSM mobilephone plugin and must give him full credit for inspiring me into doing this and providing the base framework. Because of this the plugin has both ATSM and Bluetooth functionality. Having said that I know nothing about how ATSM works so cannot provide help on that part and I hope I haven't broken it when adding the new fuctionality.
So to the usual question of does this support my phone? Well check the BlueSoleil website. It has a full list of supported phones. If its not there then it doesn't but the list is pretty extensive.
So onto the important stuff.
In the attached rar file you will find a read me telling you everything you need to know.
Installation instructions
Pre-requisites:
1) You must have BlueSoleil version 6.4.236.0 or greater is required for this plugin to work. You can use the trial version to test.
2) This is a .net application so the .net framework must be installed. I've tested it with .net 2.0.
3) You must have the vc runtime installed. You'll find it in the installer rar.
Installing:
Run swift_gti's installer (Big thanks to him for initial testing and creating the installer). Everything should be installed automatically. If not refer to the troubleshooting guide in the rar.
Next you need to pair the phone before using this dll. Do this in bluesoleil itself. Once paired it will remain paired forever unless you unpair.
Next, you need the bluetooth address for the phone. Hover over your phone in bluesoleil and you'll see it.
This needs to be added to your mobilephone.ini file for the dll to allow you to connect only that phone. This is for security reasons.
Trial skin
There is a trial skin also for BMV courtesy of Lucifer.To install this:
add skin folder from the attached zip to your skin directory
add x,mobilephone to your menu.skin
change the button 09 in the menu.skin to B09,10,416,150,110,"LOAD;MOBILEPHONE.SKIN;","" *** this only applies to the BMV2 skin
PLEASE NOTE. the smssend button is the dial button.
For trouble shooting there is a debug log created in a log directory. Try looking in there if you experience problems or post the log here for help.
What you should see.
Well nothing really. In the skin you will see a set of three circles above a button called conn. If the left most one is green you are connected and can make a call. If not try clicking the conn button when the circle should go green.
thats it. You should be good to go now. Have fun and goodluck.
lambosprit is offline   Reply With Quote
Old 02-19-2009, 04:25 PM   #2
lambosprit's Avatar
Screen shot of skin working
This is a screenshot of what it looks like when working. Notice the green circle above the conn button. This indicates that RR has connected with your phone successfully.
Old 02-19-2009, 04:25 PM   #3
lambosprit's Avatar
Ride Runners Car wings plugin manager screen shot
Old 02-19-2009, 04:54 PM   #4
DaveDog's Avatar
DaveDog is on a distinguished road
time to fire up the test unit!!!!
TruckPC, BoatPC, and CarPC I need a life!
DaveDog is offline   Reply With Quote
Old 02-19-2009, 05:03 PM   #5
swift_gti is an unknown quantity at this point
Updated installer sent, I'd hold off until then or do the install manually so you know where everything lives as the new one moves some stuff around.
swift_gti is offline   Reply With Quote
Old 02-19-2009, 05:22 PM   #6
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
pretty cool
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 02-19-2009, 05:40 PM   #7
lambosprit's Avatar
new installer added. Cheers Swift_gti
Old 02-19-2009, 06:01 PM   #8
pcpete's Avatar
pcpete is on a distinguished road
can't wait to try this!
htc touch cdma bell mobility, nfsfan custom rom...generic 10$ bt dongle....
pcpete is offline   Reply With Quote
Old 02-19-2009, 06:44 PM   #9
lambosprit's Avatar
just found a bug. You MUST have the mobilephone.ini in the roadrunner directory otherwise nothing happens. Working on fixing it now
Old 02-20-2009, 08:09 AM   #10
lambosprit's Avatar
Bug fixed and new installer added in post one.
The mobilephone.ini is now looked for in .\plugins\mobilephone as it should be.
Old 02-22-2009, 12:03 AM   #11
SoulR's Avatar
SoulR is an unknown quantity at this point
Awesome work lambosprit, will have to try this once i get my act together.
SoulR is offline   Reply With Quote
Old 02-22-2009, 02:54 AM   #12
bes51659's Avatar
bes51659 is on a distinguished road
This sounds great!
Is there a way to run this standalone?
Tried to run the setup but it requires a valid RR directory.
A 8051 system that controls PC power etc with or without BMW IBus and is a GPS receiver with dead reckoning. mp3car thread
My car installation mp3car thread "showing off project"
bes51659 is offline   Reply With Quote
Old 02-22-2009, 09:58 AM   #13
lambosprit's Avatar
It needs RR to run because all the control inputs are through RR. It might be possible to make it standalone but what would the inputs be?
Old 02-22-2009, 01:19 PM   #14
bes51659's Avatar
Well, FreePhone had an early version that worked stand alone. That is, it looked as being inside rr with skin and all, but run without having RR acctually installed.
I don't know how much work it is, but since I am not running RR...
Old 02-22-2009, 03:43 PM   #15
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
I havent been able to get this to work.
THis is the copy of the debug when loading from menu.skin
2/22/2009 2:36:45 PM: Plugin Manager: Error loading (menu.skin): mobilephone(ActiveX component can't create object, check spelling of plugin, or its is COM registration missing.)
THis is the copy of the debug when loading from plugin manager
2/22/2009 2:36:44 PM: Plugin Manager: Plugin Found: MobilePhone(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped].
Here is a copy of the registration from command prompt
C:\Program Files\RideRunner\Plugins\MobilePhone>regasm.exe MobilePhone.dll /tlb:
MobilePhone.tlb
Microsoft (R) .NET Framework Assembly Registration Utility 2.0.50727.42
Copyright (C) Microsoft Corporation 1998-2004. All rights reserved.
Types registered successfully
Assembly exported to 'C:\Program Files\RideRunner\Plugins\MobilePhone\MobilePhon
e.tlb', and the type library was registered successfully
C:\Program Files\RideRunner\Plugins\MobilePhone>pause
Press any key to continue . . .
SO it is registered successfully, but still cant get RR to load it.
Any thoughts..
ThunderStick is offline   Reply With Quote
nGhost 2.0.0 Final is out! kev000 LinuxICE 53 07-16-2009 10:16 PM
Bluetooth problems their solutions Clintebb Bluetooth Hardware 9 12-26-2007 09:03 AM
Hello World plugin paulpv CF Plugins 5 06-08-2006 11:07 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
